HELP 3RD ALTINATOR IN 6 MNTHS
Old 12-05-2009, 10:27 AM
williamgd2's Avatar
Please someone have a solution, I have replaced my altinator 3 times in 6 months and am getting real sick of doing it. Here's how it goes, It starts off and on over charging and dying almost leaving me stranded. On all 3 the possitive connection with the nut on it has over heated and caused failure.They are autozone lifetime warrentee altinators but my once dependable Maxima is no longer dependable.What do you guys think is causing this? Just bad rebuilts? Or something else?I am looking for a way to solve this? Any suggestions? Thank you people in advanced just for being here.
williamgd2 is offline
Old 12-05-2009, 12:14 PM
03kodiak's Avatar
How are your cables? Check for shorts between the alt. and battery. Stock setup or running amps or subs or something like that?
03kodiak is offline
Old 12-05-2009, 01:15 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
you have a short somewhere that it is causing this issue.
Lontar1 is offline
Old 12-05-2009, 01:39 PM
williamgd2's Avatar
Stock running 2 amps with a capacitor. I am thinking the mod from altinator directly to battery might work, What do you guys think?
Old 12-05-2009, 01:41 PM
williamgd2's Avatar
The short seems to be at the possitive bolt at the altinator
Old 12-05-2009, 05:25 PM
That's Mr. Detail to you
Scottwax's Avatar
Have you had the battery checked? A weak battery overworks the alternator.
Also, I'm not sure I'd trust any electrical part from Autozone. After replacing three of their starters (in my old Accord) because every 3-4 starts, it would grind, I took the last one back, got a refund and bought a used one from Honda Heaven (wrecking yard) for $35 and never had a problem again.
Scottwax is offline
Old 12-05-2009, 05:47 PM
bigpopaj369's Avatar
id upgrade to the big 3 wiring mod and possibly change the battery. sounds kinda like u have a bad alt pos to bat connection. by upgrading the big 3 u will have better results with ur system and prolly eliminate ur issues.
bigpopaj369 is offline
Old 12-05-2009, 06:30 PM
DennisMik's Avatar
The connection overheating says that it is the weak spot in the flow of electricity. You have more current flowing than that connection can handle. The question of "why is this?" is not easy to answer. I expect the design to be correct. The altenator can only produce as much current as it is designed to, not one bit more. Loose connections cause resistance to current flow, electrical current flowing through resistance causes heat. If you heat metal and cool it down, the electrical conducting properties change. The metal gets brittle and this causes resistance. It becomes a vicious circle.
I would check and change the connector on the end of the wire harness that attaches to the altenator. I would also use an internal tooth lock washer when attaching the wire.
Just my 2 and a half cents worth.
DennisMik is offline
Old 12-05-2009, 06:37 PM
Nopike's Avatar
It's unlikely that you were provided three faulty alternators.
Check that the positive and negative connections of the battery are clean and tight. Make sure the alternator ground wire has a good clean ground connection from the alternator to the frame/trans (I'm not sure where it gets its ground but the connection should be clean and tight).
I remember a friend hads trouble starting his car, it turned out the battery connection was corroded. When I touched the corroded battery terminal it practically burned my hand. We cleaned it up and no more trouble. Maybe something like this is happening to you.
Nopike is offline
Old 12-06-2009, 06:41 AM
williamgd2's Avatar
I really appreciate you guys help.I think that I will do all of the above including the big 3 wiring mod. I think the 2 amps in trunk might be taking too many amps. it is a 1600 watt driving my speakers and a 1000 watt driving my sub,I am driving both of them off a 2 fared capaciter,I think that I might add another capaciter also.
Old 12-06-2009, 08:23 AM
captainbass7's Avatar
alt.
did the same thing, 3 alts from autozone, went to nissan. it is still working for three years now.
captainbass7 is offline
Old 12-06-2009, 09:50 AM
Scottwax's Avatar
He did get them at Autozone...
You might want to have the charging system tested while you are running your audio system at normal listening volume, could be the stock alternator doesn't have sufficient output to handle it.
Scottwax is offline
Old 12-06-2009, 11:53 AM
williamgd2's Avatar
Well the alts are 110 amp
Old 12-06-2009, 01:01 PM
mysticalone's Avatar
I'm having a similar problem. I bought a reman alt from autozone, and at night (sometimes during the day) my voltages will drop incredibly low with the lights on. Could be the battery, but I'm leaning more towards those reman alternators. I'm considering a refund and just buying it from Nissan.
mysticalone is offline
Old 12-06-2009, 02:34 PM
williamgd2's Avatar
Well it is a brand new battery autozone top of the line.They do sell good batterys.Thanks guys if it happens again it won't be a autozone altinator.
Old 12-06-2009, 05:41 PM
keep us updated
Old 12-06-2009, 06:04 PM
chrys9989's Avatar
I don't if you are auto or mt, but when I had a simialar issue last year. Turns out my motor mounts died. I went threw several altinators, (two remans, one new), then one morning, my ecu fried. When the new ecu was put in, the motor mounts were unplugged. I've had no issues at all since.
chrys9989 is offline
Old 12-09-2009, 08:38 AM
krsmax's Avatar
Alternator Autozone
Bought mine last year for my 00 against advice from many. No problems so far. Not an easy install as alternators go is it?
krsmax is offline
James92SE
142
01-02-2024 09:23 AM
aw11power
10-10-2021 04:57 AM
04-16-2020 05:15 AM
Quick Reply: HELP 3RD ALTINATOR IN 6 MNTHS
