Charging-Battery Issue
Old 01-11-2010, 04:00 PM
mandyfig's Avatar
Today the battery red light lit on. The car made it home. I checked the voltage while engine on, only shows 9.8V instead of the 14.+ volts while charging.
When engine is off, I see the battery voltage go to 11.5 volts. Looks like the battery is ok and picks up the voltage after it is offline. The battery would crank up the engine after a while.
The RED Battery light remains on all throughout the RPM's.
FSM says, if the RED BATTERY light is lit on all RPM's, check belt for the alternator, if alternator belt is ok, then replace Alternator.
Is the alternator change an easy DIY?
Also, what auto store has a reliable re-built (they normally are all re-built, right?) alternator. How much are they?
Thanks in advance!
mandyfig is offline
Old 01-11-2010, 05:23 PM
mandyfig's Avatar
Found an original thread regarding the alternator replacement! Beat somebody telling me to do a search. It is actually a sticky in the DIY's.
Now to continue the reasearch....
mandyfig is offline
03-12-2020 12:06 AM
conansriver
11-18-2015 02:46 PM
wingnut2006
09-19-2015 06:13 AM
BrandonCause
09-14-2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
09-14-2015 05:28 PM
Quick Reply: Charging-Battery Issue
