Oxygen sensor help
Old 10-05-2011, 03:51 PM
cmax1's Avatar
Oxygen sensor help
I did a search on oxygen sensor and 02 sensor and it said that no threads could be found.. I find that odd being this has to be one of many hot topics in the 5th gen forum..
I just need to know is there a difference between the primary and secondary sensor, also what brand is a good one to go with? I was looking around on ebay and i seen a few so has anyone had good luck with those..
cmax1 is offline
Old 10-05-2011, 03:59 PM
BigLou55's Avatar
you didn't search for long if you didnt find any...go to google type in oxygen sensor _____(your year goes there) maxima and I guarantee these forums will show up along with others....good hunting my friend
BigLou55 is offline
Old 10-05-2011, 04:01 PM
Gizm0's Avatar
Yeah, there is a problem with the search engine on this forum right now. All my searches come blank too...
Gizm0 is offline
Old 10-05-2011, 04:24 PM
tetete's Avatar
me too,
I search for idle or rough or start in titles come back no result
tetete is offline
Old 10-05-2011, 04:55 PM
cmax1's Avatar
would you guys say that o2 sensors are "if they are not broke, dont fix them" type items? i got a code for just one of the sensors but i figured since i had the precats off to just change all of them..
cmax1 is offline
Old 10-05-2011, 05:35 PM
HotshotVQ35's Avatar
i would change only the one thats bad and go with oem. i forget how much, but they are over 100 bux a piece, so if it aint broke, dont fix it!
HotshotVQ35 is offline
Old 10-06-2011, 06:28 AM
dot dot dot ...
NmexMAX's Avatar
137.xx, no bueno.
NmexMAX is offline
Old 10-06-2011, 07:14 PM
Montego Murph's Avatar
Did you try OxygenSensors.com? I bought all mine there and they are great. Good prices and plug-and-play replacements.
As for the "all or just the broken," I replaced mine as the codes went off, however I think I ended up replacing them all within a 9-month period.
Montego Murph is offline
Old 08-29-2014, 07:58 PM
egali045's Avatar
Did you use some sort of special tool or with what?
egali045 is offline
Old 09-01-2014, 11:37 AM
maxiiiboy's Avatar
My experience with O2 sensor "failures"
I would not rush into a replacement. I suggest you:
  • Disconnect the battery overnight.
  • Optionally, clean the "engine ground" contacts.
This is how I fixed my problem (codes p0138, p0139, and p0430, but the car was running just fine).
I was about to order a replacement sensor when I received this advice. After an overnight disconnect, all by codes and CEL light went away and never came back.
background/reasons: It seems that the thresholds for triggering the codes/CEL are too tight (like 5%), with the result that the ECU may indicate a malfunction when in reality, nothing is wrong.
maxiiiboy is offline
TallTom
50
07-08-2022 09:54 AM
my03maxima
04-29-2020 12:48 AM
Kyle Lee Cleveland
09-28-2015 09:01 PM
Quick Reply: Oxygen sensor help
