Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-06-2009, 01:12 PM   #1
My trunk slams shut
I installed a OEM spoiler on my 03 maxima. No problems there, however the weight of the spoiler causes the trunk to slam and it doesnt pop open like it used too.
I was just wondering what keep the trunk lids from slamming when the spoilers are put on the right from the factory?
acgrunt19 is offline   Reply With Quote
Old 11-06-2009, 01:22 PM   #2
Send a message via AIM to Rhyno02
My trunk is the same as yours and my spoiler is from the factory. I am curious to see what answers come up...
__________________
G35 18's-245/40/18 General Exclaims:Otto FSTB:Powerslot slotted front rotors:Hawk HPS pads:GAB-K&N dropin filter:Clear Bumper Lenses:Optima Yellow Top:Tints and many more to come....
Rhyno02 is offline   Reply With Quote
Old 11-06-2009, 01:27 PM   #3
Right from the factory and it slams??
Now im curious to see if there is an OEM solution to the problem. I thought originally if it came from the dealer with a spoiler that the slamming was not an issure.
If anyone has any pictures of the inside of the trunk, that would be a big help
Thanks guys
Old 11-06-2009, 02:01 PM   #4
Nothing keeps them from slamming. Mine is factory-installed and it also slams if I let it go from, let's say, the midway position (I'm assuming yours stays put when it's all the way open and it just slams if you let it go as you bring it down to close it).
Nothing to adjust in my trunk, as someone suggested in your other thread.
When I open it, it barely just unlatches the hook but it will not go up at all.
__________________
Nelsito65 is offline   Reply With Quote
Old 11-06-2009, 02:37 PM   #5
Mine is also from the factory, and when you pop it... it unlocks but doesn't open all the way up if that is what your are expecting. Once it is opened it stays all the way up until you decide to close it, it is a pretty simple hinge that holds it there are no hydrolic arms to lift it on its own.
__________________
2003 Sterling Mist 3.5 SE /Llumar tint 20%/20%/20% /Racingline FSTB /Custom Intake /BPI Velocity Stack /*17 Advance /HID Plazma Xenon Fogs /2x10 Fosgate Subs & 1000w amp. /Falken ZE912 235/50/17 OEM rims /Budget B pipe & Vibrant Exhaust - Deleted Resonator /LED Underbody Lighting /Blue LED Interior Lighting /Chrome Rings Gauge Cluster /Viper Security /F&R Motor Mount ES Bushings & Sub Bushings /Sm Markers /KYB GR2's/S-Techs
Ghost_54 is offline   Reply With Quote
Old 11-06-2009, 03:09 PM   #6
Puerto Rico-Maxima Lover
Lontar1's Avatar
Quote:
What he said....
__________________
AT TRANNY FLUSH
http://www.cardomain.com/ride/335521/3
Lontar1 is offline   Reply With Quote
Old 11-06-2009, 03:22 PM   #7
Hey wings r heavy so the trunk is going to slam. Just close it carefully thats wut i do.
__________________
MAXX FOR LIFE
03 maxima se
GO EAGLES!!!!!
cmd26 is offline   Reply With Quote
Old 11-06-2009, 03:29 PM   #8
What they all said. It barely pops when I unlock it. Almost like it's sticking to the weather stripping.
And if I let it go from anywhere it slams pretty hard.
fflint_18 is offline   Reply With Quote
Old 11-06-2009, 06:47 PM   #9
jsut keep it easy when closin it, mine is oem and it shuts pretty hard
StenholmEngineering is offline   Reply With Quote
Old 11-06-2009, 07:14 PM   #10
nsnrider's Avatar
Send a message via Yahoo to nsnrider
get stiffer tention rods for the trunk. it will make the trunk feel a bit lighter though it will not make it go up all the way by itself.
__________________
Sold my 2k3 Max.
nsnrider is offline   Reply With Quote
Old 11-06-2009, 07:16 PM   #11
nsnrider's Avatar
also check your weather stripping around the trunk.
__________________
Sold my 2k3 Max.
Old 11-06-2009, 07:32 PM   #12
Send a message via AIM to JAMAICANLOVRBOY Send a message via Yahoo to JAMAICANLOVRBOY
the spoilers are heavy, and maximas dont have trunk shocks to help with the added weight. i noticed the same thing when i added a spoiler to my car.
__________________
98 gxse, de-k swap, vlsd, apexi II, I/H/E, stillen kit, NEX coilovers
http://boredmder.com/ecucodes/index.php?year=
http://forums.maxima.org/general-max...niti-fsms.html
JAMAICANLOVRBOY is offline   Reply With Quote
Old 11-06-2009, 07:50 PM   #13
Wait, when you pressed the trunk button (pre-spoiler) it opened all the way up?!?! Must be nice
Gemner is offline   Reply With Quote
Old 11-08-2009, 12:58 AM   #14
... mine doesn't slam.. and i have ghetto sound dampening on the trunk.. i guess i just always carefully put down my trunk lid... It closes if i lightly press down on it when its sitting on the latch
__________________
2001 Nissan Maxima 20th Anniversary Edition w/ only 65k on it (11/8/09)
Suspension-
Eibach Springs on Illuminas set to 4F/4R
Stage 2 LTB Installed!
Now I need a RSB
Audio-
JLAudio 12W7 in a 2.3cuF (same box, ghetto sealed)
JLAudio 500/1 @ 85hz
Rainbow SLC 255 Comps
Alpine V12 MRV-F407 @ 75hz
Optima Bluetop D35 (1/2 Grounding Kit done)
FlipCpt45 is offline   Reply With Quote
Old 11-09-2009, 07:10 AM   #15
i carefully close it every time.....its juts annoying when someone else does it and it sounds like someone rear ended me
Old 11-19-2009, 07:34 PM   #16
Dealer sells tension rod kits for the trunk for the extra spoiler weight. These are very tricky and dangerous to put in if you dont know what you are doing so be carefull !!
11-YEARS-DEALER-EXP is offline   Reply With Quote
Old 11-20-2009, 08:50 AM   #17
unless you put them there
http://video.cardomain.com/VideoPlayer.aspx?id=705587
__________________
NWP spacers, NWP VIAS , Berk intake, Unorthadox pully, 4g Grounding Kit Optima , timing advance, Illuminas, S Tech, Eclipse CD7200 mkII, Kinetik HC600, 15% tint, Color matched headlights, angel eyes, LED Tails & side markers, RPM R505 19x8.5, Eagle F-1 235/35ZR19, 20mm H&R spacers rear 5mm front, Mesh grill.
http://www.cardomain.com/ride/3281165
phxgold is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
