Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-31-2010, 09:03 PM   #1
big maf tuning
Has anyone with a vafcII figured out how to tune their bbmaf? I have found that setting the sensor to 1 in 3 out evens out the idle but then you have to tune it down as you start to drive and no matter how much i turn down 3500 it still runs rich down to 9.2 afr. I know every car is different but any feedback would work great.
if you have NO experience with the bbmaf please keep your comments.
i am not going to buy a safcII either. I know it works with that afc.
rayac88 is offline   Reply With Quote
Old 07-31-2010, 09:20 PM   #2
I am also curious. I have a VAFC, and I really don't feel like configuring all of the settings manually, so someone please chime in with the proper sensor configuration for the VAFC.
__________________
2002 Maxima SE 6MT:
Black on Black. Loaded.
Performance:
HLSD, OBX v2 Headers, Custom 2.5" Exhaust, DIY VIAS Delete, NWP's Intake Spacers, ES Motor Mount Inserts, ES Rear Trailing Arm Inserts, ES Front Sway Bar Bushings, ES Shifter Bushings, Moog Endlinks, Progress RSB, Lowered on Eibach's, Innovate LC-1 Wideband, Apexi VAFC-II, Custom Short Ram Intake with Velocity Stack, 6th Gen BBK.
Appearance:
Fresh Paint at my Dad's shop, 01 SE Black Tails, AE Replica Rear Lip, Sunroof fin delete.
Unklejoe is offline   Reply With Quote
Old 07-31-2010, 10:04 PM   #3
update: still set to 1in 3out tuned narrow lvt down to about -17 up too 4100 rpm. and runs good around 15 -13.9. but i cannot seem to tune the wot no matter how low i tune the wide throttle i have it down to 17 and still reading 9.2 afr. is there a setting i down have set? my th point is at 55% for wot
Old 08-01-2010, 02:34 AM   #4
I see what you did there
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
SAFCII >
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
Quote:
It's like killing ants with a rocket launcher ....
NmexMAX is offline   Reply With Quote
Old 08-01-2010, 07:39 AM   #5
My axles cry for mercy...
essential1's Avatar
I'm gonna be running a larger maf soon too with my vafc2. I'm waiting on my wideband though, so until then...
Quote:
Originally Posted by NmexMAX View Post
SAFCII >
__________________
DJ paul drives a 5th gen
essential1 is offline   Reply With Quote
Old 08-01-2010, 03:53 PM   #6
NmexMAX's Avatar
Strange it's running rich. Whats the diameter of this new MAF?
I was @ +27% when I first tossed my BBMAF on. It was very lean otherwise. I would get some good AFR and it felt responsive, then it would fall on it's face. Then I found out about the IN/OUT deal.
What tranny type do you have and how does it idle (AFR)?
__________________
Old 08-01-2010, 04:11 PM   #7
essential1's Avatar
By the way, have you tried to space out the IN/OUT settings more than you have it now? Such as 1IN 6OUT? Or 1IN 10OUT?
__________________
Old 08-01-2010, 05:59 PM   #8
NmexMAX's Avatar
After taking a look at the VAFC wiring diagram, looks like there are only 3 V6's, the J30, J32 and the J35. Those are all PR-6, Vehicle #2 for the sensor info. I would imagine these have the largest intake diameters, so that might be a good place to start since the correction scale would be greater. Maybe try using say a D15 engine (PR-6 Vehicle #2) and the other one of the V6 variants mentioned above. Maybe food for thought.
__________________
Old 08-01-2010, 06:58 PM   #9
Quote:
Yes i havent gone through every setting yet its super time consuming to sit there to turn the car on run then off then start it and see.
i can set it to run really lean but i would prefer to tune from a rich standpoint to avoid kaboom...
its a bosch tube thats i all i know the owner said its from a 5 series. im guessing its lin 3.25 id... its huge i have to use a 3.5" coupler to hold it on... i tuned it to run good but once WOT hits the gas just shoots into the intake and feels like some one trying to run through water.
