so much rust underneath (pics inside) - is this the norm?
Old 04-26-2010, 09:21 PM
no more maxima...
kingrukus's Avatar
Well I did an actual inspection of my car today. It was the first time I actually was able to go and really look at it in a few weeks since I purchased it - i never really had a chance to look at it before.
Anyhow, the car seems very rusty underneath, rustier than I remember my 4th or 5th gen being (then again age is one of the largest determining factors here).
Is the rust in these pics excessive? I am considering getting rid of this car. When I initially looked at it, I spent at most 10 minutes looking at it and driving it before I decided to pay for it. I just need this piece of junk to last me for 2-3 years, at which point I plan to push it over scarborough bluffs.
I am thinking that I should have stuck to my original plan of buying an 04+ Acura TL 6speed instead.
kingrukus is offline
Old 04-26-2010, 09:25 PM
CraigSE's Avatar
For sure, 100% the flash on the camera makes that look worse than it is... It's all surface rust... About what you'd expect on a 5th gen of almost 10 years of age.
my 2002 doesn't look much different (a little less) But nothing is perforating. It's all just surface rust.
CraigSE is offline
Old 04-26-2010, 09:29 PM
no more maxima...
kingrukus's Avatar
I am considering taking a drill, a wire-wheel, and taking off as much of the the surface rust as possible. Then will coat in POR-15, followed by rubberized undercoat where necessary and finally bring it to Krown for an oil underspray.
Old 04-26-2010, 09:33 PM
CraigSE's Avatar
Sounds like a good plan buddy.... KROWN Is the best there is.. I've had my cars done with it before.... Great product. If you do what you plan, and get it Krown'd every year, you'll be golden.
Make sure you pay most attention to the rear wheel wells though. You probably already know that is a very common problem area.
CraigSE is offline
Old 04-26-2010, 09:42 PM
no more maxima...
kingrukus's Avatar
Yeah the rear wheel lip is a terrible location too. I plan on doing the Squrrel82 fix of opening the folds, sanding down, covering in POR-15, closing the seam, using seam sealer, and paint.
Old 04-26-2010, 09:50 PM
CraigSE's Avatar
I'll probably do that this year too.. I'm also hoping to not have to drive my 2k2 in the winter next year and in the future (If I still have it)
CraigSE is offline
Old 04-26-2010, 10:16 PM
colombian4u_61's Avatar
looks way better than my car LOL
colombian4u_61 is offline
Old 04-26-2010, 10:43 PM
JustinXtlr's Avatar
dammmnnnnn, my 2k max isnt anything like this. Maybe it is cause im from the south "yall". lol
JustinXtlr is offline
Old 04-26-2010, 11:48 PM
navigator82's Avatar
i dont look so bad ... when i buy mine it was really bad... just do your homework and enjoy your car
navigator82 is offline
Old 04-27-2010, 05:01 AM
jeff5347's Avatar
Hey King, mine has some good amount of surface rust to. The harder metal such as the trailing arms, rearend and such have started to rust under the paint so it chips off in those big flakes. I dont think the Japanese cars are made with the best metal or sealed up great where 2 sheets of metal meet. Ive been under German cars such as BMWs that have years and winters on them and they dont look half as bad. I gotta clean mine and paint it up. Mine doest look like yours in the front, the arms bolted to the frame for the control arms are still silver, but the rear is a different story. My oil pan is BAD to. Def need to take off and clean or get a new one.
jeff5347 is offline
Old 04-27-2010, 05:57 AM
2slow's Avatar
I don't see anything beyond surface rust which is normal for a 7+ year old car used in snow/salt. I would doubt you'd find many other vehicles in significantly better shape used under similar conditions over the same period (excluding DeLoreans and galvanized cars).
2slow is offline
Old 04-27-2010, 07:54 AM
BlackHawk3G's Avatar
That's not that bad, u should see the 2002wrx I was looking to buy until I looked under the thing
0_0 what I looked like after seeing that.
BlackHawk3G is offline
Old 04-27-2010, 08:33 AM
Rochester's Avatar
It can be very depressing seeing all that rust underneath. That's why reading comments like that are so supportive:
And Craig is spot-on about what a camera's flash can do to highlight the surface rust and make it look insanely fugly.
If you're still really concerned, the opinion you need is that of a trusted mechanic after he gets it up on the lift and analyzes the situation. Personally, I'm with 2slow on this assessment: looks normal, and nothing to be worried about.
Rochester is offline
Old 04-27-2010, 09:20 AM
Toolie
knight_yyz's Avatar
POR 15 stands for Paint over Rust, so all you have to do is buy there metal ready spray, and Paint Over the Rust. Wire wheeling all that rust will take you months.
Metal ready from POR eliminates the rust, adds a thin layer of zinc phosphate to the surface and etches the metal for the POR 15. much easier to do.
http://www.por15.com/METAL-READY/productinfo/MRG/
knight_yyz is offline
Old 04-28-2010, 08:30 AM
nzelinsky's Avatar
That rust isnt bad at all. Trust me my car has more than that underneath I can guarantee it
nzelinsky is offline
Old 04-29-2010, 06:16 AM
MatMax01's Avatar
My 2k1 has just as much rust as yours and I wash it all the time to get the road dirt and salt off. I live the the north and winters are rough and the salt will get everywhere. But if you only want the car to last 2-3 years then just drive it.. Putting POR-15 won't make it go any faster or run any better. Put you money/time in changing out all you fluids, change plugs, and cleaning the MAF and TB like I just did this past week. This will make the car more enjoyable to drive and you will forget about what is underneath.
MatMax01 is offline
Old 04-29-2010, 08:51 AM
Rods03Max619's Avatar
Yeah that is DAMN I dont have none of that but I guess its because it's really really cold where they are or Snowing cause DAMN but in Cali. only rains a little in San Dieg
Rods03Max619 is offline
Old 04-29-2010, 09:01 AM
MONTE 01&97 SE's Avatar
Well its a combination of the snow,ice, salt etc etc, those of living in S.Cal or the South etc should not have this issue. My car doesn't have any rust except for where the parts are welded together.
MONTE 01&97 SE is offline
Old 04-29-2010, 03:41 PM
You embarrass me.
zero2sixtyZ's Avatar
The area you should be looking after is the subframe and radiator support.
zero2sixtyZ is offline
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
06-06-2017 02:01 PM
doctorpullit
03-29-2016 11:08 AM
uttadms31
09-30-2015 05:24 AM
Quick Reply: so much rust underneath (pics inside) - is this the norm?
