Finally figured out front-end clunk!
I took my 2000 SE to my mechanic today and he replaced front sway-bar stabilizer links for me. Didn't feel like doing any work myself this time. My infamous front end clunk over bumps is finally gone! Hope maybe this will help some of you guys with this front end clunk problem.
I have the clunk too. Ging to replace the suspension and the strut mounts which I think is the culprit but if not ill do the links. Awesome stuff man, glad you figured it out and thanks for postin up
Now when you say "clunking," do you mean the deep banging in the front end that makes you think your cars going to fall apart? and the severity and noise of the clunking depends on how effed up the road is? lol
dont do it. i had both front struts replaced and it didnt do anything. i was pissed
I had this problem. Lots of noise up there. I replaced everything short of the rack. Struts, swaybar links, ball joints, and inner and outer tierods. I found driverside ball joint had some play in it and the passenger side inner tie rod had some play as well.
Car rides and drives very nice now and no front end noise
And while you are in there, you should get some ES swaybar bushings and put them in.
To the OP and the other newbs, try searching next time. There probably 100 threads about front end clunk, and the MOOG endlinks are mentioned in everyone of them.
For those who are not familiar with the end links check out this image from rockauto:
http://bit.ly/9AJklo
oh yes! i've been so depressed with the clunking noises making me feel my cars going to fall apart that i was thinking of selling it! i had replaced struts and strut mounts, but nothing changed. i hope this fixes the noise for me too!
Ridiculous! Pep boys quoted me $990 to replace all 4 struts... screw that, I picked up a lightly used set of Tein SS' for $975 and a friend is willing to install them. Much better.
Definitely try the sway bar links first. Get the moog end links from Rockauto.com. They are about $15 each. Its a lot less expensive than suspension and/or mounts and fairly easy to replace (unless the nuts are rusted on there good).
I'd like to see that as well. I was thinking about buying a set of ES FSB bushings, but when I was under the car doing an oil change I looked around and could not even see the stabilizer bar bushings, let alone figure out how to change them.
My car has always had the infamous "front end clunk". For the last 4+ years I've just lived with it as after I replaced the struts, I guess I just didn't care anymore. I'm now to the point though that I want to finally fix this problem for good. I got under the car and felt every joint I could. Ball joints, tie rod ends, stabilizer bar links, basically anything that moves. The only joint I could move by hand were the stabilizer bar links. They felt loose to me, that is they easily moved side to side but not up and down. All other joints had no play at all no matter how hard I tried to move them. Does this mean that the stabilizer links are shot, or is this normal?
Can't answer your question for sure, kbo, but I would say risking $30 + shipping is not really a risk at all! The end-links will go bad, eventually, so if you replace them and the clunk is still there, well, that just helped you narrow down the list of culprits (on to the engine mounts..!).
I keep forgetting that those grease-able links are so cheap! Two $15 parts and the scary "I AM GOING TO EXPLODE ON THIS PAVEMENT" noise goes away? Yes, please. I know my engine mounts are shot, though, and am dreading the removal and pressing process. Sigh. Maybe fixing the clunk will help cheer me up enough to engage in 12 hours labor to pop out those shredded suckers.
To answer your guestion... Yes, it is normal for the link to 'twist' when there is no load on them. However with the amounts of load throughout suspension components, being able to move them by hand really isn't the best way to determine if the sway bar links need to be replaced. A visual inspection is better, but even then it helps to have previously seen worn out sway bar links so you know what to look for. Usually on higher mileage vehicles the sway bar links and bushings get replaced first because they are cake to change, fairly cheap, and often the first suspension component to wear out. I say change them if they have high mileage or you live in an area with dilapidated roads.
Order up! Link from the 5th gen stickys. It's for the sway bar bushings, but you'll also see a picture of the sway bar links(photo showing where to place the jack). The links are pretty straight-forward once you see them. Note: Don't forget a preemptive spray of PB Blaster before you attempt to remove the hardware on the links.
Also check the stabilizer bar bushings where it attaches to the subframe.
I replaced those on my dads' 2K and it totally solved his front end clunk. End links didnt even need replacing.
For those of you who are still searching for the clunk....
Sway Bar Bushings
All,
I too have this slight knocking noise going on in the front right side of my 2000 Maxima. I had a lot of front end work done including my subframe and new end links. One of the things not replaced were the sway bar bushings. The noise has gone down a lot but is still lingering. The mechanice that did the work ended up putting in Duralast end links. Had I read these threads before hand I would have requested he put in Moog end links. That being said can someone answer these 2 questions for me:
1. Should I replace the newly replaced Duralast end links with Moog end links since they are highly recommended?
2. Could it be that I simply need to replace my sway bar bushings? Could those be causing the little noise thats left?
Any response would be greatly appreciated.
All,
again swap out the sway bar bushings with some from energy suspension first. that seems to be the noise maker!!
06-06-2017 02:01 PM
Unclejunebug
04-02-2016 05:42 AM
fx4five
10-18-2015 06:57 PM
