7th gen vq in a 5.5?
Old 11-17-2010, 02:47 PM
madcatz8489's Avatar
hey been out of the scene for awhile. basically my 5.5 6mt broke down two years ago...the piston rings were shot, now im finally at that point where i have moneys to fix my baby. But i dont want to buy another old vq.....has anyone heard of putting the new 7th gen vq into a 5.5??? if its possible i think it would be worth putting out the extra cash for a new motor. Any info would be greatly appreciated! TIA.
madcatz8489 is offline
Old 11-17-2010, 02:54 PM
Grand_hustle17's Avatar
2 years to do a motor swap??? damn!... really tuff times... essential said some guys in Florida did this swap before, and according to what he was saying it wasnt much a difference... i was thinking of doing the samething... 7th gen motor offers more than just performance... i say go for it bro man
Grand_hustle17 is offline
Old 11-17-2010, 02:59 PM
do you have a link to that forum or thread so i can read up on it, even possibly communicate with them?
ya the worst two years of my life...AND i had just finished modding it dropped bout 3k right before it died... im really interested in this but im wondering will there be a problem with the motor working with the 5.5 6mt?? and would i have to change my ecu? If i can get some good info i will definetly go this route
Old 11-17-2010, 03:08 PM
ajcool2's Avatar
Here you go.
http://forums.maxima.org/all-motor/6...vq37-swap.html
ajcool2 is offline
Old 11-17-2010, 03:27 PM
My axles cry for mercy...
essential1's Avatar
4th gen. But you get the idea.
essential1 is offline
Old 11-17-2010, 04:36 PM
possible
Old 11-17-2010, 09:43 PM
MIKERNM1990's Avatar
Im undecide which is best Old Aluminium IM or New Plastic IM?
MIKERNM1990 is offline
Old 11-17-2010, 10:14 PM
Unklejoe's Avatar
The plastic intake of the newer VQ's is better, assuming the VIAS can be properly controlled. I have a couple of questions:
1. Does the 07+ Altima VQ35 have variable exhaust timing?
2. Is that a 2007+ Altima engine or a 2009+ Maxima engine?
3. Both the 07+ Altima and 09+ Maxima have the newer HR valve train correct?
4. If it does have exhaust cam timing, what can be done to run it properly on the 5.5 ECU?
5. Is the crank position sensor location the same between all VQ's?
Thanks.
Unklejoe is offline
Old 11-17-2010, 11:37 PM
CMax03's Avatar
No, it's not 2 years to do a swap! It's 2 years for the man to save $$$$$$! Hell yours has been down probably longer than that if you add up all your downtime with those multiple transmission changes.......I wonder if that swap would be worth it......I would go a different route Madcatz but you don't have anything to lose either!
I thought you wrecked it honestly.........
CMax03 is offline
Old 11-18-2010, 05:36 AM
essential1's Avatar
It doesnt matter which one is better or not. You cannot put that IM on your 1st gen VQ35. Or visa versa.
Thanks.
1. If i'm not mistaken, yes it does have variable exhaust cam timing. But dont quote me on that. Either way, This was done using 3.0 timing components.
2. The place he got the motor from get's all his motors from japan and claims that it came out of an "08 maxima". But we all know that the 08 maxima still had the older stlye VQ35 still so chances are, it came out of an altima. Most people who arent into nissans can tell the difference between the 2 anyways.
3. I dont wanna go as far as saying that it surley is exactly the HR valvtrain, but it is deffinately similar to the HR in alot of aspects. Most notibaly the head design.
4. This is outside of my relm of knowlege, but I would guess V-manage maybe?
5. I never checked where the CPS was on this one when they had the motor out, but if I had to guess, i'd say yes. Check with a FSM to verify though.
As far as how the engine performs with the 4th gen timing components goes, it's not that impressive at all. 1st gen VQ35 swaps are significantly faster than this one in a heads up race. But when dynod in the altima chassis w/ the 6 speed, they put down some impressive numbers with minor mods. So based on that, i would say that it's not worth it unless you do a full harness and ECU swap if you're going for an increase in power. But again, this is on a 4th gen chassis, so take it how you want it.
Old 11-19-2010, 04:05 AM
This upcoming march makes 2yrs since I've owned this car sooooo chill with the exaggeration.... mines was down a total of 7months and not because of $$$ or whatnot, I just had an installer that procrastinated 4 of the 6months it was down.................
Old 11-19-2010, 05:13 AM
BlackMacks's Avatar
I can't help you with any of those other questions, but I can definitively answer #5: NO, the CKPS is not in the same spot for all VQ's. The VQ35 from the '08 Quest that I put in my car earlier this year had the CKPS mounted at the 6 o'clock position on the block, whereas as we all know, the CKPS on the 02-03 VQ35 is mounted at roughly the 3 o'clock position.
Boy my ignorance to that "subtle" little difference kicked my *** for months.....
BlackMacks is offline
MAXSE5SPD
09-17-2022 04:00 AM
thatcollegestudent
18
10-05-2015 02:29 PM
hot04
09-18-2015 06:14 AM
ik95
09-16-2015 08:11 PM
Quick Reply: 7th gen vq in a 5.5?
