Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-12-2009, 05:24 AM   #1
NissanMan97's Avatar
Send a message via AIM to NissanMan97
car did something strange
i was driving to work this morning, going across a fly over on the expressway and as I was downshifting my car went dead...sorta. the oil light, brake light, battery light and check engine light all came on and my power steering went out. i had the clutch pedal pushed in the whole time and was freaking out. just when i came over the top of the fly over and decided to coast it to a stop i released the clutch and the car was fine. I dont know whether the engine shut off or not because i was freakin a little but i dont think it did because the car didnt jump like i had popped the clutch or anything.
WTF?!?! can some help me out with this.
B
__________________
02 Maxima SE 6spd w/HLSD
Mods - Stillen high flow intake, Fog light rewire, Ralco RZ STS kit and ES shifter bushings on the way
Future Mods - Brembo blanks, HPS pads, SS brake lines, ES suspension bushings, Eibach springs, Koni Yellows
Past cars
97 Maxima SE 5spd, FSTB, RSB, A4 Projectors, full audio overhaul -Totaled
96 Probe GT auto, CAI, full cat back, custom header - sold
94 Probe GT auto, full audio overhaul - Totaled
93 Altima 5spd, CAI, headers, full catback - totaled
NissanMan97 is offline   Reply With Quote
Old 10-12-2009, 08:26 AM   #2
I'm assuming the car still runs... Maybe a belt broke???
6SPD02SE is offline   Reply With Quote
Old 10-12-2009, 08:30 AM   #3
Quote:
car runs fine now...only 2 things ive done since i bought it are change the oil (switched to Mobil 1 full syn) and cleaned the air filter (k&n cleaning ****...not fun so im buying a new intake system when i get the money)
B
__________________
Past cars
Old 10-12-2009, 08:48 AM   #4
Quote:
The MAF on the Maxima seems to be wicked touchy, which is one of the reasons I went with a dry filter pop charger (Apexi).
I have zero insight into your problem, but your mention of cleaning the air filter made me think of that, is all.
__________________
NWP phenolic intake spacers, Cattman y-pipe, Cattman 2.5" cat-back, Frankencar short-ram intake, Apexi pop charger, UR crank pulley, ES motor-mount and sub-mount bushings, Racingline FSTB, Progress RSB, STS mod w/ES bushings, Brembo blanks, Hawk ceramic pads, Goodyear Eagle F1's -- 54,000 original owner miles
Rochester is offline   Reply With Quote
Old 10-12-2009, 08:55 AM   #5
that is a good point...is this one of those things that i need to just watch it? i do i need to start disassembling the intake and have a look around?
B
__________________
Past cars
Old 10-12-2009, 09:08 AM   #6
are any of the lights still on? if you toasted your maf from the k&N the car wont rev past 2500 rpms iirc..
__________________
2K2 SE 6 speed Grey Lustre SE Every option minus navi, black leather, HLSD, Hotshot headers, Cattman Catback, Frankencar WAI, HP autoworks STS, ES motor mount inserts, ES shifter bushings, FSTB, RSB. JIC FLA-1 coilovers, A34 Brakes Hawk HPS pads, TR Motorsports MT1's, Toyo 4s, 64,000 original owner miles.
HotshotVQ35 is online now   Reply With Quote
Old 10-12-2009, 09:13 AM   #7
Quote:
no lights on at all...went to make a run for work and put it to the floor revved to 4k no prob, shifting fine, starting fine and sounds fine...ill let it sit for a while and then go take her out again to see what happens
B
__________________
Past cars
Old 10-12-2009, 09:22 AM   #8
Doubt it. I'm imagining something touching on the MAF sensor after cleaning that filter, and then dislodging or evaporating or whatever.
But honestly, I'm pulling that concept out of my ***, (which itself is a crazy image.) All I know is that I would never "clean" an air filter, even though it's designed to be cleaned, and people do it all the time without issue. But that's just me. I'd rather buy a new one.
That's my 2 cents. Probably not even worth 1.
__________________
Old 10-12-2009, 09:26 AM   #9
its worth the 54 bucks that a K&N filter cost in my opinion.
here is a question you might be able to answer, will an apexi filter or similar work on the stillen intake? ill take a picture of it if i need to so you can see it, that way it will eliminate the need to clean it...ever!
