How many of you guys have gotten the P1610 and P1612 Codes
I am confused as to how I drove my car last night fine and now today it wont start so I scan it and it gives me these codes P1610, P1612 I checked the internet and found that the key needs to be reprogrammed. is this true? and how often has it happend to you guy
Thank you
Jake
Thank you
Jake
NATIS malfunctions are pretty rare to begin with but i will try to help you with the best of my ability, have you checked to see if your key still has the blue transponder chip in the bottom of it?
also when you put the key into the ignition does the red security light up and stay solid when you turn it to the on position and try to start it. Does the car start? it could be as simple as the cable that connects the ignition transponder receiver has come loose and it just isnt detecting a key. let me know what you come up with i will try to help.
I am working on a 04 i35 with the red security light solid no start condition
i have a i35 solid red light no start condition took to the dealer no luck there tried a couple other shops and they can’t reprogram the key, now can I use a used 04 Infiniti immu and pcm with keys and get it reprogrammed? Also how do I tell if the pcms are compatible?
yat70458
08-03-2015 01:16 PM
