5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Oil light on but dipstick reads full - please help
As I was pulling into my garage today my oil light came on. I immediately shut down the engine and checked the oil. I just had it changed less than 500 miles ago and it showed full on the dipstick. No oil spots on the garage floor, and no evidence of any leaks underneath. I have been driving in deep snow/icy conditions the last couple of days, and was worried I might have hit something underneath, but I can't see any damage. Since everything looked fine I started it up again to see if the light stayed on, and it did. Any thoughts? Anybody had a similar issue?
Thanks in advance.
__________________
Currently:
'02 SE 6-Speed Pearl - XM MyFi, Luminics yellow fogs, Parrot CK3100BT
'01 Sequoia 4x4 to haul the kids, 9" Headrest Monitors, Audiobahn DVD
Way back in the day:
'95 GLE - 17" Masitaly Axels w/ SP5000, H&R/Tokico, Stillen Intake ,Cattman Y, FSTB, Porterfield pads, 35% tint
Is it making alot of noise? You'll usually hear lots of knocking and timing chain noise if you have no oil pressure. on checking the oil pressure sensor, might be alot of salty water in the plug.
__________________
Gatorade on my keyboard FTL.
5th & 5.5 gen VLSD Auto transmissions for sale, PM me.
I too would check the oil sensor. Recently replaced my cv axles and noticed that sensor isn't the strongest connection...it's pretty easy to pull off, so it's plausible it just came undone.
Like mentioned before, don't drive the thing until you get it fixed. I threw a rod through my dads Jaguars oil pan over a decade ago because the oil pressure light started flashing and I didn't stop in time.
I wouldn't run it until you make sure it has oil pressure.You could turn a bad oil pump into a bad motor.
A++++ advice. I wish I had it. This is why I now have a different VQ than original. Then again, I used it to justify a new "exhaust manifold" (the kind with equal-length bends) to the wife.
There wasn't any valve clatter or other indication that oil wasn't getting to the motor (and I know that sound from past experience) and the car only has 80k miles, so I checked the sensor and cleaned up around it a little. I also replaced the battery which died after 10 minutes with the headlights on, which I had been meaning to do this weekend anyway since it had been showing signs of weakness. The end result is no more oil light. Hopefully it will stay that way, but my next step will be to hook up a mechanical oil pressure gauge if the light comes on again to see if it is the oil pump or just a bad sensor.
Thanks for the helpful advice. It might be time to buy something with a little more ground clearance if I'm going to keep living in the Rockies - got a smashed foglight too, and last winter I lost a sidemarker.
__________________
Currently:
Just a FYI, If the sensor is unplugged the oil light does not come on. I have not had me sensor plugged in for some time now, no oil light at all. If the sensor is faulty it could be the reason.
__________________ Co-Owner and Founder of NYCNissans.com