B
__________________
Past cars
Old 10-12-2009, 09:32 AM   #10
I don't know. Research the diameter of the intake and the filter neck.
Well, if by "ever" you mean, until you replace it... then yes. The apexi is (generally) considered a better design over the K&N pop charger, but it's also very expensive. Worth it, IMO.
There are a bizillion threads on that topic.
__________________
Old 10-12-2009, 09:39 AM   #11
id rather replace the clean...the cleaning process what a *****, and the oil gets everywhere.
ill look up up the apexi...thanks.
B
__________________
Past cars
Old 10-12-2009, 11:22 AM   #12
Don't you know who I am?
Rydicule's Avatar
Send a message via AIM to Rydicule
B
Honestly, it sounds like a stall and pop from what you've said here. If you lost power steering and then got it back, I'm pretty sure the engine must have shut down. The only other experiences I've had losing power steering, it doesn't just come back without fixing a leak or replacing a belt.
I can't say I've ever pop started my car, so I'm not sure that it would "jump" or "jerk" if you did... however, I can say I've released the clutch with it still in gear when I thought it was in neutral () and the car jerks like hell.
Not really sure why the car would have stalled... I can say the K&N cleaning is a bit of a delicate process. I've been doing it for 5 years now, and I have 2 filters so I just swap them out every year. That way, the oil has a year to dry so as to not cause any damage (however, the jury is still out as to whether K&N oil actually does cause MAF sensor damage).
My inclination would be to just drive the car and hope it was a one time fluke. If it happens again, have it checked for codes... always the first place to start.
Rydicule is offline   Reply With Quote
Old 10-12-2009, 11:26 AM   #13
thanks...will do. the 2 filter thing is a good option as well.
B
__________________
Past cars
Old 10-29-2009, 06:26 AM   #14
ok so im dragging this back to the top cause the car did it a second time after 2 weeks. I was getting on to a ramp and I pushed in the clutch to down shift and it died. Let out the clutch and it started up and was fine.
Ive been reading and asking questions and so far ive come up with: MAF, Idle sensor, A/F ratio, Alty and possible corrosion in the power/ground lines.
im guessing what happens is that maybe im taking to long to shift and the car is idling down to far and dying. if that is so should it do that? to my little knowledge it shouldnt but again im messing with a different engine than Im used to from my 4th gen.
I really want to figure this out because its ****ing scary when it happens.
B
__________________
Past cars
Old 10-29-2009, 09:01 AM   #15
Send a message via MSN to J-Rod
What octane gas do you use?
__________________
Jarrod
2000 Maxima SE
White Pearl
5-Speed, short throw shifter
Dropped on Progress Springs & KYB GR2 Struts
True CAI
Unorthodox Underdrive Pulley
CustomMaxima.com Front Strut Bar
Sarona Design Full Body Kit... still in attic
J-Rod is offline   Reply With Quote
Old 10-29-2009, 09:42 AM   #16
Quote:
93
B
__________________
Past cars
Old 10-29-2009, 10:01 AM   #17
Check your battery cables, ect to see if they are all tight. Its possible it could be a loose connection somewhere.
SmokinMax01 is offline   Reply With Quote
Old 10-29-2009, 10:17 AM   #18
Quote:
i thought that...battery cables are fine....a loose connection (at least in my experience would happen more often).
alty is running fine and battery is good
B
__________________
Past cars
Old 10-29-2009, 04:30 PM   #19
Puerto Rico-Maxima Lover
Lontar1's Avatar
the car just farted...
__________________
AT TRANNY FLUSH
http://www.cardomain.com/ride/335521/3
Lontar1 is offline   Reply With Quote
Old 10-29-2009, 05:05 PM   #20
Bad *** Newb
Child_uv_KoRn's Avatar
Non oiled filter FTW. I think nearly everyone that tries an oiled filter kills their maf sooner or later.
Child_uv_KoRn is offline   Reply With Quote
Old 11-01-2009, 12:27 AM   #21
I had something similar; it died on me in gear, so I pulled over, started up fine, parked. But then when I was pressing the key fob to lock it, no response first thought was battery? I checked it out....the positive terminal ring was cracked from corrosion, if it wasn't for the remote key, I would have never thought to check the battery. Hand the K&N filter before, oily not good, back to OEM.
__________________
coldfear13 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
