03 Maxima not staying started
Alright, so this is a long story.. I had to change the clutch and the crankcase main seal on my 03 Maxima 3.5L V6 6 speed manual. That all went fine. We slammed the ***** back together and go to start it, and it only stays started when the throttle is floored at only about 300 rpm. Checked spark plugs, grounds, pinched fuel lines, blown fuses, MAF, and fuel rail is still getting fuel at a good pressure. We ran codes but we only got one that was P0462, which is a fuel level sensor A low circuit input, but we figure that that only came up because my cluster is ****ed and the fuel guage always reads full and speedo is ****ed. I'm fresh out of ideas and just need help.
I personally would look at this way, if the car ran fine before you did these jobs then maybe you may have overlooked putting flywheel on right. Not saying you did but I would go over everything that you did once more very carefully and if it's still not running then I would check the flywheel. I know it sucks but what can you do. I guess you could have a fuel pump or something related to fuel issue but if it wasn't giving you a problem before the clutch then I wouldn't think it would just show up now.
If this is an 03 then you should have a electronic throttle body on your motor, Mabye there is an loose wire from the throttle to the pedal or the motor in the TB died. If you have access to a diagnostic scanner, check out the throttle percentage and see if the % goes up as you hold the gas( car doesn't have to be running, just acc2)
Check this out hope it helps https://maxima.org/forums/5th-genera...a-02-03-a.html
I think you're trying to look for a problem when you already know what the real one is. Did you recheck the flywheel yet? Cause the ecu reset and various relearns won't stop the car from running. It might not run right but usually it would still run. On top of that you weren't really sure which hole was the dowel pin hole to begin with were you?
Yea it sucks to have to take everything apart again. There should've been one hole like in the pictures in the other thread that's different than all the other ones. That's the dowel pin hole. In the other thread you can see the picture there's a hole that's different than the rest. That's should be the dowel pin hole.
Did your gauges get straightened out? Mine have gone wacky too, only it's all of them.
I'm having deja-vu right about now brother. Going through the same sh#t myself. My car runs and is driveable so I'm pretty sure I have the flywheel out of position by one hole on the crank flange. I will be making time to fix this soon but the question I really want the answer to ...
Sadly no. At least not yet. We snapped the bolt for the main ground to the trans last night and have to go buy one somewhere. But I don't think that's the problem. I'm pretty sure it's just the whole cluster is screwed. Because even the odo only clicks a km about once every 3 km travelled. And after changing all this crap, I don't have the money right now to replace it.
They all work it's just that their start / resting points have been altered somehow.
My odometer is working as it should.
Have you done the self-diagnostic on the cluster?
valerit1
05-19-2016 04:13 PM
ZerotoSixty
29
02-29-2016 05:13 AM
Digital Alchemy
02-26-2016 10:12 AM
