Replacing MAF have a few questions
So I took my car to the shop bc it was stalling at red lights. They cleaned the MAF and it is much better, but still stalls every once and while.
I want to buy a new MAF and I understand that I should get the 00-01 for durability and price.
Do I need to get one with the housing or just the sensor?
Is this what I am looking for? If not can somebody point me in the right direction.
http://cpwstore.carpartswholesale.co...EPI316701.html
Also, I read that I need to swap the IAT resistor. I dont understand what this is. Is it the little metal wire on the MAF? If my MAF is damaged do I need to buy a new IAT resistor for the 00-01 MAF?
Thanks in advance for you help, I searched this but can't find a clear answer so I hope somebody else has done this swap and can explain it better for me.
Hey, glad to hear you at least figured out what was wrong after that huge string of bad luck. I'll have to come up to the strip in Calgary one of these days... IF I can get my tranny working right. I'm replacing my solenoid pack to try to fix the 1-2 flare/slip... If that doesn't work I'll have to get a used tranny sometime. This is soooo annoying! With the money I've spent trying to diagnose the problem and on the solenoid pack, I could have bought a VAFC II and LC-1 wideband!!! Gah. Car problems can be so frustrating!
All I know is my Maxima had the same problem and I just bought the MAF sensor (w/o housing) and replaced it myself. It solved my stalling issue and my fuel efficiency has increased a lot. But I've heard from some sources that it needs to be taken to a dealer to reset the ECM which I haven't done. Idk about the resistor but I hope I've helped a bit.
I'm waiting on my new MAF. I might replace the entire housing so I can have a clean MAF Housing Screen Call me picky, and I know it's probably not so dirty as to be hindering airflow, but every little bit helps! I think it'd bug me knowing I have a clean screen sitting there and not installing it when it's really not that difficult.
It's not worth for even 5 minutes to change out the MAF tube, but do whatever fits your fancy.
vingodine
45
05-21-2016 12:46 PM
95Maxi
08-29-2015 09:38 PM
