Oil leak problem
Old 01-20-2010, 06:54 AM
str8max's Avatar
Oil leak problem
Well members its been a while since I have posted about this problem..... But I have still have an oil leak problem. This is what I have done so far
1. Cleaned old pan and replace silicone - still leaking
2. Cleaned old pan and replace silicone - still leaking
3. New pan and silicone - still leaking
4. Replaced oil cooler o-ring - still leaking
It leaks when the car is parked and over night I will have a spot the size of a baseball and golf ball.
Any suggestions would great.
str8max is offline
Old 01-20-2010, 07:07 AM
mandyfig's Avatar
You sure it is coming from the oil pan instead of other sources, like the rear main seal?
mandyfig is offline
Old 01-20-2010, 07:25 AM
str8max's Avatar
well its on the side of the oil pan.... i know that doesn't mean much as oil can travel to where ever on the car then drip..... but it pretty consistent.
I have also thought about the oil pressure switch....maybe?
str8max is offline
Old 01-20-2010, 08:41 AM
vastmax's Avatar
rear valve cover?
vastmax is offline
Old 02-27-2010, 10:19 PM
RR5
RR5's Avatar
Can't imagine why this has not been said before, so I'll say it now:
I would clean everything and try to catch the oil leaking red-handed.
RR5 is offline
Old 07-12-2010, 07:02 PM
str8max's Avatar
Ok after a long wait here are some before cleaning and after cleaning pics. Please look and tell me what you think I am still thinking the oil cooler O-ring is bad even after replacing it once. ITS FOR SURE NOT THE UPPER GASKET!!!!!
str8max is offline
Old 07-12-2010, 07:18 PM
2slow's Avatar
Front main seal (although I seem to recall some sort of bronze washer rather than a typical rubber seal). It seems to come from above the oil cooler.
Also, is this coolant hose torn?
2slow is offline
Old 07-12-2010, 07:32 PM
spock's Avatar
Now that it's clean, you have to wait for it to start leaking again. Would hazard an early guess of the front main seal. You should take it for a drive, let it sit for 1/2 an hour and check. Post new pics after the drive.
spock is offline
Old 07-12-2010, 07:37 PM
str8max's Avatar
Its clean right above the cooler
No the hose is not torn
str8max is offline
Old 07-12-2010, 07:45 PM
Grand_hustle17's Avatar
I forgot the name of them but its have you checked the selonoid beside the rear valve cover??? Both of mines was busted and I thought it was the oil pan but it wasn't... no to condole speeding but try flooring the car and see if it smokes at a certain speed... I don't remember what the name of the part is but its like an oil pressure selonoid...
Grand_hustle17 is offline
Old 07-12-2010, 07:48 PM
str8max's Avatar
No it doesn't smoke at all!
str8max is offline
Old 07-12-2010, 08:03 PM
Neither did mines... it only smoked at WOT inn the middle of 3rd... driving regular only had me thinking the oil pan was leaking... anyways check those out
Old 07-13-2010, 06:56 AM
str8max's Avatar
Ok after coming out this morning and looking and this is what I see! everything is dry but the cooler....
So what do you think now?
str8max is offline
Old 07-13-2010, 12:21 PM
Don't you know who I am?
Rydicule's Avatar
I think it's ironic that a 5.5 gen is losing oil through leakage.
Rydicule is offline
Old 07-13-2010, 01:22 PM
Cletus
SoonerFan's Avatar
exactly
SoonerFan is offline
Old 07-13-2010, 02:22 PM
spock's Avatar
Yea, that helps him.
There is an O ring behind the oil cooler. I'd start by removing the cooler to see whats going on. Might get away with just replacing the O ring.
spock is offline
Old 07-13-2010, 03:28 PM
2slow's Avatar
Do this again.
2slow is offline
Old 07-14-2010, 12:56 PM
RR5
RR5's Avatar
For starters I'd pressure wash your engine bay to clean everything, then start the engine and see what starts to leak and where.
RR5 is offline
Old 07-15-2010, 09:31 AM
vastmax's Avatar
Do this again.
x2, make sure you clean all surfaces before reinstalling.
vastmax is offline
Old 07-17-2010, 11:32 AM
str8max's Avatar
OK installed a in oil o-ring and that did the trick....
I removed the old one and it looks like it twisted on installation.... I have to give big ups to a .org member that said to just remove the 2 cooler lines and that made it easy as pie and I lost zero coolant!
