Anyone use Urethane exhaust hangers
Has anyone used these on their car? I'm looking into them for the fact my stock hangers are worn and need to be replaced, and I would like something that will keep the exhaust system from major movement. Or can someone tell me the sizes of each hanger and I will order them and test them out!
Thank you
Sent from my ADR6300 using Tapatalk
Thank you
You could save the money and just zip tie your current ones. Works just as good if not better then the poly ones and will hold well over time. I don't have any pictures, but you zip tie the outer perimeter of the hanger so that it holds it's shape even when weight is applied to it.
In 35 years of driving and owning probably 60 different cars and trucks, I've never messed with exhaust hangers. Do they make a lot of noise or something when they wear out? Maybe it's because I've always lived in So Cal, where we have no winter.
I've replaced them in my b13 with poly ones from kartboy.com Its mostly Subaru ones, but they made a special run for us on the sr20 forums. I'm replacing the exhaust and am going to try it with 3 leftover ones I have laying around. Hopefully, they are the right size. Made a world of difference, exhaust swaying is eliminated, and no banging around when rockin and rollin. Yes, they do wear out in a way. The rubber does stretch over time...... My 2 cents.....
I wouldn't say 8 years would do much but I'm sure couple more years would sag them up, I personally just changed my muffler and mines looked just fine for an 02 maxima and I'm pretty sure they were stock...
06-06-2017 02:01 PM
KabirUTA13
19
10-17-2015 02:15 AM
