Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-06-2009, 07:57 PM   #1
sliders on calipers need to be replaced
when I get home, I notice a burning rubber smell and the rim is very very hot on the passenger side of car. I don't notice any leakage or smoke and the car does not pull one way or another. After taking it to the shop they showed me that the the caliper is applying pressure all the time and the slider is not releasing. Charge is $286 for re surfacing the rotors, flush of break fluid and caliper silde service.
Is all that needed?
boost4age is offline   Reply With Quote
Old 11-06-2009, 08:09 PM   #2
Sounds like to me. I doubt the sliders would need to be replaced, most likely just lubbed properly. I hope that $286 is for resufacing all four rotors, because you can buy all new oem ones for less than that. Did you give them the go-ahead to do the work already? If not I highly suggest you save yourself a couple hundred dollars and just do the job yourself. I used this how-to to help when I did mine: http://www.shiftice.com/brake_install.html
__________________
2002 Maxima
Sterling Silver Mist
LongIslandMax is offline   Reply With Quote
Old 11-06-2009, 08:20 PM   #3
No i didnt let them do it. Its just on the passenger side of car.
Old 11-06-2009, 08:24 PM   #4
yeah man i would just replace the rotors and grease the sliders b4 i spent 286 bucks on somethin that wont cost anywhere that much to do yourself!!
StenholmEngineering is offline   Reply With Quote
Old 11-06-2009, 08:39 PM   #5
I would love to give that a try but i dont have any of those tools.....I'm going to call around and see if anyone can do it cheaper. I only went there because i have warranty on the break pads...
Old 11-06-2009, 11:00 PM   #6
Quote:
Is all that needed?
By sliders, you mean the caliper sliding pins?
If so, then do not let the shop charge you so much for the job. The sliders on the maxima are made from a very strong steel. They rarely bend.
If you want to replace them anyway, you can get a "caliper kit" from your local Autozone, Schucks, or Pepboys. The caliper kit comes with new sliding pins, new sliding pin boots, and some other caliper accessories you may want to replace. The kit costs around $10 per wheel.
LoveSick is offline   Reply With Quote
Old 11-07-2009, 01:18 AM   #7
Send a message via MSN to lalaMAX
when i replace my rear rotor couple days ago, one of the slider was rusted as well... i need to use a locking piller to get it out and clean rust and relube them... anyway i am going to get a new Dorman caliper bracket (should come with boot and slider) for around 20 bux, then another 20 bux shipping from rockauto, problem solved
lalaMAX is offline   Reply With Quote
Old 11-07-2009, 01:48 AM   #8
Notice the small rubber boot or gromet on one of the sliding pins? You can safely remove that. That is often the cause of caliper pin seizing. That boot swells up from heat and pressure, and ultimately grips the sliding pin against the bracket.
Old 11-07-2009, 03:31 AM   #9
this is the reason anti-seize was invented
Gemner is offline   Reply With Quote
Old 11-07-2009, 05:46 AM   #10
Quote:
Last week I lubed my caliper sliding pins. I had a very hard time trying to push the pins with that rubber sleeve back in the caliper bracket, so I decided to remove the rubber sleeve. Glad to read it is often the cause of seizing, and that it can be safely removed.
__________________
winter beater: 2003 Maxima GXE
fun toy: 2002 JR supercharged Miata
wife: Ford Fusion AWD
kids: Civic, Integra, Mazda3
twiggy144 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