Thanks again
str8max is offline
Old 07-19-2010, 12:14 PM
vastmax's Avatar
Thanks again
if you just unbolt the coolant hard line, you dont have to disconnect anything.
vastmax is offline
Old 07-19-2010, 12:56 PM
str8max's Avatar
Yep that's what I did
str8max is offline
Old 07-20-2010, 09:29 AM
mandyfig's Avatar
Oil leak resolved!
mandyfig is offline
Old 07-22-2010, 10:57 PM
dnice02's Avatar
i had that same prob for a month and it drove me crazy. changed the oil cooler o-ring and the leak was gone.
dnice02 is offline
Old 08-06-2010, 10:40 PM
BigBear805's Avatar
Thank god for these forums, I have the same leak! I'll be fixing it soon!
BigBear805 is offline
Old 08-19-2010, 07:07 PM
gdal's Avatar
Mine is leaking at the same spot. How much is this gasket?
gdal is offline
Old 08-20-2010, 06:23 AM
vastmax's Avatar
like $3
vastmax is offline
Old 08-25-2010, 06:15 PM
maxpilot53's Avatar
Is this o-ring behind the part that the filter mounts to? If so, how do you get it off?
maxpilot53 is offline
Old 08-25-2010, 07:30 PM
RR5
RR5's Avatar
Drain oil and optionally the coolant, remove oil filter and remove the bolt the oil filter attaches to. I did it myself no problem, just clean the hell out of everything before reinstall. You also have to disconnect the coolant lines to the oil cooler. Be prepared to catch the coolant.
RR5 is offline
Old 08-26-2010, 03:31 AM
maxpilot53's Avatar
Got it. Thanks!
Old 08-26-2010, 05:31 AM
ghostrider17's Avatar
Originally Posted by SoonerFan
exactly
.....I had a chuckle as well.....
"I love the smell of burnt oil from a VQ in the morning!"
Glad the OP got that fixed....i would have guessed main seal.
Didn't know there was an o-ring at the filter junction.
gr
ghostrider17 is offline
Old 08-26-2010, 08:03 AM
vastmax's Avatar
dont worry about draining or catching any coolant, just unbolt the 2 bolts holding the hardline on.
Also I believe the oil cooler bolt is a 22mm
vastmax is offline
Old 09-03-2010, 11:37 AM
maxpilot53's Avatar
I think mine is leaking here too. Where do you get the o-ring. Dealer says they don't have it.
Old 09-03-2010, 11:29 PM
RR5
RR5's Avatar
Call DaveB at 888-254-6060 mention maxima.org forums to get the discount.
RR5 is offline
Old 09-04-2010, 06:49 AM
chimaxima's Avatar
Thanks str8max,vastmax and all others for this post. I had this leak for some time,no one figured out where the leak was from but because of you guys leak is gone now.
Thanks.
chimaxima is offline
Old 09-10-2010, 06:24 PM
gdal's Avatar
I was told by DaveB that this leak only happens to 3.5 'cause the 3.0 doesn't have an oil cooler.
I have a leak around th same area ... I wonder where this leak is coming from ...
gdal is offline
Old 09-10-2010, 06:38 PM
sascuderi's Avatar
good to know...another reason to love the 3.0!
sascuderi is offline
Old 10-13-2010, 05:40 PM
maxpilot53's Avatar
Just got around to doing my oil cooler o-ring. Pretty easy! As vastmax said, I unbolted the two brackets that hold the coolant hard lines. This gives you enough play to remove the cooler enough tho replace the o-ring without disconnecting the hoses.. What is weird, is that when I went to the dealer, they said they had no listing for the 0-ring. They showed me the picture on their computer and it indicated that they only sold the cooler as a unit for $226. I told him that that was rediculous and that I know from the forum that the part exists. I went home and got the part number from this thread. Called the dealer with the number and he says he has two in stock. I asked how that could be possible, and he tells me that those o-rings are probably used in other vehicles too, but not available for a 2002 Maxima. I said that's either a rip off trying to get you to buy the whole unit or just plain stupid. Anyway, no more oil leak thatks to this forum.
Old 10-27-2010, 02:59 PM
norcallump's Avatar
I need to check my car as I have a nasty oil leak. I have oil on the a/c compressor and alternator. I was told by mechanic it is the timing cover. I have replaced the oil pan gasket. This problem started after a oil change by walmart. Im guessing they over filled the motor. I have cleaned my motor, and now my belt makes a funny sound...
norcallump is offline
Old 11-18-2010, 12:38 PM
dellguy3700's Avatar
Location: The place were people take there talents from to go to South Beach
Thanks for the above info...
I too started with the oil pan gasket. I suggest everyone that has leaks similar to this start with the oil cooler oring.
dellguy3700 is offline
captchaos
03-15-2016 12:18 PM
kjlouis
10-03-2015 05:29 AM
markevans999
09-10-2015 04:29 PM
dcam0326
09-07-2015 07:26 AM
nbstriker10
09-04-2015 04:26 PM
Quick Reply: Oil leak problem
