Ebay Halo Lights?
But...if you must. There are two types one can think of: the projector style and the non-projector style. I wouldn't recommend either for a 5.5gener. The light quality isn't nearly as good (unless of course, you retrofit them as mentioned above)
i have the ebay halos on my 5th gen. i think they look hella better with a 6000k+ HID kit. i def wouldnt put those on my 5.5gen. takes away from the look. and dont buy the projector ones, THEY SUCK
http://cgi.ebay.com/ebaymotors/JDM-0...ht_5632wt_1148
dont want to thread jack but could you post a pic of the output of the halos with the 6000k HIDs?
I've seen those ebay projectors in person and they definitely do not project like they are supposed to and the halos are not that bright, a waste of money that could have went to a performance mod IMO.
I was going to buy eBay halos but changed my decision at last moment just have added a lil bit more and took 2 5.5 gen oem lights and going to put orion V2 angel eyes in it. so can anybody help me with installation of Angel eyes into my 02 OEM lights in Philadelphia, PA?
One of my buddies here in MI bought the ebay projector head lights and his bulbs weren't seating properly. The right bulb was bouncing in the housing. They didn't fit properly and just were cheap quality. So I personally wouldn't recommend them. If you're looking to replace your headlights, I'd probably check out www.rockauto.com . They have good parts. Also www.autoanything.com
ive been looking at some for my 5th gen are these good ones?
with the 6000k HIDs you wont really be able to see the halo rings. the lenses that they use give off a slight glare which actually make the HIDs look a little brighter than they are, which to me isnt a bad thing at all. i would post a pic of them lit on my car but its in the shop.
Also, I heard that the Ebay halos have a better light pattern than the stock 00-01 headlights.. so i wanted to check it with someone that has them installed..
I would be great if you could post a pic of the light on the road from the halos with the HIDs.. the reason im asking is bc one of my stock headlights is cracked on the back of the housing and i cannot seal it to save my life.. so im thinking of getting the ebay halos and upgrading it with HIDs.
Ebay non projector with led corners, and 10k hids..i must say they are bright but they have nothing on the 2k2's and the 2k3's.. they definatly look good, and give off just enough light with the right hid bulb temp in them..
like BIGC said they give off a glare, which actually is a good thing.. i will try to get a pic of the light output soon cause im out of town right now.
ok, guys, I need help, I can't make new topic so I'll ask here. I have baught 02 OEM Xenon Headlights and going to put in my 2000 halogen Maxima, my mechanic told me I need connectors to change headlights. But I don't know what connectors do I need? I can't find it. I need connectors for HID-d2r, 9005 High beam and 7440 turn signal, a saw that parking light works from HID-D2R. can anybody help me to find what I need?
but its the honest truth... everyone that looks at my headlights love them, then when i turn on the HIDs theyre like D@mn which k HIDs r those and wen i say 6000k theyre like wow no cant b look more like 8 but they look really good
I had my stock headlight cracked by a rock, didnt have the money to replace with the 2k2-2k3 OEM housings, so I figured I'd give the infamous ebay's a shot.
Light output is not great, but with a 6000k kit it lights up the road better than the stock halogen. I won't get into the discussion of useable light vs. non-useable light and glare, all I'm gonna say is that it lights up the road better than halogen.
I have occasional fogging in one of the lights. Fitment was terrible, as I could not manage to get the stock headlight clips to snap into the ebay housings. I did eventually secure them with less orthodox methods.
Overall, for the low cost, I am pleased with the lights...after installing HID kits. I personally don't like the look of the projector halos because the smaller outside circle makes the car look goofy to me.
My sig shows the 6000k lights with LED's in the parking lights. They appear slightly more blue in the pic compared to in-person.
My light setup just before my retro projectors were the non-projector ebay halos w/ an ebay 6000k kit. Sure, I've seen hid setups that give off worse glare than this setup, but glare is not a good thing.
You want a light setup w/ minimal glare, and controlled (mostly) light patterns.
Healthy bright light is one thing...glare = bad
Agreed. These lights do a much better job than the stockies, and for the price it's not a bad upgrade as well. The modeled design after the 5.5 lights mean the look better too.
