5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
One of my fans is loose (fan blade wobbly) and making a lot of noise and vibration. I would like to replace or repair.
Looking at the FSM under LC-17, the fan assembly is only held by 2 bolts. So it looks feasible to remove it for trouble shooting without radiator being removed.
My suspicion is that the bolt that holds the fan is loose.
Has somebody removed the fan assembly only and not remove the radiator?
This thread details replacing/removing the radiator and fan as a whole, but you might be able to use it as reference to locate the fan bolts and where it's attached to remove it.
yes, I had one fan go out on me in the past. really easy to remove. no need to remove radiator.
How did you know one of the fans had failed? Was there a CEL?
And OP, please use default font and color when posting. Your entry is only legible when using the forum "dark style" theme. It's pretty much invisible otherwise.
__________________
NWP phenolic intake spacers, Cattman y-pipe, Cattman 2.5" cat-back, Frankencar short-ram intake, Apexi pop charger, UR crank pulley, ES motor-mount and sub-mount bushings, Racingline FSTB, Progress RSB, STS mod w/ES bushings, Brembo blanks, Hawk ceramic pads, Goodyear Eagle F1's -- 54,000 original owner miles
Removed the radiator fan shroud last night and yes it was easy. But have to remove the air intake and the upper hose (plan on spilling some coolant, stuff it with something, both the radiator and the hose to limit the spill) to ease out the shroud, do not fight it.
There will be a hose in the bottom and top that you need to yank out and 2 motor connectors unplugged.
Tore down the suspect fan, bolt was not loose, it is indeed the motor that went bad.
Have checked around for a replacement motor, cost wise, better to get the whole shroud replaced (cheaper). Fleabay has a few of them. Some folks have purchased them and replacement was a breeze, plug and play. Some have gone to the junkyard and picked up a set, pretty sure it will be cheaper that way, but you time is valuable, too.
When you start hearing a noisy fan and some vibration coming from the front when the fan is on…it is your fan shroud.
The fan assembly from fleabay came in and took me 15 minutes to swap it out, with a little coolant loss. Went well with practice.
Turned on the AC and the fan was running quietly. Noise and vibration solved.
Plug and Play. Was looking at a motor replacement for 1…$160 was the cheapest. Crud! The whole assembly was $87 shipped!
