Crank no start help!!!
How are the lights? Does it look like the battery is low? Maybe alternator?
It could be something with your security where immobilizer is still active.
It could also be related to your crankshaft position sensors or camshaft position sensor(s).
valve cover seals are no big deal, happens on most of these engines and its a job you can do yourself. The cranking but no start could be a few things so lets start small. Any codes? How are your spark plugs and cam and crankshaft position sensors?
UPDATE:
The oil cooler o ring needs to be replaced and after getting it towed to the shop my car started right up which I dont understand because I couldnt get it to start for 2 weeks.
Based on that I would say you need to check your crankshaft position sensor(s). One or both may be bad. Also check your ground connections. If one is bad then you'll need to fix it. If everything checks out OK then you will need to add a ground cable from your tranny (as close to CPK as possible) to the negative terminal on your battery. Use a 2 or 4 gauge wire with good connections. I picked up everything for the ground wire from Home Depot for under $10.
What's the point of grounding from the frame to the battery? Or, are you talking about grounding from the tranny to the frame?
Ok people oil leak fixed got an oil change now gettin my ac belt changed. The max starts fine im clueless. Maybe where I parked at is on an incline my car sit there for long periods sometimes 2 weeks maybe thats a factor, idk, dat @$#t kray.
Give it time the hard or no start may return. Initially, mine went away for weeks at a time and came back. As it went on further it became more frequent. It took me almost 2 years to figure it out and get it fixed thanks with the help from the org.
Got my car back today runs great once it starts. Starts are kinda rough so Im going to change my starter. New tensioner pulley and belt were a big difference especially in the noise department, my compressor is no super quiet.
How old is the battery? This stuff happens in 3s right? What about the ground and sensors? You may want to verify the crank problem before throwing parts at it, as in CPK and CPS, along with the checking your connection to a starter before replacing it. If this was flooded with oil you may want to pull a spark plug and see if they are fouled.
97_GXE
09-15-2015 06:47 AM
ballerchris510
09-11-2015 05:29 PM
