Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-05-2009, 05:00 PM   #1
Moog swaybar end-links: are they _too_ big?
I've gone through two sets of Moog end links so far. First set, one of the links seized up (joint wouldn't rotate at all). This second set isn't physically bad yet, but the problem is that I have to tighten them ever so often (like once or twice a month). I know it's time to tighten if I hear/feel popping sounds or if the car is just "loud" going over rough crossings such as railroad tracks.
What's been on my mind is the clearance that these end-links have with the control arm; there's hardly any. This makes me wonder if this is the reason why they keep loosening their-selves...possibly 'cause they pivot against the control arm. Has anyone had this problem or issue?
PS: I torque them down to spec (about 40 ft-lbs) while on the ramps every time. I know I can just hit it with the impact/breaker but fear that might do more bad than good.
__________________
137k miles
To-do: Belts, Fix suspension problem
Major probs fixed: L
ower oil pan | Radiator | EVAP canister/valve| VIAS Control Valve | Rear VC | Exhaust hole near axle
ridinwitha35 is offline   Reply With Quote
Old 11-05-2009, 05:47 PM   #2
Auto Tech Performance
rroderiques77's Avatar
Send a message via AIM to rroderiques77 Send a message via Yahoo to rroderiques77
Try tightening them without the load on the vehicle.
__________________
94 F22B2 CD6 G77M 5MT- daily bucket
Will be one day modded
02 A33B KT3 6MT
241whp/227wtq
ET...14.480
Interested in owning/operating an automotive repair franchise?
P/M me for details.
rroderiques77 is offline   Reply With Quote
Old 11-05-2009, 06:07 PM   #3
When I did mine I tightened them without the load of the vehicle.
I also agree that they are too big and I think that the cause of the clunking sound I hear, when going over speed bumps, is because of the minimal clearance between them and the LCA. The picture below shows the difference in size between the stock ones and the Moogs.
Edit: I've heard concerns from other org members because of how close they sit to the LCA.
__________________
Nelsito65 is online now   Reply With Quote
Old 11-05-2009, 06:10 PM   #4
Puerto Rico-Maxima Lover
Lontar1's Avatar
the size is not a problem.. I have them and have no problem
__________________
AT TRANNY FLUSH
http://www.cardomain.com/ride/335521/3
Lontar1 is online now   Reply With Quote
Old 11-05-2009, 06:18 PM   #5
^^^^this
__________________
02 A33B KT3 6MT
241whp/227wtq
ET...14.480
P/M me for details.
Old 11-05-2009, 06:22 PM   #6
If they are both too big, I wouldn't think it would matter because it will just offset the position of the sway bar.
Also, you could try some loctite next time you tighten the bolts.
Unklejoe is offline   Reply With Quote
Old 11-05-2009, 06:31 PM   #7
Unklejoe, I mean "big" in the sense that the ball joint & its enclosure is bigger; the offset from the top & bottom studs are the same as that of OEM end links.
For example, in Nelsito's picture above, the distance from the center of the bottom stud to the bottom of the link is greater on the Moog links.
So those of you who say they don't have a problem...are you saying:
A) They might be hitting the LCA, but it's not a major issue
or
B) They aren't hitting the LCA so there is no issue
As far as tightening while not under load, I was basing that off of what the FSM says about rubber suspension parts...but I guess since there is no "bushing" it doesn't apply.
__________________
137k miles
Old 11-05-2009, 07:02 PM   #8
Oh I see, that makes sense. I will be installing mine this weekend, so I'll post back if there's a problem.
Old 11-05-2009, 07:42 PM   #9
Never had an issue out of mine. Perhaps they aren't installed correctly?
PulsarGTS is offline   Reply With Quote
Old 11-05-2009, 08:14 PM   #10
How often do you think these MOOG end-links need to be packed?
Age, or miles?
__________________
NWP phenolic intake spacers, Cattman y-pipe, Cattman 2.5" cat-back, Frankencar short-ram intake, Apexi pop charger, UR crank pulley, ES motor-mount and sub-mount bushings, Racingline FSTB, Progress RSB, STS mod w/ES bushings, Brembo blanks, Hawk ceramic pads, Goodyear Eagle F1's -- 54,000 original owner miles
Rochester is offline   Reply With Quote
Old 11-05-2009, 08:22 PM   #11
Send a message via AIM to djfrestyl
They fit. No worries about the size. I've installed many many of them.
edit: When I tighten them (no load on the vehicle), I use a pry bar to 'raise' them off the control arm a bit. No noise.
__________________
Eclipse CD3000
Audison LRx 6.9-> Rainbow SLC 265.03, (2) 10" DLS Reference W710's
Knukonceptz 1/0awg / Cascade VB2Max / Stinger / Clifford / Optima
Exterior: stock-tastic.
I can install your suspension and stereo. Click here for info!
