5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Just some teaser pics for my custom LTB stage 1 to go around my cattman headers. Once this is welded I will follow up and then turn it into a stage 2.
It's not quite there yet. Needs a few tweaks. I made the ends out of one solid piece of mild steel instead of the way the other more popular one was made. Needs to be trimmed and spot welded then I will tig weld it. Then it will be painted with por 15 hardnose paint.
__________________
6MT | 06HLSD | I/H/E & FC | Stillen FSTB & RSB | Eibach Pro Kit | Illuminas | Watkins STS | UDP | NWP Spacers | Greddy Blue | ES Bushings
sig courtesy of rochester
253.50 fwhp
249.75 lb/ft tq
14.3 @ 101mph (street tires, bad wheel bearing and a few spun tranny bearings)
very cool man!
will the 'other' LTB not fit around the cattman headers? what about the OBX headers?
why not get a little crazy and come up with a stage 3?
B
__________________
2002 Maxima SE 6spd w/HLSD
Stillen high flow intake - Ralco RZ STS - ES shifter bushings - CM FSTB - Fog light rewire - 6000k fogs
Knight, could you post the dimensions of the metal used so us DIY may be able to get the material ourselves to do this. What type of tubular mount to the control arms did u use. Did you have to cut a piece of metal into a circle then weld it to the tubular mount and then drill a hole so it would attach to the control arm? What size tube did you use to mount to the control arm..EX...1.5 in diameter by 1 inch deep..? What thickness was the plate used to weld to the back of the tubular mount and what size hole was drilled in it to mount to the control arms...
This has been something on my mind as well to DIY and add to the bottom..
The control arm mounts are one piece machined cups. I did not weld a washer like the other style out there. Mine should be stronger. The bar itself is 3/4 hydraulic tube thick wall.
The original tie bar may fit the OBX but I have no idea for sure. It definitely does not fit around the cattman. I already tried and have come up with this design.
__________________
253.50 fwhp
249.75 lb/ft tq
^^^^ knight for the machined cups how/where did you get them from...wait you said you are a machinist so did you do them yourself? Also to get the bar bent in the ways needed how did you go about that.
Ive been thinking of doing the same thing for a while now. Wondering since i dont have machine shop connections would getting say 2 pieces of tubing and then welding a thick enough plate on the back be strong enough for just Daily driving... thoughts..?
Yes, I am a tool and die maker so I machined the cups to just fit the 27mm socket that you need to remove the bolt for the ID then made the OD a nice even number. Then I drilled the hole clearance hole per specs for a 20mm thread.
For the bar I used a hydraulic bender that we have at work that can bend up to 1.5 in diameter tube.
__________________
253.50 fwhp
249.75 lb/ft tq
Rodriguez77 has a stg 2 or 3 with OBX headers and a really beautiful clean fit....Knight, I glad you're thinking cause those infamous Blehmco LTB weren't thought out to well. The cups are too small so a socket can't fit on the Lower control nut and the socket...
I'm not sure if there was a 3 either now that you mentioned it...but Rod77 had some nice shots under his car and I was really impressed that the OBX cleared the Blehmco LTB stg 2.....I can't do that with my Cattman headers installed! I would love to see how tying the suspension to the crossmember front and rear locations would work as well.....?
Please explain how it wasn't thought out too well.
I took a Craftsman and a Kobalt 27mm socket to the steel yard and fund tube that fit over both sockets, then made the rest of the bar fit around that.
They don't fit the Cattman headers since my design was done before the headers were out. Once they were out, nobody with the headers ever volunteered to come by my place for a test fit or I would have made a bar to fit them. Can't fix something like that if nobody helps. :shrug:
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
