Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-06-2009, 11:51 AM   #1
Are all MOOG parts upgrades?
There are a couple of current threads here discussing the FSB (front sway bar) end-links. Nelsito65 went and posted this great picture of the OEM end-link, side-by-side with the MOOG part. The differences are obvious.
That got me thinking about the MOOG Ball Joints and Tie-rod ends. I'm really only planning on replacing them when or if they ever fail. But now that I see this end-link, I'm wondering if the MOOG ball joints and tie-rod ends are "upgrades".
Anybody with opinions on that? Pictures, maybe?
__________________
NWP phenolic intake spacers, Cattman y-pipe, Cattman 2.5" cat-back, Frankencar short-ram intake, Apexi pop charger, UR crank pulley, ES motor-mount and sub-mount bushings, Racingline FSTB, Progress RSB, STS mod w/ES bushings, Brembo blanks, Hawk ceramic pads, Goodyear Eagle F1's -- 54,000 original owner miles
Rochester is offline   Reply With Quote
Old 11-06-2009, 11:52 AM   #2
Nelsito65's picture, btw:
__________________
Old 11-06-2009, 12:23 PM   #3
Play with my balls
Deckdout2's Avatar
Send a message via AIM to Deckdout2
I have these parts at home. When I change them out, I can take pics for you.
__________________
GI: 19" x 8.5" +33 Offset Rare Millie Miglia Evo5
In One's Own Tune, Balance Is Found In The "Area Under The Curve".....
Deckdout2 is offline   Reply With Quote
Old 11-06-2009, 09:29 PM   #4
Quote:
That would be great. Love to see these parts side-by-side. If they're upgrades, I'd consider some preventative maintenance.
Why did you buy them?
__________________
Old 11-06-2009, 10:50 PM   #5
The moog suspension joints are a good replacement whenever the existing ones fail.
However, they are far from an upgrade, and I wouldn't recommend changing out perfectly functional stock ends for the MOOG ends. They are a nice improvement over stock, but not worth changing to if your existing ones are operational.
One must note that despite the larger rod being used on the sway bar endlinks, what matters is the ball joint itself. I have seen MOOG joints becoming loose after a couple years of use. The serviceable nature of the MOOG suspension joints allow the masking of the creaking noise, which is an indication of worn out joints.
I have been using the 200,000 miles factory sway bar endlinks on my 240sx with Tanabe sway bars. They were fine and really tight. Those parts rarely wear out.
Truthfully, once in a while I would read about ball joint failure being reported on different forums. However, as a mechanic I have never actually replaced any ball joints for my customers. The only times I saw ball joints failure were when the owner hit a curb, which required changing out the entire control arms. Ball joints themselves, I have never had to replace any.
One way to check when your ball joints are in need of replacement is by shaking the control arm or spindles while the car is suspended with wheels removed. If there is any wiggle room from the ball joints, that is a sign of ball joint failure.
LoveSick is offline   Reply With Quote
Old 11-07-2009, 02:45 AM   #6
MOOG is used by NASCAR.
Which means your car will handle like a NASCAR.
__________________
2001 A33 AE || KV3 || 5MT || VLSD
SHIFT_sleepy
PM for cheap Infinity, Rockford Fostgate, and Kenwood car audio equipment!
MoncefA33 is offline   Reply With Quote
Old 11-07-2009, 06:34 AM   #7
I can't speak for Moog ball joints but the tie rods/tie rod ends didn't visually strike me as an upgrade. Mechanically, it might be a different story, because as mentioned the actual joints are the most important part.
__________________
137k miles
To-do: Belts, Fix suspension problem
Major probs fixed: L
ower oil pan | Radiator | EVAP canister/valve| VIAS Control Valve | Rear VC | Exhaust hole near axle
ridinwitha35 is offline   Reply With Quote
Old 11-07-2009, 07:56 AM   #8
That was a great response. Exactly the kind of insight that's helpful for people evaluating replacement parts.
Perhaps my original plan is best: before having my suspension mods installed in the spring, step in for a quick lift and have my mechanic analyze the ball-joints and tie-rod ends first.
