5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
What's the gear ratio/configuration of the 6-speeds?
For the 2002 3.5 6-speed, what's the gear config? Are they 4 under-drive, 2 over-drive? Or 5 under, 1 over?
While I'm axing newbie questions - about how much scratch should I plan on dropping on a short-throw aftermarket and are they an easy DIY installation?
you literally just beat me to it. STS mod has worked for every 5.5 owner and they will all tell you its the same if not better than an aftermarket shifter
__________________ 2000 Maxima SE
l Berk w/ APEXi Filter l 17* Advanced Timing l Grounding Kit l Vibrant FSTB l Custom RSTB l Rockford Fosgate- Infinity- Pioneer l Smoked Sidemarkers l AE Headlights l Rear License Plate & Trunk LED lDDM 5000k/ 3000k Fogs
NEXT MOD: CUTOUT
never tried the free sts so i cant speak on that,.. but i have done the ralco rz short shifter which is a breeze to install..and only cost ~57 bucks from cattman on here...
your also going to want the Energy Suspension 6 speed bushings.. amazing difference...
Here's a great site with tech specs on all Nissans. It gives you specs, TSBs, recalls, reviews and all sorts of info going back to 2001. http://www.nissanhelp.com/Models/
I've got one of the first HP Autoworks short throws that came out about 4 years ago. There are a lot more choices out there now including the "free STS" mod. The install or mod isn't very hard. If you look through the "how to" stickies at the top of the 5th gen forum you'll find the info. It's worth it on these cars.
__________________
2K2 SE 6 speed w/leather, sunroof and Bose : HLSD tranny from 2004 car, Fidanza 15lb flywheel, 350Z clutch, Hotshot headers, Warpspeed B-pipe, PR CAI, homemade VAIS blockoff plate, Apexi S-AFC2, 17 degree timing advance, HP autoworks STS, PR solid motor mounts, PR shifter bushings, FSTB, RSB. Eibach springs with Ilumina 5-way adjustable struts, 16.5 pound Enkei Wheels. Over 145,000 miles. I turn my own wrenches.
