Post pics of your 5th gen with other gen/model OEM Nissan/Infiniti Wheels
#41
#42
#47
#55
2002 with 18" Murano
Here's my 2002 with 2006 Murano 18's wrapped in 245-45-18
http://forums.maxima.org/album.php?a...0&ref=gnr-prev
#62
#66
#67
#68
#69
Lateral beam tends to slide to one side when being lowered the tdmi adjustable TQ link fixes that because I had the same issue with my 19" Rays and when I put it on it was gone no more rubbing after a while I did change the tires of course
#70
But did the TDMI actually fix it or was it the change of tires?
#71
sounds like NMEX's issue has to do with how the beam slides when hitting a bump. He would have to off center it so that when he hits a bump it slides to the center. That, or roll the fenders and trim that flange that hangs out in the fender well that loves to scrape tires
#73
you can fix that without buying anything also, and its a pretty simple task
But, even when sitting in the garage, you can see one side sitting out a bit further than the other side. Maybe I can get funky and use a 5mm on one side and 10mm on the other.
#75
Flanker84 ! love the wheels they are awesome!
yes I did this difference on the rear it looks and works fine.
5mm one side, 20mm other
235/45/18 18x7.5 3mm
and I am sure you know this but making sure, did you grind your tabs at the quarter where it meets the bumper? This helped my "one sided" rubbing before anything else did.
I decided to roll the fenders, or modify them to whatever works. Whenever time permits. It only rubs with a passenger or cargo, and obviously with both.
#76
Finkle
09-27-2015 09:53 PM
ViciousVQ30
08-05-2015 05:40 PM