Not helpful, but still (a little) entertaining.
Quote:
They look like a stronger design to me, why not to you? I assumed the thicker bar in the end-link meant a stronger, more solid connection. Not so, by your reasoning.
But then why is the SE swaybar 23 mm, vs the 22 mm sway bar on the non-SE models? Isn't thicker better?
MoncefA33, this is where you chime in with, "That's what she said."
__________________
Old 11-07-2009, 09:13 AM   #9
Quote:
The inspection will be done prior to your alignement. I needed a ball joint on my car.
The sway bar is a torsion spring, so thicker (or shorter) makes for a higher rate.
The end links are strictly in tension and compression. If the stockers don't deflect, then thicker is meaningless....except for marketing.
__________________
LTB II, CAI, H&R, Illuminas, ES shifter, subframe, engine mounts, sway bar bushes, Megan OE-RE, Watkins STS.
SteveB123 is offline   Reply With Quote
Old 11-07-2009, 05:04 PM   #10
Thanks Rochester.
__________________
SHIFT_sleepy
Old 11-07-2009, 05:53 PM   #11
Well said.
Old 11-07-2009, 06:04 PM   #12
Thanks Rochester.
It's all in good fun. (what she said)
Well said.
Glad I asked these questions. Didn't expect it to backfire on my initial opinion about the end-links, but I do appreciate getting educated.
__________________
Old 11-08-2009, 08:25 AM   #13
Send a message via AIM to djfrestyl
I agree with LoveSick who summed it up perfectly:
"However, they are far from an upgrade, and I wouldn't recommend changing out perfectly functional stock ends for the MOOG ends. They are a nice improvement over stock, but not worth changing to if your existing ones are operational."
They're not an UPGRADE per say, but a nice improvement. I hardly notice a difference in handling or driveability between OEM and Moog, but when replacing them, for the price and Moog being known for their suspension parts, it's more of a "why not.."
__________________
Eclipse CD3000
Audison LRx 6.9-> Rainbow SLC 265.03, (2) 10" DLS Reference W710's
Knukonceptz 1/0awg / Cascade VB2Max / Stinger / Clifford / Optima
Exterior: stock-tastic.
I can install your suspension and stereo. Click here for info!
Is your spare tire cover sagging? Trunk have a big DIP in the middle? Click here to see a solution!
djfrestyl is offline   Reply With Quote
Old 11-08-2009, 09:17 AM   #14
Yours is always a welcome opinion, djfrestyl. Thank you.
So taking that one step further, (and hopefully not putting words in your mouth), a philosophy of "why not" doesn't apply to ball joints and tie-rod ends because they are relatively expensive when compared to $15 MOOG end-links.
You've crossed paths with me on this issue a few times, so I apologize for seeming redundant. I've been trying to lock down a reasonable and practical approach to these parts, and got side-tracked seeing the side-by-side picture of the end-links. I think that summary is:
(1) If you're already "down there" with suspension and/or brake work, replace the end-links with MOOG parts because they're inexpensive and good-as or better than OEM. (Including ES sway bar bushings.)
(2) Replace the ball-joints and tie-rod ends with MOOG parts when they fail.
Yes?
__________________
Old 11-08-2009, 09:37 AM   #15
Option #2, but apply that to end links as well. No point in replacing anything before they fail. The end link job is easy enough to do on its own. And the difference in handling is marginal - if any at all.
__________________
Eclipse CD3000
Old 11-08-2009, 09:41 AM   #16
nsnrider's Avatar
Send a message via Yahoo to nsnrider
i've been using MOOG parts for many years now, and recommend them to all my customers over other aftermarket parts that are available on the market.
My main reasons for MOOG parts over other aftermarket counterparts are:
1. better in design
2. greesable
3. good warranty
4. priced well compared to oem
5. descent fit and finish
This goes true for all of their suspension parts, and I've done all of them, inner/outer tie rods, ball joints, etc.