Old 08-01-2010, 07:02 PM   #10
NmexMAX's Avatar
Probably an M62 engine, same as LRMAF.
__________________
Old 08-01-2010, 09:01 PM   #11
looks similiar to the lr maf... probably is. i did some testing and 1in 3out works the same as 4in 3out and 8in 3out. I just cant get the thing to tune under WOT. im starting to wonder if the computer is going around the tuner at hvt. or that i have some setting wrong in reference to the wide throttle.
Old 08-02-2010, 06:03 AM   #12
NmexMAX's Avatar
Try putting your old MAF on and see if it does anything different. I'm just baffled at it going rich instead of lean. Try 1 and 6 maybe.
__________________
Old 08-02-2010, 06:23 AM   #13
essential1's Avatar
What year/generation 5 series did it come out of. (if you know) Or better yet, what years can you get the m62 maf from either vehicle.
I was shocked when he mentioned it is staying rich also, but this is a good starting point for advancing timing...
__________________
Old 08-02-2010, 06:29 AM   #14
essential1's Avatar
By the way, how do you have the tuning map set up? Did you combine the maps to get 24 correction points? Or are you using just 12? If you're using 24, make sure you have the hvt and lvt set properly
__________________
Old 08-02-2010, 07:08 AM   #15
good shyt here
__________________
Quote:
Originally Posted by tedo007 View Post
Hustle you manage to pull 13.7 in 1/4 mile and I have 6 speed and better bolt ons(I THINK).
DCMAX current mods- 4th gen intake, 2.5" custom catback, NWP block off plate, 00SE tailight w/overlays, Rewired fog lights, Eyelid, JIC coilovers, FSTB, 3.0 OBX headers, SSIM...
00 Sterling GXE- 15.0 (ebay intake, exhaust) my next love and beauty (crashed n sold)
02 Sterling GLE- 13.704@100 2.0' street tires http://www.youtube.com/watch?v=jlvEqClE9R0
Grand_hustle17 is offline   Reply With Quote
Old 08-02-2010, 07:13 AM   #16
NmexMAX's Avatar
If this is the case, well then I may need to play with my settings to get on the rich side for that simple fact ...
IIRC, the M62/S62 use that big bad boy. Also, this thing is found on Ferrari F360's too.
__________________
Old 08-02-2010, 07:17 AM   #17
essential1's Avatar
hmm... good enough for a ferrari? Good enough for me.
__________________
Old 08-02-2010, 07:20 AM   #18
LMAO!!! thats funny, its crazy how im not really looking for any HP gains out my LRMAF moreso a powerband shift
__________________
Old 08-02-2010, 07:20 AM   #19
NmexMAX's Avatar
They have 2 of them though.
__________________
Old 08-02-2010, 07:22 AM   #20
essential1's Avatar
I have a really big drill and my manifold is only plastic...
__________________
Old 08-02-2010, 07:24 AM   #21
essential1's Avatar
Wait a minute... does a 97 BMW 540i also use an M62 MAF?
__________________
Old 08-02-2010, 07:32 AM   #22
i dare you lol
__________________
Old 08-02-2010, 07:46 AM   #23
1 10 and up runs me lean... i just dont want to tune that car lean cuz sometimes it goes as high as 19-20 afr once i saw it go that high i turned the car off
explain a little but more. i beleieve i have 12 on lvt and 12 on hvt i have to switch screens to go between the 2.
Old 08-02-2010, 07:48 AM   #24
if this problem cant be fixed by wednesday ima put the stock one in temporarily cuz i plan on going to the track on friday
Old 08-02-2010, 07:49 AM   #25
NmexMAX's Avatar
Take a look at the manual and try say 2/6. Those are the largest contrast of engine sizes IIRC.
__________________
Old 08-02-2010, 08:14 AM   #26
i will try again tonight after to work. ill go through the 2in and see. where is this diagram that has all the sensor types and voltages. im sure it will help. I am really the only one who has taken this on with the vafc2?
