Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 02-22-2010, 12:21 PM   #1
2000 Nissan Maxima GLE Transmission Replacement
As some of you know, I purchased a 2000 Nissan Maxima GLE with a blown transmission for $500. Other than the transmission, the car is in perfect condition (Interior / Exterior).
On a more related note, I just bought a replacement transmission from a junkyard for $500. The Transmission has approximately 73,000 miles and is in pretty good shape (No burned smell from the fluid left over in the torque converter) and all the cables / hoses are intact.
Is there any kind of guide or manual to help me along the way? I bought a Chilton's Auto Repair manual for the 92-04 Maxima, but I don't see any kind of transmission replacement in the book. My neighbor has used Chiltons for awhile and they give great tips / advice .. especially for a job as big as this one.
Are there any online guides for this kind of job?
PS: If you've done an automatic transmission replacement by yourself, I'd appreciate if you guys could chime in.
TylerDT is offline   Reply With Quote
Old 02-22-2010, 12:58 PM   #2
Points: 8,576, Level: 62
Points: 8,576, Level: 62 Points: 8,576, Level: 62 Points: 8,576, Level: 62
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
Send a message via AIM to Rood
no 5spd swap??
__________________
Precision injectors 525cc
BBMAF
J Dub bodykit
Profec e01
All for sale
Rood is offline   Reply With Quote
Old 02-22-2010, 02:34 PM   #3
Points: 4,118, Level: 40
Points: 4,118, Level: 40 Points: 4,118, Level: 40 Points: 4,118, Level: 40
Activity: 1.1%
Activity: 1.1% Activity: 1.1% Activity: 1.1%
i'd say it's pretty straightforward.
if you'l be doing it on your back i would suggest a heavy duty jack and jack stands.
the A/T trannys are much heavier than the manuals, so you will need a friend to help out.
i'd start from the bottom, removing the torque converter to flexplate bolts and bell housing bolts 1st, try and do everything under the car 1st, like axles, tq converter bolts etc.
so that way when it's ready to come out, all you would have to do is unbolt the bellhousing from the top and then lower it down ( you can always unbolt it and just let it fall since the tranny is already junk ) .
then have a friend help putting the transmission on the jack and slowly work the new tranny into the engine bay.
i haven't done A/T on my back, only done them at work, but i have done clutches on my back before .
__________________
2000 Maxima SE
www.jiujitsusweep.com For all things jiu jitsu
www.BJJGiMarket.com Slightly used BJJ gear
Amave is offline   Reply With Quote
Old 02-23-2010, 08:10 PM   #4
Quote:
Originally Posted by mrood1986 View Post
no 5spd swap??
Unfortunately, I don't have the money or time to do a 5MT swap.
I really appreciate your advice man. I bought the transmission and since the torque converter is seperate, I'm going to install the newer torque converter in the old transmission and see what happens.
Here's my reasoning;
I basically took it for a drive for a couple miles and here are my impressions. The transmission shifts fine all the way through 1-4, the problem lies when I am at a stand still with the brake on in D, 3, 2, 1, R. When I get going past 5 mph, the sound disappears and as I apply more throttle while I am moving, the belt sander sound comes up.
I tried a test where you put the brake / gas on at the same time (it really works the torque converter), the sound changes to a higher / faster spinning sound ..
Here's my concern: If the torque converter is damaged, doesn't it throw debris into the transmission itself?
Old 02-24-2010, 02:33 AM   #5
Activity: 1.1%
why not just install the newer trans? it's a hell of alot of work to just replace the torque converter w/o knowing exactly what the problem is.
__________________
2000 Maxima SE
Old 02-25-2010, 10:02 AM   #6
(off topic)
-I've sent you a PM
20th01 is offline   Reply With Quote
Old 05-31-2012, 09:12 PM   #7
Points: 349, Level: 6
Points: 349, Level: 6 Points: 349, Level: 6 Points: 349, Level: 6
Activity: 0.3%
Activity: 0.3% Activity: 0.3% Activity: 0.3%
Hi TylerDT,
I'd love to hear the diagnosis and cure! Was it only the TC? My 99 is doing the exact same thing! (same transmission I believe... RE4F04A)
Thank you!
Regards//KP
KP11520 is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
