Harmonic Balancer
Old 06-14-2010, 02:40 PM
FanaticMadMax's Avatar
Harmonic Balancer
Just have question regarding to the Harmonic balancer, has anyone replace it before on your own, did you have to drop engine to get to it, or you can easily do it from removing the Passenger side tire and work from there? Also wondered if the Crank Position Sensor is that located behind the harmonic balancer?
FanaticMadMax is offline
Old 06-14-2010, 03:31 PM
maxboy325's Avatar
The VQ is internally balanced. It does not use one.
maxboy325 is offline
Old 06-14-2010, 03:46 PM
P. Samson's Avatar
I believe that there is elastomer (rubber) between the crankshaft pulley's center "hub" and the outer part of the pulley, but it is NOT a harmonic balancer. As we've seen on this forum in the past is there a visible wobble of the pulley? Why are you concerned? The Gen. 5 cars have the crank position sensor (REF) located adjacent to the crank pulley, but you can remove it without disturbing the crank pulley.
P. Samson is offline
Old 06-14-2010, 07:25 PM
2slow's Avatar
I think you're looking for these:
http://www.greghome.com/Greg%27s%20G...e%20Pulley.htm
http://www.greghome.com/Greg%27s%20G...xSE/2K2UDP.htm
2slow is offline
Matt93SE
05-24-2019 02:58 PM
dcam0326
09-08-2015 11:02 PM
02nissmax
09-05-2015 01:50 PM
raffivegas
08-23-2015 09:54 PM
Quick Reply: Harmonic Balancer
