Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-31-2009, 10:33 AM   #41
H.M.F.I.C
MidN1te's Avatar
the only thing i could think of replacing right now besides the mounts.. is the wheel bearings and hubs... i'm getting a slight humming noise as the speed increases... i've this problem on my s2000 in the rear so its sounding familiar...faint..but familiar...
thats why i figured i would replace those.. i dont think there is anything wrong with other stuff... so i normally dont replace until things go wrong...
but in my years of being a mechanic.. both in the Army and out... preventative maintenance is the best maintenance...If you up keep things, less things to go wrong...
not worried about this maxima so much at all.. but on a turbo s2000, its crucial...
__________________
My Babie with my Baby. Turbocharged S2000
MidN1te is offline   Reply With Quote
Old 10-31-2009, 10:33 AM   #42
Quote:
Originally Posted by Rochester View Post
...and the ball joints, and the tie-rod ends, and the radiator, and the brake lines, and the alternator, and the MAF...
I forgot to mention the oilpan, but only because mine is nasty.
__________________
NWP phenolic intake spacers, Cattman y-pipe, Cattman 2.5" cat-back, Frankencar short-ram intake, Apexi pop charger, UR crank pulley, ES motor-mount and sub-mount bushings, Racingline FSTB, Progress RSB, STS mod w/ES bushings, Brembo blanks, Hawk ceramic pads, Goodyear Eagle F1's -- 54,000 original owner miles
Rochester is offline   Reply With Quote
Old 10-31-2009, 10:36 AM   #43
H.M.F.I.C
MidN1te's Avatar
What's the (approximate) parts & labor cost for a job like that, Ghost?
well personally i've found deals like $327 for 2 wheel bearings and 2 hubs.. go to advanced auto... rent the bearing press... do it yourself.. i do... saves alot of money and its easy.
__________________
Old 10-31-2009, 12:11 PM   #44
Toolie
knight_yyz's Avatar
Quote:
Originally Posted by MidN1te View Post
i'm wondering if that maybe my next project then...I'd like to go ahead and replace the wheel bearings whether i need them or not...
but that's in due time... first i wanna make sure the mounts fix my issue...
did you by any chance dyno the headers and bolts on FIRST before you tuned? becuase i'm wondering how much more power did the tune make after the initial install of headers and stuff.
Run one is stock, run 5 is headers no tune, run 9 is headers tuned, run 12 is spacers and 06 tranny swap tuned.
__________________
6MT | 06HLSD | I/H/E & FC | Stillen FSTB & RSB | Eibach Pro Kit | Illuminas | Watkins STS | UDP | NWP Spacers | Greddy Blue | ES Bushings
253.50 fwhp
249.75 lb/ft tq
14.3 @ 101mph (street tires, bad wheel bearing and a few spun tranny bearings)
knight_yyz is offline   Reply With Quote
Old 10-31-2009, 12:33 PM   #45
H.M.F.I.C
MidN1te's Avatar
So the tune didnt help so muxh with the hp but more tq. Wat spacers did u say u had? Wat kinda spacers do u have and where do they go? Are u talking bout intake manifold spacer?
__________________
Old 10-31-2009, 01:23 PM   #46
I had my brakes and rotors all replaced at the same time, but it would be between 400-500, your looking at approx. 90.00 each for the bearings they will need to be pressed in so another 80.00 a couple hours shop time approx. 90.00 per hour and then another 100.00 for an alignment ... just ball park numbers Rochester but you get the idea.
__________________
2003 Sterling Mist 3.5 SE /Llumar tint 20%/20%/20% /Racingline FSTB /Custom Intake /BPI Velocity Stack /*17 Advance /HID Plazma Xenon Fogs /2x10 Fosgate Subs & 1000w amp. /Falken ZE912 235/50/17 OEM rims /Budget B pipe & Vibrant Exhaust - Deleted Resonator /LED Underbody Lighting /Blue LED Interior Lighting /Chrome Rings Gauge Cluster /Viper Security /F&R Motor Mount ES Bushings & Sub Bushings /Sm Markers /KYB GR2's/S-Techs
Ghost_54 is offline   Reply With Quote
Old 10-31-2009, 01:28 PM   #47
Quote:
I do. Thanks for the perspective.
__________________
Old 10-31-2009, 01:29 PM   #48
Tuning also helps in making the overall engine perform at its peak performance, improving fuel efficiency by tuning the air to gas mix, so tuning isn't always about horse power and torque.
