Weird sound after reving
Old 10-06-2010, 07:37 PM
asma123's Avatar
hey guys I've been having an issue mainly with accelerating. Today I turned on my car (it's been sitting since I upgraded vehicles.) I turned it on and reved it up a bit and I noticed there was this rattle everytime I rev it up. Any ideas?
I got the 2k2 maxima gxe model. heres what it sounds like.
http://www.mediafire.com/?ps3nod8pk95gpo2
asma123 is offline
Old 10-07-2010, 04:14 PM
asma123's Avatar
Bump
Anyone got any ideas?
asma123 is offline
Old 10-07-2010, 04:20 PM
Ghost_54's Avatar
perhaps check the front heat shield on the exhaust, they do have a habit of becoming loose and creating a slight rattle noise.
Ghost_54 is offline
Old 10-07-2010, 06:24 PM
Toolie
knight_yyz's Avatar
when was the last time you checked the oil level?
knight_yyz is offline
Old 10-08-2010, 12:39 AM
asma123's Avatar
I'll check it when I have time. I'm sure it should be ok
last oil change car was fine and I just recently changed the oil 3 weeks ago and car has been sitting for 2 weeks so the oil thats in it right now only has like a week of usage
asma123 is offline
Old 10-08-2010, 04:58 AM
.aNiMaL's Avatar
i am having the same problem. it is such a small slight rattle. right at the end of the rev
.aNiMaL is offline
Old 10-08-2010, 12:07 PM
asma123's Avatar
I was doing some research I know about the famous rattle lots of people get when their engine is stressed roughly 2k rpm perhaps it's the same thing thats making the sound?
From what I hear it could be either the heat shield or the precats more than likely the precats.
asma123 is offline
Old 10-09-2010, 11:59 AM
Gizm0's Avatar
If you ever find out where the noise is coming from, please let me know, bc I have the exact same noise on my max
Gizm0 is offline
Old 10-09-2010, 12:01 PM
Gizm0's Avatar
One detail, on my car, it only does that sound when the engine is warmed up. If it is cold, no noise for some reason...
Gizm0 is offline
Old 10-12-2010, 06:12 AM
Gizm0's Avatar
Well, I finally decided to get under the car while my friend was reving it up, and it's definately coming from inside the rear pre-cat. Nissan quoted me $785 just for parts...
I can get one on eBay for just over $200. Anyone has experience with ebay precat for their max?
Gizm0 is offline
Old 10-12-2010, 01:48 PM
Gizm0's Avatar
Since the inside of my precat is all blown up, I figured it probably partially threw all kind of **** up the third catalytic converter located downstream of the Y-pipe and most likely partially clogged it up so I will probably go ahead and replace this one too. Since I'm cheap, I was thinking of pulling it off, and removing the honeycomb thing inside the cat with a hammer and screwdriver, and put it back on the exhaust as is... Is it a good/bad idea?
It will probably throw me some codes but I don't care, but my question is: will it decrease the performance of the car since it will fool the 02 sensors?
Gizm0 is offline
Old 10-22-2010, 05:40 AM
Gizm0's Avatar
Alright, I had the exact same problem with my Max coming from the rear precat. I bought a precat on eBay for about $280 and paid a local exhaust shop $75. 2 hours later, the noise is gone
So now you know what to do!
Gizm0 is offline
Old 10-22-2010, 08:26 PM
asma123's Avatar
thanks. I'll check up on it hopefully my mechanic wont charge me an arm and a leg for the work
asma123 is offline
AaronL
08-08-2020 10:31 AM
Mahmuth
10-17-2015 12:03 PM
Need help
23
10-02-2015 08:56 AM
HerpDerp1919
09-29-2015 02:02 PM
DC_Juggernaut
09-28-2015 04:07 PM
Quick Reply: Weird sound after reving
