Tranny/Valve Body...I need advice
5.5AT, ~90k miles.
I started getting the flaring from 2-3 about 3 months ago. In case you've never heard of this problem, the tranny would release 2nd, flare up ~500rpms(not slipping), then catch 3rd. If I let off the gas, then it wouldnt flare up and would catch 3rd. I ordered a used TCM which made no difference.
This weekend I pulled the VB and installed a Trans-go modded VB with BRAND NEW solenoids. I take it for a test drive and it doesnt want to shift out of 1st until ~5k RPMs. Once 2nd comes around, i can rev it all the way to redline and it wont catch 3rd. I got so frustrated I called it a day, only to return the next morning.
The next day I drop the modded VB, installed the OEM VB I originally pulled out and installed the NEW solenoids. Take it for a test drive and its better, but its having a hard time shifting to 3rd.
Has anyone ever encountered this? My plan tonight is to test the solenoids. I have 4 sets so hopefully I can find a working combinations. Also, when i dropped the VB I didnt unplug the battery before I took it for a test drive. I wouldnt think this would have an effect on the way it shifts but i'm open to try anything now.
I'm getting sick of the 1.5-2 hour ordeals only for it not to fix the problem. Any help is appreciated.
5.5AT, ~90k miles.
Why do you have so many solenoids if you do in fact have 4 sets?
Make sure all the o-rings are seated properly. Once I reinstalled a VB and it wouldn't get out of 1st, reinstalled, 2-3 would slip like no one's business.
Finally got it right after a few tries (install/reinstall).
Wow Russ! That's alot to go through, you've been dealing with this for a while now. Maybe Mike is right, and it's just a matter of getting the install perfectly seated after a few tries.
Can you do me a favor and verify which style of VB you have and also your build date.
Is yours like this
or like this?
This ? stemmed from this.
http://forums.maxima.org/7518612-post2290.html
So i swapped out my VB....again.
Before I did this, I tested the resistance and the operation of the shift solenoids themselves. I had my brand new solenoid kit @ 2 'old' kits lying in front of me, 3 total. The resistance of all the new solenoids came back within spec. The operation, however, came back with strange results. I tested the operation of each solenoid per the FSM instructions. 4 of the 5 solenoids worked, no problem. The last solenoid I tested, solenoid A, did not make a sound. I then tested the 2 old kits. They came back with the same results. What are the chances that ALL 3 solenoid kits have the same problem?
With the results being similar, and me running out of options, I made sure everything was seated and bolted as necessary. I just got in from a test drive. The car will NOT shift into 3rd. I'm at a loss, looks like its time for a new tranny.
The 2-3 flare is a valve body issue, not usually a solenoid issue. Not so sure I would have touched the solenoids if I was just doing a shift kit assuming the transmission was otherwise working properly.
I'd also check to make sure the TPS is properly adjusted, that can also cause shifting issues if out of adjustment.
How do we adjust that? There are 4 total (for the pedal, APPS1 & 2 / for the throttle body TPS 1 & 2). If they're not within a certain voltage range, hellloo limp mode
something else worth noting...
After I completed the swap, I started the car in neutral while on the stands. I look at my front wheels and they are spinning, not fast i'd say maybe <5mph. I try to stop it with my hand, and it doesnt.
With that said...any idea wtf would cause that?
When I had my Accord, I could adjust shift feel by adjusting the cable that ran from the throttle body to the transmission. By shorting the cable a bit (which would add tension to the lever on the transmission) I could make my car shift harder. Half throttle and up it would chirp the tires on the 1-2 shift.
Just make sure everything is in the range they are supposed to be in. Not sure how to actually adjust it if something is out of whack. Just another reason throttle cables > DBW.
If it's out of whack on these, it will run into limp mode, and that is painfully obvious.
do any of you guys know which valves internal to the VB control the 3rd gear shift? I think one of them is stuck. The strange part is i never had a problem (other than the 2-3 flare) shifting into 3rd. As it stands now, it still wont shift into 3rd. If I give it almost full throttle, it acts likes its about to shift but revs like in neutral.
TIA
TIA
My bad, you want actual valves and check *****? After briefly looking over the FSM I didnt see exactly which valves or check ***** control 3rd gear. Check your Transgo instructions.
I have tried 2 different sets of solenoids, both having the same issues. The only thing I could think of is the TCM not telling to work properly. I have my old TCM that i'll switch out so this will be my final attempt before I buy another tranny. For those keeping up with this...it'll be #3.
Thanks for replying. I have pretty much the same issue right now. Although my circumstances a little different. I have a 1998 GLE. I finished a FULL VQ35 swap about a month ago. Discovered transmission shift problems since first test drive. Turn on the car and start driving everything shifts properly, until the very first brake. After that LIMP mode with your symptoms. Car stuck in 2d, or sometimes stuck in 3d. I have been checking everything thinking that maybe my wiring is not right but could not find any problem there. Found your post yesterday. Very helpful. Thank you for the info. Going to take it to the dealer for CONSULT diagnostics next week to confirm my suspicions.
Do you mind telling where did you source the new transmission?
Thanks,
Mike
Thanks,
Mike
I got it from car-part.com there was a local junkyard that had a few in stock, with the 5k miles one being the lowest. Here's the best part, it was $375 delivered to my house.
Good luck man, the auto trannies suck.
Vastmax,
Does the current trans have the transgo kit in it?
I have read a couple .org members who seem to have experienced failure after the install recently. Already bought the shift kit, Trying to decide if its worth installing
THX
THX
