Cooling Fans
Cooling Fans
I am hoping you guys can help me out a little. I have a 2002 Altima 3.5 SE and the cooling fans are nearly always on. The car does not over heat and the coolant level is where it should be. It just doesn't seem like they should be running that much. It doesn't matter if I am in the city or highway, they just always run. Any ideas?
Get yourself an infrared thermometer and measure the temperature before and after t-stat. If your fans are on constantly, then there is a chance they are being commanded to do so.
I had this same thing happen to a 2000 maxima after doing the water pump. It was just low on coolant. It did not overheat, but I'm guessing the water control valve saw lack of flow and turned the fans on full speed.
MaxJay, any update on this? Are both your cooling fans still working almost all the time? What was the solution, if you did solve it?
I have a similar issue; when my fans operate, they both come on at the same time, regardless of whether I'm using the A/C or not. It is a new fan assembly (same brand and model as the one before), but I don't remember the previous one behaving that way.
tarun900
19
12-20-2021 06:57 PM
magiconthetire
10-26-2015 09:03 PM
