Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-03-2009, 10:51 PM   #1
Send a message via MSN to lalaMAX
help, two weird problems.
Problem 1:
I noticed lately, when i turn my key to ignition on and when engine is running, and open my driver door, my door light doesn't light up and the red "door open warning light" on the dash is very dim, but the roof light does light up properly.
if I don't put the key in and open the door, the door light and dome light does light up, but no "door open warning light"...
All other doors are working properly, ie. open door, front door light, "door open warning light", and dome light does light up properly.
I did swap the door sensor on B-Piller with the passenger door one, still the same problem, so I assume the sensors are fine. I did check the fuse under the steering wheel, the "room light" fuse is good. Does anyone know what it might be? I am thinking maybe a relay under the hood. Does anyone had this problem before? please let me know the solution.
Problem 2:
I just changed my rear break and rotor with the ATE. everything is fine but I feel that the hand brake is kinda loose. ie. Normally, I remember when I shift into D and release brake padel, 3-4 click could prevent the car from rolling, but now it needs 6-8 clicks. I am just wondering if there are anyway to tighten the cable?
Thank you all for the help first
lalaMAX is offline   Reply With Quote
Old 11-03-2009, 11:20 PM   #2
subscribed GL having sim prob...
__________________
PLEASE HELP!
power door locks, rear defrost, dome light don't work?HELP!
current 2001 max gle
rip 98 max se july 4 2009
mrjamaica98mx is offline   Reply With Quote
Old 11-04-2009, 12:33 AM   #3
so GL has the same door light problem?
did he came up with the solusion?
Old 11-04-2009, 06:20 AM   #4
Send a message via AIM to mist max2000
yes there is a way to tighten it,.. ive seen it on here before,.. but i have the same problem... my 3-4 clicks now, the handle just flops around, and doesnt get tight till 6-8+,.. i know someone can help with the tightening location
__________________
| 2002 6speed|Progress RSB|Illuminas|Progress Springs|Clear Sides|Crome DoorTrim Blackout|Grill-tech lower Valence insert|HID fogs|eyelids|Hella Supertones|HD CatchCan|Berk Intake w/ Apexi filter|
Parts I own waiting to go on:| stillen classic kit|GenI cattman headers|Test Pipe|SAFCII
mist max2000 is offline   Reply With Quote
Old 11-04-2009, 06:33 AM   #5
H.M.F.I.C
MidN1te's Avatar
i like it tight.....giggity..
if you pop up your center console.. the lever is hooked up the cable to the brakes... you can use a wrench and turn the cable til it gets tighter.
__________________
My Babie with my Baby. Turbocharged S2000
MidN1te is offline   Reply With Quote
Old 11-04-2009, 07:45 AM   #6
Send a message via ICQ to jasonmax Send a message via MSN to jasonmax
I remember the service manual says 6 clicks is recommened.
__________________
Life would be boring without the Maxima.
From Nebraska? Go here: http://forums.maxima.org/midwest-tex...ebraska-9.html
You wanna clean your MAF under 10 bucks? Go there:http://forums.maxima.org/5th-generat...10-w-pics.html
jasonmax is offline   Reply With Quote
Old 11-04-2009, 07:47 AM   #7
H.M.F.I.C
MidN1te's Avatar
now that i think about it. i never actually just pull up.. i always hold the button down while pulling up lol.. that way i dont hear the clicks.
__________________
Old 11-04-2009, 07:55 AM   #8
Quote:
dont really use mine cuz the cable might get frozen then Im stuck.
__________________
Old 11-04-2009, 07:57 AM   #9
H.M.F.I.C
MidN1te's Avatar
Quote:
why would it do that?
__________________
Old 11-04-2009, 09:31 AM   #10
see but mine loosens up on it self over time,.. like basically.. you can tap it ever so slightly from under it and it will bounce up and down,.. basically,.. at 1-2 clicks.. there is still slop/slack in the line with no tension on the line at all untill higher clicks.. i know it hasnt always been like that,.. but thats why i always put it in second gear as well
and a comment on what was said about it being stuck,..on my old 00 max, if the e brake was up,-- upon disengauging it ,.. the back brakes would not losen up completly, yet the handle would make it appear as if it were disenguaged,..found out the hard way.. after driving about 5 miles to my destination on the highway.. i got out and said mmm smells like brakes,.. sure enough the wheel was hot to the touch lol and i had to crawl under there and push the e brake off by hand,..only happened once cuz i never had to use it (auto)
cant remember exactly because this was prob 4+ years ago but this might of might not have had something to do with ripping doughnuts in empty lots in the snow
__________________
Old 11-04-2009, 10:00 AM   #11
water gets in, temperature drops, the cable gets stuck, simple as that
__________________
Old 11-04-2009, 10:11 AM   #12
The manual is a bit vague as to where the adjustment is located but it appears to be at the center console. I uploaded a 2 page pdf to http://home.comcast.net/~ahearn4john/br.pdf if you want to see it. I would check the rear brake actuation as well.
ajahearn is offline   Reply With Quote
Old 11-04-2009, 11:08 AM   #13
IDK
amansour14 is offline   Reply With Quote
Old 11-04-2009, 11:22 AM   #14
I need help please ...
Old 11-04-2009, 11:22 AM   #15
I have 2002 nissan maxima ... se ..
Old 11-04-2009, 11:24 AM   #16
H.M.F.I.C
MidN1te's Avatar
wats the problem there lil guy?
__________________
Old 11-04-2009, 11:26 AM   #17
what should I do??
Old 11-04-2009, 11:27 AM   #18
My left back door is locked and I can not open the door from inside and outside ...
Can not open from inside because the child lock is on ... but from outside I think because the door handle ..
Now If I got this handle, can I replace it while the door is locked? Is this is possible .. can you send instruction ( how to install it ) with the handle?
Old 11-04-2009, 11:27 AM   #19
H.M.F.I.C
MidN1te's Avatar
wats the problem?
__________________
Old 11-04-2009, 11:28 AM   #20
H.M.F.I.C
MidN1te's Avatar
damn dood... that sucks! hahaha...
you can't take off the panel huh
__________________
Old 11-04-2009, 11:29 AM   #21
the door is locked
Old 11-04-2009, 11:30 AM   #22
H.M.F.I.C
MidN1te's Avatar
Quote:
Originally Posted by amansour14 View Post
the door is locked
well jeez unlock the door
__________________
Old 11-04-2009, 12:10 PM   #23
first..dont bump your thread count by clogging up someones thread in order to get your count up to start a post,..you will get banned from here..
second.. that really sucks,.. if the child lock is on and the handle broke from the outside,.. at least its not the drivers door..,.. i would suggest a few things.. maybe try and take the door panel off from the inside to gain access to move the lever manually, either the unlock lever or the security lever...if that doesnt work..maybe you can fish for the lock with a jimmie but im not sure if it would work with the security lock on,.. other then that it might be the dealers nightmare lol...
__________________
Old 11-04-2009, 01:00 PM   #24
Thanx guys, I got the hand brake problem now. but does anyone know wut is wrong with the interior light?
Old 11-05-2009, 12:01 AM   #25
for my first problem, I had read many threads, it looks like either the BCM, body control module, or the relay... does anyone had experience with it? please let me know what the symptom is and where could you find the part? thank you
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
