Carbon Fiber Trunk Catapult
So here's the deal. A got a cf trunk over a year ago and ever since installing it, I had to tie it down with bungee cords so that it wouldn't fling up so violently and almost break my rear window and maybe even rip the trunk from the latches. If a small cat were to sit on my trunk I could launch it at least 20 feet just by popping my trunk. Its that bad. So any body have any ideas on how to control how fast the trunk opens instead of replacing ripped bungee cords every month?
Like other guy said, you'll probably need some weights to counter-balance the mechanism that opens the trunk. It was designed with the factory trunk in mind. Nissan didn't intend for anyone to replace it with a much lighter trunk cover.
Maybe you could try removing the trunk torsion bars? This is for a 4th gen, but the 5th gen shouldn't be too different. (http://www.diymobileaudio.com/forum/...97-maxima.html)
And I would like to see pics/vids of said cat catapult.
And I've tried removing the torsion bars, but then the exact opposite happened, the trunk wanted to shut. So after catapulting the cat, I could chop its head off.
Oh, and weights, defeat the purpose of a cf trunk like Unklejoe said.
you really think the 20-40 lbs you "saved" really makes the car that much faster or quicker...trust me...it takes about 100-150lbs for us to see 0.1s off the 1/4 times on the N/a application.
Admit it....the trunk is for aesthetic purposes and add the little bit of weight.
btw the idea of the torsion bars was so our trunks popped open on their own but it never worked even from the factory as far as I know, so be happy that you are a maxima that has a self popping trunk
Alright maybe you're right. It is only for looks haha but still I'd rather not add weight. But as of now it looks like its that, or someone's dead cat.
Yeah, they also didn't intend for anyone to add turbos, exhausts, wheels, cf hoods, and all the other crap we do to our cars either haha.
Loose the front seats (fully loaded airbag, heated and leather weighs roughly 75-100lbs) sit on egg crates
I don't even know where you'd mount those in the trunk considering our trunks are on a u-shaped bracket.
IIRC, the trunk rods are different on the 3rd gens between those that came from the factory with a spoiler vs those that did not. So, which was your trunk originally from the factory...spoiler or none? It may be worth checking to see if the rods are different on a fifth gen Max.
If they are, and you originally had an oem spoiler, then you could try swapping out the trunk rods for those out of a non-factory spoiler trunk lid.
Just a thought.
Just a thought.
I would guess you mount one end to the trunk hinge and the other to the bottom of the rear deck.
Mount one end of the damper on the U bracket and the other end on a bracket mounted under the rear deck. Whether it will work or not idk, but its actually pretty simple.
Unless I'm mis-interpreting your mounting points.
I mean, I can see where you and Chris Gregg are coming from, but I can also see the damper getting caught on the lower lip of the rear window. Mainly because our trunks sort of "roll" up instead of opening on a hinge, if that makes any sense.
i did a bracket in mine and mounted the shock that i added to the rear support arm. It pivots on the one end and causes no issue.
My problem comes from all of the deadening, and i think youd continue to launch with 2 shocks, but one you should be fine. just install an L bracket on one side and mount to the rear deck. Youll be fine.
REDinLV
10-18-2015 05:31 AM
KabirUTA13
19
10-17-2015 02:15 AM
zzznightmarezz
09-21-2015 06:32 PM
