Need to step on accelerator to start + P1320 = Crankshaft pos sensor?
Old 12-10-2010, 11:52 PM
KilJim's Avatar
Help~ Car not starting, no sound or anything
Hi guys,
Recently since about the last 2-3 weeks my '00 I30 has been getting starting problems. It sounds like it cranks just fine, but doesn't start up unless I step on the accelerator pedal (and a few tries with that)
Started off not so common, now it happens once in every 2-3 starts.
I've also had a P1320 for a long long time now. Previously had 2 coils replaced after getting specific coil codes, I always thought it was just gonna be another coil going bad so I didn't check the CPS
Anyway does this sound like it might be the crankshaft pos sensor (REF) going bad? If it is I might just go ahead and change it since it's not too expensive
UPDATE:
So now the car wont start at all. At first it cranks like usual, slowly got weaker and weaker until it doesnt crank at all now
Radio, fan and lights work when i turn the key to the ACC position. When i turn it to start, everything goes out
Is there a way to tell if this is the battery or starter? or something else
KilJim is offline
Old 12-11-2010, 04:45 AM
Ghost_54's Avatar
Soon as you described the hard to start having good crank power I thought it was the CPS, it would be the first thing I would replace.
Ghost_54 is offline
Old 12-11-2010, 05:31 PM
KilJim's Avatar
Yeah, read this thread Starting Issues - Related to Camshaft/Crankshaft Sensors? and thought it might be a similar issue
Nvm figured it out, its the right/front one apparently
KilJim is offline
Old 12-11-2010, 09:22 PM
P. Samson's Avatar
First......remove the CPS (the one under the crank pulley), clean any swarf of the business end, check it for cracks, check the harness and connector for damage, and reinstall. See if that makes any change in the hard to start issue before you start throwing parts on the car.
P. Samson is offline
Old 12-16-2010, 03:23 PM
KilJim's Avatar
UPDATE:
KilJim is offline
Old 12-16-2010, 03:51 PM
Amave's Avatar
sounds like a battery issue.
even if the lights come on when you turn the key to ACC doesn't mean the battery is strong enough to crank the starter .
if you have the starting problem iwth a strong battery, then your starter or starter circuit is FUBA'red
Amave is offline
Old 12-16-2010, 04:30 PM
Froggmann's Avatar
Originally Posted by KilJim
UPDATE:
Your battery is dead now because of the cranking. As for the hard start issue try cleaning your grounds. I just read about another issue like this on another thread.
Froggmann is offline
Old 12-16-2010, 07:25 PM
CMax03's Avatar
Maybe from trying to start it so much he may have ran down the battery....
CMax03 is offline
Old 12-16-2010, 08:45 PM
KilJim's Avatar
Would if its just the battery would it not crank at all?
It has enough to power the radio, lights and fans right now, but doesnt even try to crank at all
KilJim is offline
Old 12-17-2010, 05:54 AM
sontakke's Avatar
A new battery costs $50; buy one if yours is more than 3 years old. THEN start figuring out the other problems.
sontakke is offline
Old 12-20-2010, 03:24 PM
KilJim's Avatar
Problem solved
Put in a new started from Advanced Auto and it started up better than ever
No need to waste $80 on a new battery
Also swapped ignition coil #1 with an eBay one and the P1320 is gone
Thanks for the input guys
KilJim is offline
cruce91
09-20-2015 10:23 AM
sake1bs
09-19-2015 09:32 PM
intimidator
09-05-2015 07:23 PM
00MAXI
09-02-2015 10:23 AM
maxinout93
08-20-2015 02:17 AM
Quick Reply: Need to step on accelerator to start + P1320 = Crankshaft pos sensor?