Old 08-02-2010, 09:09 AM   #27
NmexMAX's Avatar
Most just sorta fail and never get to it, so this could be ending up a breakthrough thread/sticky mateial.
http://www.apexi-usa.com/content/pdf6133.pdf
Page 11.
__________________
Old 08-02-2010, 09:33 AM   #28
essential1's Avatar
If you go under the settings menu it should be the 3rd on the list if i'm not mistaken. It should say V/T control or something to that nature. make sure that is set to switch over and the same rpm as your map switches over.
I wish my wideband was here already so I could help more.
__________________
Old 08-02-2010, 09:40 AM   #29
essential1's Avatar
Now that I think of it, I never really read the manual all the way through. I've only just skimmed through it at the most to find basic stuff to get the car running at the most. All I know about the vafc is from me just EFing with all the settings.
I'll start reading now only because you so kindly posted up the link for us.
__________________
Old 08-02-2010, 09:49 AM   #30
I have tried doing that and it gave me issue where my engine would run and then just cut off...i will put it back on and see if it allows my to lean it up
Old 08-02-2010, 09:50 AM   #31
essential1's Avatar
I just realized that the link you posted was just the wiring section... epic fail on my part....
__________________
Old 08-02-2010, 07:38 PM   #32
im about to join the masses and put back in the original maf... i cannot get this thing to work for me. the low end gains feel smoother but its just not taking the tune up high. if there is any one in miami that is proficient with the vafc send me a pm
Old 08-02-2010, 07:55 PM   #33
Wouldn't a dyno shop be needed for this???
__________________
Old 08-02-2010, 08:00 PM   #34
NmexMAX's Avatar
Right after the figure out how the hell you tossed an AFC designed for a Honda on your car, sure, they would help.
If a shop knew the answer, I'd be surprised as all hell and I would eat my words.
__________________
Old 08-02-2010, 08:15 PM   #35
when essential gets his wide band setup im sure we will find out if it can be done. I'm not gonna go to a tuner shop for something i could find the answer too with some messing around of settings. plus i always hear that tuning shops are an overkill on price but i digress.
ima take out the housing until essential gets his stuff installed and see what can be found. and so when my lighter rims come tomorrow i can see what the timing gains are at the track. ill admit I'm not perfect with the vafc2 but i feel i know enough about it to get this thing to work.
Old 08-03-2010, 12:11 AM   #36
I think it would help if you post all of your settings here. Such as your Lvt -> Hvt and your individual RPM points and whether you corrected only one of them or both.
I noticed that when I took my car to be dyno tuned (with a faulty knock sensor argh) the shop only tuned across one of the settings leaving the other one alone. I'm also waiting for a wideband to do the tuning myself.
They were able to tune the idle AFR however....
__________________
MODS:
Illuminas + Eibach | Stillen FSTB | Progress Rear Swaybar | 10mm Front/ 25mm Rear Eibach Spacers | Unorthodox UDP | Stillen Y-Pipe | HKS Rear Section | InJen WAI | Shinjinduo Grounding Kit | 300ZX BBK | Ionic Dynamics Bodykit | Ebay Projectors | Foglight HIDs |License Plate LEDs | Blacked out grills | Pioneer Avic-D3 | Interior LEDs
McSteve is offline   Reply With Quote
Old 08-03-2010, 02:09 AM   #37
I have the LR MAF housing that I'm going to install today, I also have a VAFCII, hopefully I don't run into these problems also.... ill post up all my settings later, when I get back from work
__________________
Old 08-03-2010, 06:17 PM   #38
Question to the Massive, where in the heck is the in and out setting on the VAFCII??? i looked through every option and i couldnt find it
__________________
Old 08-03-2010, 08:35 PM   #39
Quote:
download the user manual from apexi it will come in handy. its under etc. sensor type
Old 08-03-2010, 08:54 PM   #40
K I will....... I thought I checked that out also... ill check again...
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Advertising - Terms of Use - Privacy Policy - Jobs - Maxima Forums - Archive -
Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