__________________
Old 10-31-2009, 01:34 PM   #49
Toolie
knight_yyz's Avatar
Nothing I have done after the headers has improved PEAK horsepower, but look at the range between 2k and 5K and see the difference. The spacers I'm talking abut are the NWP phenolic spacers
__________________
253.50 fwhp
249.75 lb/ft tq
Old 10-31-2009, 01:35 PM   #50
Yes, replacing the intake manifold gaskets. Here's the seller:
http://www.nwpengineering.com/Phenol...rs.html#VQ35DE
And here's the whole, huge development thread from start to finish:
Phenolic Spacer Development for VQ35s
And here's my thread from this summer. I gave those spacers a long, hard look before pulling the trigger. Very, very happy that I did.
Seeking long term assessment on NWP Spacers
__________________
Old 10-31-2009, 08:44 PM   #51
H.M.F.I.C
MidN1te's Avatar
Yeah i see the graphs. Where did u get the car tuned? I dont have a dyno graph of my turbo s2k but it literally has such a straight line u could write ur name on it. But i have a full aem 1052-u stand alone. Overall does the tune make the car feel that much better and powerful? Or is it the buttdyno and psychological mind thinking its improved. Again i see the graph but its not smooth. But then again the stock run wasnt either
__________________
Old 10-31-2009, 11:57 PM   #52
Toolie
knight_yyz's Avatar
it's not a flat line because of the VIAS butterfly. Dips at opening and closing.
Car was tuned in Burlington Ontario, DL motorsports. And yes it feels way more powerful through the low end and midrange. I can light up the tires in second and third.
__________________
253.50 fwhp
249.75 lb/ft tq
Old 11-01-2009, 04:52 AM   #53
H.M.F.I.C
MidN1te's Avatar
No i meant that the squiglyness of the lines...looks like serrated edge of a knife...
I think i've heard of DL motorsports... A couple of s2000's were tuned from there and i dont remember lines looking like that...I'm assuming its just the maxima then.
I do definately see the gains though and man thats so promising. How do you like your emanage? I was debating on doing the techno square and just having it reflashed...Obviously an individual tune from a piggy back would be the most beneficial because as you would know, all cars are different.
I'm auto, and if your lighting up the tires in 2nd and 3rd, i better get the valve body mod because my tranny is gonna die lol... my first maxima did the same which was an 02 and my tranny that came with the car died...this is my 2nd tranny.. its a low mileage tranny and works like its supposed to so i think i should take the step to do the valve body mod and have it rebuilt to shift quicker...specially with gains like yours..
Do you know or remember the name of the dyno that DL motorsports uses? judging by ur numbers i'm assuming dynojet or something similar...
if its a dynodynamics, i'd be going crazy happy because that is one of the lowest reading dyno's..also known as the heart break dyno...if you can push those numbers on THAT dyno... then i will Bow gracefully to ya hahahaha..
well u are one of my inspirations and i cant wait to do this. because techincally your pushing over 300 to the crank.
so let me ask.. the intake manifold spacers... i haven't clicked on the links yet, but i'm assuming its the same method to taking it off as if your gonna change the rear spark plugs right? because i did this and it took me 20 min to do... and i can do it all at once.
__________________
Old 11-01-2009, 04:58 AM   #54
H.M.F.I.C
MidN1te's Avatar
hahahaha nevermind.. i just saw the instructions.. thats alot more involved than i anticipated...
__________________
Old 11-01-2009, 01:19 PM   #55
Toolie
knight_yyz's Avatar
DL motorsports uses a dynojet. And there are always neons and s2000's and mr2's getting turbos slapped on their cars there. I even saw a turbo viper there pushing 900 whp when I went for my last tune.
I'm pretty sure the jaggedness of the lines is the ecu pulling timing, but maybe an all motor guru can step in to confirm that
__________________
253.50 fwhp
249.75 lb/ft tq
Old 11-01-2009, 07:27 PM   #56
H.M.F.I.C
MidN1te's Avatar
So what other mods do you have?
i'm looking at the phenolic spacers, ssim, and the block off plate as well..
just wondering if its really worth all of it..
__________________
Old 11-02-2009, 07:44 AM   #57
Toolie
knight_yyz's Avatar
custom intake, cattman headers, cattman fastcat, cattman exhaust, fidanza flywheel, stage 1 clutch, spacers, and a tune. I have a custom short ram BBMAF hybrid with flow stack, larger injectors and a block off plate to install next year.
__________________
253.50 fwhp
249.75 lb/ft tq
Old 11-02-2009, 07:51 AM   #58
H.M.F.I.C
MidN1te's Avatar
nice... i'm definately gonna be there well close to it hahaha
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
