Never Ending Misfiring...
Old 04-08-2011, 02:15 PM
  #41
jtm02011's Avatar
I get an occasional misfire on my max as well, it's from one of the wires that goes into the injector clip from the wire harness. Perhaps you could mess with those, just jiggle them, see if it makes a difference? Mine likes to skip warm or cold, but really loves it in the low RPMs vs high RPMs.
jtm02011 is offline
Old 04-08-2011, 02:47 PM
  #42
K-Ryder's Avatar
Look through this list and see what you've missed and check them..
Symptoms
Symptoms may include:
  • the engine may be harder to start
  • the engine may stumble / stumble, and/or hesitate
  • other symptoms may also be present
Causes
A code P0300 may mean that one or more of the following has happened:
  • Faulty spark plugs or wires
  • Faulty coil (pack)
  • Faulty oxygen sensor(s)
  • Faulty fuel injector(s)
  • Burned exhaust valve
  • Faulty catalytic converter(s)
  • Stuck/blocked EGR valve / passages
  • Faulty camshaft position sensor
  • Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
K-Ryder is offline
Old 04-28-2011, 05:12 PM
  #43
dustey's Avatar
Well, I got it figured out. There is something loose or a bad connection with the actual connector on the wiring harness which connects to the coil pack. Me and a friend of mine just starting wiggling all of the wires we could find after determining that it had to be something electrical related. By moving the connector itself a hair this or that way, I could cause it to misfire and then stop. We rigged it up to hold it place where it's not misfiring:
So far so good. It has misfired maybe once or twice in the last week but it was literally just ones or twice and then it would be fine.
My mechanic buddy at the Nissan dealership is going to replace it when he can find a spare.
I know what you are thinking... Shouldn't I have noticed this a really long time ago? Well, in hindsight, yes of course. But, it was one of those things that I took for granted and looked past. I never considered it could be something like that...
dustey is offline
06-06-2017 02:01 PM
maxinout93
10-31-2015 02:04 AM
BobTX10
10-07-2015 08:43 AM
09-27-2015 08:37 AM
Quick Reply: Never Ending Misfiring...