Is your spare tire cover sagging? Trunk have a big DIP in the middle? Click here to see a solution!
djfrestyl is offline   Reply With Quote
Old 11-05-2009, 08:34 PM   #12
Play with my balls
Deckdout2's Avatar
Send a message via AIM to Deckdout2
I chose option B.
I would check the other variables of the suspension as well. There are many other components that might need addressing to pinpoint your issues.
__________________
GI: 19" x 8.5" +33 Offset Rare Millie Miglia Evo5
In One's Own Tune, Balance Is Found In The "Area Under The Curve".....
Deckdout2 is offline   Reply With Quote
Old 11-05-2009, 08:50 PM   #13
Those endlinks are beefy as hell and have been installed o my car for close to 2 yrs no problems or noises! You may wanna check out your suspension out thoroughly there's something else going on....
__________________
CMax03 is offline   Reply With Quote
Old 11-06-2009, 07:26 AM   #14
kgallerie's Avatar
Same here...
I've had them for over a year and havent touched them since. They fixed my clunking and have been quiet ever since.
If you think they are hitting the LCA, take a look for marks on the link and LCA where they would be hitting. I would think that it definitely would leave a mark on one of them if they were hitting.
kgallerie is offline   Reply With Quote
Old 11-06-2009, 07:33 AM   #15
Quote:
How is that possible...after installation, the joints are sitting at perfect right angles, they're torqued to spec (while loaded), and they're fine/tight/quiet until they get loosened up. Where can I go wrong?
Quote:
Age, or miles?
Probably just by visual inspection...so a combination of both really. You can easily peel the rubber insulator back to expose the actual ball joint & if it looks a little dry, throw some grease in there.
OK maybe I should try that.
Quote:
Quote:
Originally Posted by Deckdout2 View Post
I chose option B.
Since you guys allude to something else being the problem, my steering/suspension has been fully upgraded except for the rack (which I think is bad), but doubt that it could contribute to end-link problems. What other variables can lead to these end links loosening their-selves if you've got new control arms, swaybar/subframe bushings, struts & mounts & bearings, and inner/outer tie rods?
__________________
137k miles
Old 11-06-2009, 07:34 AM   #16
Quote:
Originally Posted by kgallerie View Post
Same here...
I can't be sure that they're hitting the LCA....it was just a hypothesis on why they keep getting loosened. I'll try the suggestions listed (tighten with no load, use pry bar to raise 'em up a bit, usage of loctite) & see what happens but just was wondering what everybody else out there thought.
__________________
137k miles
Old 11-06-2009, 07:51 AM   #17
What are you using to torque them down? Maybe you just need some more power to get them tighter. I zip them on with an impact gun.
__________________
Eclipse CD3000
Old 11-06-2009, 09:28 AM   #18
Just a torque wrench set between 40-45 ft-lbs.
Some old references:
1) Funky noises after replacing Sway Bar End Links
Quote:
Originally Posted by Matt_01SE_20th
I had the same problem with my MOOG end link. The ends are substantially larger than the stock ones. this causes the bar link to bind between the control arm and the stabilizer bar, instead of being free to rotate.
another thread, possibly of interest:
2) Front end clunk = oblong stabilizer hole?
Quote:
Originally Posted by Love_00_Max
My front end clunks over speed bumps drives me nuts. I don't hear any noises on highways becoz the concrete highway noise masks any suspension noises. I installed MOOG endlinks and it was fine for a few months and then the sounds came -- it was never there when I had OEM links. I am going to check them out this weekend.
What a coincidence, I too must have had the MOOGs for a yr and the clunks are all over the place. Gladly I have the OEM links in the garage, I will put them back on the vehicle. I don't mind having a non-firm ride, but I just cannot deal with clunks, it really bothers me.
__________________
137k miles
Old 11-06-2009, 11:21 AM   #19
Play with my balls
Deckdout2's Avatar
Quote:
My driver's side axle is busted and my wheel bearings are shot. Have you replaced those or looked into that yet?
__________________
Old 11-07-2009, 12:10 AM   #20
Check all your motor mounts please!....when worn it sounds like suspension components!
__________________
Old 11-07-2009, 06:41 AM   #21
Lucky you! But I haven't had any indication of a bad axle (boots are fine, no clicking) or bad bearing (no 12/6 o'clock looseness at wheel or growling).
I understand. But the problems I have also affect handling. Can bad mounts cause more than just a little vibration & abnormal sounds (of course for the non-extreme case)?
I don't want to get too far off in turning the thread into a fix-my-problem thread since I've got another one going already, but still curious to see what people say about their Moog end links loosening up after a while.
__________________
137k miles
Old 11-07-2009, 06:58 AM   #22
boondoxmax's Avatar
+1 I thought my strut mounts needed to be replaced and it turned out the be the motor mounts. When they go bad they sound like a suspension problem. I also have the moog without any problems. Can't believe my mounts are worn out at 75000 miles. Geezzzzzz
boondoxmax is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
