Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-04-2009, 05:13 PM   #1
Help! Strange Heated Seat Problem!
Ok, on my drivers seat, the switch works on the 'high' setting, but not on the 'low' setting. The little light in it works on both settings. (I put a blue LED in it a year ago) It is a newer switch (only a year old) and the heated seat used to work on both settings.
What could the problem be?
__________________
-Trying is the first step towards failure...
jowo9 is offline   Reply With Quote
Old 11-04-2009, 06:23 PM   #2
Stupid question, but did you try the old switch again? Just to see if maybe the switch has an open in the one setting? It can't hurt to try...otherwise it sounds like a wiring issue maybe.
__________________
http://www.cardomain.com/ride/3245762
InjenCAI/NWP VIAS Plate/H&R/Illuminas/ContiSportContact 225/45/ZR17(summer)
NOW Pirelli PZero Nero 235/55/ZR17 (winter)
Alpine9886/Type-R components/MRP-F450/Type-R 12"/MRP-850/
byrdman164 is offline   Reply With Quote
Old 11-04-2009, 06:47 PM   #3
ahh, I don't have the old switch... otherwise I'd try. But..... I know that the seat used to work with the new switch. It's just recently that it quit.
__________________
Old 11-04-2009, 06:55 PM   #4
Send a message via ICQ to jasonmax Send a message via MSN to jasonmax
Quote:
take it out and use a DMM to check
__________________
Life would be boring without the Maxima.
From Nebraska? Go here: http://forums.maxima.org/midwest-tex...ebraska-9.html
You wanna clean your MAF under 10 bucks? Go there:http://forums.maxima.org/5th-generat...10-w-pics.html
jasonmax is offline   Reply With Quote
Old 11-04-2009, 07:28 PM   #5
hmm... don't have a DMM.. I just have a 12/6 V voltage tester.... maybe that'd work, i dunno.
__________________
Old 11-04-2009, 08:22 PM   #6
a voltage checker would work...you just need to see if the circuits have power at the proper switch position. It would probably be easier to check the switch if you had a DMM or an ohmmeter, to component test the switch itself though. If you had access to a wiring diagram or FSM check and see which pins or wires should have power when the switch is in the high position and low position.
__________________
Old 11-04-2009, 09:11 PM   #7
K, I used my voltage tester and found out that everything is definitely working fine in the switch. Now I'm thinking that there may be a problem with the wiring under the seat?? I might pull the seat out tomorrow and check it... I just don't know where to look yet.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
