5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Ok so my buddy has a wrecked 02 Maxima and said whatever parts I could get off of it and would fit on my 01 Max, I could have. The interior of the 02 is leather and both front seats are power and heated.
My interior is cloth and only my driver side seat is power, neither are heated. I don't really care for the heated part but do you think the harness for power seats is somewhere in the car just with a manual seat or is that a big No?
Also the wheels on it are the 7 spokes
Will they fit on my 01?
Then the taillights are this type:
What would I need to make them fit?
__________________
Roll Tide Roll!
Thanks to ChrisMan287 for the new sig
All those parts should be interchangeable without any modifications. The 00-03 tails are the same size, just different designs. The rims have a slightly different offset on the 02 than on the 01, but they will fit.
As for the power seats, I'm not totally sure. The plugs shouldn't be different from the 01 to the 02, but I could be wrong. When the blower motor for my heater went bad in my '02, I replaced it with a motor from an '01. The only difference between the two units was that the plug was in a slightly different location. Not far enough off to affect re-installation, though.
Oh, also, I don't know if the seat mounts are the same in '01 and '02. I don't see any reason why Nissan would change it, though.
There are no plugs IIRC to just plug in the power seats, you can grab them though and just take them apart and fit them onto your seat frame pieces, Write-up is around here on the org
Other things I would grap
Headlights, Sideskirts, engine, tranny, and his brakes
__________________
2004 Pontiac Grand Prix GTP Comp G
|3.5" Intake Bpi/R2C|Ram Air|3.4" Pulley|180* T-stat|Headers|Corvette Brakes|SSC Lowering|KYB|LEDs everywhere|GXP parts|SE Parts|
Want a Plug and Play Harness for your Emanage Ult/Blue? CLICK HERE!
Quote:
Originally Posted by MOHFpro90
Thank you Dave. I love you Dave.
Quote:
Originally Posted by bigleman
...so i had to get towed out of a ditch last night...
I believe your car should have the wiring harness for the heated seats preinstalled. You simply have to trace it through the panels. If you are getting the heated seats, make sure you grab the harness from the wrecked car as well so you could retrofit everything correctly. Just because your Maxima has pre-existing harness, doesn't mean the plugs are identical between the 01 and 02. The easiest way to check whether your vehicle has the heater harness is by checking the fuse box.
The wheels and taillights are dirct bolt-on, but I believe the ones already on your car is more desirable. I may be wrong though.
My tails are the red ones and I would prefer the clear ones and my wheels are base models so I definitely prefer the 7 spokes. Will just inspect to see if I have the harness for the power seats already there. As said above I don't really care for the heated part.
__________________
Roll Tide Roll!
does the gated shifter translate? that would be a fat upgrade (the 2000-2001 dont have the gated shifter do they?)
Dunno if this can be done as there are some different points in the positioning and the 5 gen has an overdrive button on the shifter etc.... . I will trade you my SE rims for those GLE rims as I think those were the best looking Max rims besides the sport rims on the 09's......hehe!
__________________
Wifes 05 G35S auto 14.31@98.90 mph (11/4/06) stock
Monte 03SE auto 14.60 @96.71 mph (11/4/06) stock
Monte 09 370Z Sport package auto (have not tracked yet)
All auto's[Twilight Blue, Glacier Pearl and Pearl White ]