When you are trying to compare to OEM, then I would not necessarily consider these an upgrade per functionality as I like the fit and finish of most OEM products, the longevity of OEM is adequate, the most common different from OEm parts is the price as these tend to be pricier than MOOG parts. Every once in a while you can find a descent price on OEM suspension parts that are comparable to aftermarket, but in general they are much more.
Hope this info helps.
__________________
Sold my 2k3 Max.
nsnrider is offline   Reply With Quote
Old 11-08-2009, 09:44 AM   #17
nsnrider's Avatar
I agree.
Most of the time when it comes to end links, it's the annoying clattering noise you get over uneven surfaces over handling, reason why you'd replace the end links unless they're bad to a point that they pop out of their joints or break, then its a handling issue on top of the clunking noise.
__________________
Sold my 2k3 Max.
Old 11-08-2009, 09:57 AM   #18
Glad this thread was posted, as I'm thinking my TRE's might be worn. I ordered new MOOG TRE's from Advance Auto. They set me back $81+change, but haven't put them on yet. Don't know if I'll get around to putting them on before I leave for my business trip to be able to give an opinion on better or not. Would still like to hear what everybody elses opinions are.
1800bucks is offline   Reply With Quote
Old 11-08-2009, 10:24 AM   #19
Quote:
Originally Posted by nsnrider View Post
I agree.
OK, OK. Man, I keep trying to spend money, and you guys keep trying to put it back in my pocket! OK, I get it. (Phew!)
I'm going to cool my jets on end-links, tie-rod ends, and ball-joints. In March, I'll put it up on the lift and go over this stuff with my mechanic, to assess the situation before planned April mods. (By the way, that's the advice of my mechanic, too... replace these things only when they break.)
I'm done. I've got the advice I needed, just not necessarily the advice I wanted. Thanks, guys.
__________________
Old 11-08-2009, 10:55 AM   #20
Oh crap. Now I know where my money is going...
...went to use the car just now, and I'm missing on one cylinder.
Kind of sucks the fun right out of things.
__________________
Old 11-08-2009, 10:59 AM   #21
Time for a spark plug/coil job. Any codes?
__________________
Eclipse CD3000
Old 11-08-2009, 11:06 AM   #22
Plugs are less than 2 years old; Iridium Tips. I had one coil replaced 18 months ago, the others are original equipment. Codes? Don't know, but the CEL hasn't started yet.
What sucks is I just had the spacers installed, which would have been nice timing to coincide with bad coils. Not that you can plan that crap. See, this speaks right to the heart of things with this thread: spending money on upgrades is fun. Spending money on repairs is decidedly not fun.
Coils are expensive. Oh boy.
__________________
Old 11-08-2009, 03:43 PM   #23
Probably another coil. By codes I mean if a CEL or SES appeared yet. Hopefully one appears soon so you know which cylinder it is.
Agree - good luck
__________________
Eclipse CD3000
Old 11-09-2009, 09:29 AM   #24
Agree - good luck
Hooked it up at my mechanic's shop this morning. No CEL, but it did register a misfire on the #2 cylinder; (I think the code was P302 or something like that.) So we replaced the coil pack on #2 and cleared the codes. Runs great again.
Very pleased it was in front. 1-3-5 are a PITA.
I'm out $130 for parts and labor/diagnosis, and a half-day of work, but I got it fixed ASAP and the car runs good again. What can I say... cars are expensive.
__________________
Old 11-09-2009, 10:23 AM   #25
Send a message via AIM to vastmax
All i have left to change out are the MOOG ball joints up front. I have replaced endlinks, inner and outer ties, & strut mounts with moog parts. Each part, except for the strut mounts, have been noticably meatier than the stock counterpart. At 130k, all of these parts were pretty worn and could be moved freely by hand with no force. Everything except the strut mounts NEEDED to be replaced. I am in the process of replacing all the bushings up front with ES hoping I will acheive the suspension/steering we all long for.
Also, for those going to advanced for parts, dont forget about the $10 off $25 coupons floating around here...
__________________
vastmax is online now   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
