5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
my driver side door seems to be hanging low, where the lock is hitting the strike ring (if that's what its called). There isn't any signs of scraping on the door or door frame. If the door is closed gently, you can feel it hitting something before it actually hits the lock. If any of this makes any sense, I guess can the door be raised or adjusted. thanks
I cut two shims out of plastic milk jugs, same size of the plate of the bottom hinge of the door that attaches to the car body, made holes to match those of the bolts on that same plate and sandwiched them between it and the body of the car.
Edit: Sorry, I meant to say that shims go between the part of the bottom hinge that attaches to the door (not the car body).
I have the same problem. I was going to adjust the striker plate, lower it down but the screw would not budge.
The hinge can be adjusted but looks like you have to remove the fender to get in there?
This banging of the door is so annoying and the sound hurts the ear. It is supposed to be a thud...but instead it is a long bang. And half the time the door is not closed and have to re-close it.
Sucks.
We need a repair on this, how did this work, see bottom? Good? So you shim the bottom hinge? How does that help with the mis-alignment? Thanks.
Sucks.
Yes, I shim the bottom hinge only, and I meant to say that the shims go between the part of the bottom hinge that attaches to the door, not the car body, as I stated in my previous message, which I just edited, BTW. The shimming would raises the door up in a way that is like rotating it around the top hinge, bringing it closer to alignment.
Got it Nelsito. You ended up taking the door down I take it. Put the shims in and solved the problem. Probably a steel shim is much better? The plastic will compress in time?
Let me repeat:
Shim the bottom hinge (attached to the door) with 2 plastic jug material.
just last week i solved this problem. I think i did it the hard way, but i unbolted the hinges from the door and had a friend hold on it it while it was still electrically attached. then i loosened the hinges from the body and they have a little bit of play in them once loosened. For me i adjusted them slightly upwards, tightened everything back down and it closes perfectly now. It all took about 10 minutes. I set up a jack with a pad on it for my friend to balance the door on too, because it starts to get heavy.
I think you can take for front quarter panel off and get to the screws that hold the hinges to the body and it would probably be much more precise but i got lucky and got them right the first time.
Another note for those needing to buy new hinges because theirs are sagging. The hinges have an "L" and an "R" on them this does NOT correspond with left and right side, i have no idea what it means but each side has an L and an R hinge
__________________
00' SE 5 Speed/ Cattman Muffler/ Warpspeed Y/ 17º advance/ 5% tint all around/ 6000K HID's all around/ Hawk HPS's all around/ FSTB/ Alpine HU/ Alpine Type R speakers
yup..this is very common on many nissans-my 88 stanza did it, my 98 alti and now my 02 max (tho the wifes 01 is sturdy as can be-figures). anyway, its the hinge pins-they are soft and wear with use so usually its the drivers door is first to go. did hinge pins on the alti and it fixed no problems.
I had not considered the shim idea and I like it-may give this a shot.
Did you access the hinge bolts on the body? If so how? What wrench did you use? I thought the only way you can do this is to take off the qtr panel.
Hence the shim on the door side hinge was an easier fix.
Did you read any of what i wrote?
I took the door from the hinges then got to the body side bolts.
It seriously only took 10 minutes to take the door off adjust the hinges and put the door back on
__________________
mine does the same thing. Its been like that since i bought it
It took me almost a year to do anything about mine. I bought a Subaru for the winter and have been fixing little things on that so i decided to finally do this. I wish i had done this a long time ago, my door finally feels like it shuts smoothly
__________________
I was planning on putting these washer-shims on the bottom hinge, door side.
I would use the plastic shims. You only have to loosen the two bottom nuts and have someone pick door up. Plus plastic will not rust or scratch paint. I did mine and used aluminum shims.
feldman u are the man! im doing this tomorow ive been so sick of this for 3 years!
__________________
BIGPOPAJ369
SEXIMAbadge,black w polished lip rims,rain guards,SRI,painted spark plug cover,AE'd heads w/luminics bulbs,rewired yellow tinted fogs w/out glare guards,polarg blinkers/reverse/plate lites,tinted n rewired sidemarkers(blinker mod),painted interior trim,all interior lights to led,AB clock mod w/white display,red leds in climate control w/white display
just so you know you are going to want to set something up so whoever is helping you can just rest the door on top of it. I used a jack with a towel folded up on top of it. That way they just have to balance it. I also put a towel in between the door and the quarter panel so the door wouldnt scratch it if my helper got lazy
__________________
If the hinges on these cars are just like any other, they sell the pins with the washers in the help section at the parts store. I had a t-bird where the door sagged and I purchased the help kit, used a grinder to cut the old hinge pin out and replaced it with the new one.
In the hole were the two hinges are connected by that pin, there is a copper washer that slides in between the pin and the hinge hole. Over time the washer wears out and the door saggs. Not too hard to do if you have a floor jack and someone to hold the door up. If you dont have someone to hold the door get some rope and roll the window down, tie it to the door and the other end to a ceiling beam in the garage if you have one.
There should be adoor hinge bushings I would check those first they are brass and weak and commonly need to be replaced I'm pretty sure all cars have them if not it's most
ok ya ill def do the same thanks bro!
__________________
BIGPOPAJ369
Well, I did my sagging door problem fixed by installing the washers-shims. Nothing to it. However, the real issue is the washer-pin wearing out. I will get them and will replace them. That's the real solution.
For now, it is closing with a solid thump. not unlike before...ka-blang and you needed to bang it.
Thanks for the tips. But replace the pins-bushing, that's the right thing to do as mentioned above.
