After replacing axle, car vibrates
Old 10-06-2009, 06:13 AM
Puerto Rico-Maxima Lover
Lontar1's Avatar
Replaced both axles and now the car vibrates on acceleration... the car aligned and the tires are balanced. everything is ok under the car.. where should I look first?
Lontar1 is offline
Old 10-06-2009, 07:22 AM
MROTH's Avatar
did you get remanned axles? my buddy is havin the same issue in his 03 TL-s.
MROTH is offline
Old 10-06-2009, 07:33 AM
Lontar1's Avatar
Yes, the mech got them from autozone.. I guess
Lontar1 is offline
Old 10-06-2009, 07:41 AM
MROTH's Avatar
i honestly dont know if that is the issue but, my buddy has an 03 tl-s with a pretty aggressive drop. at about 105k the original axles started vibrating very bad under acceleration, rolling the car was fine but anytime you were on the throttle it would vibrate heavily. we purchased remanned axles, popped them in and within 1,000mi the vibration came right back, returned them to the company that did the work and they gave us two new axles, installed the second pair and about 2 weeks ago the vibration came right back. we have since then installed brand new (not remanned) axles from a different company and havent had the issue come back yet..... if you do buy new axles i would personally recommend raxles.
MROTH is offline
Old 10-06-2009, 07:48 AM
ghostrider17's Avatar
So - out of curiosity, why'd you replace the OEM's??
Also, can you describe the vibration??
Been having an issue with mine for a while (vibration) and wondering if it's a bent (pass) axle.
Can't help you with your issue -- but curious to hear more about yours!
gr
ghostrider17 is offline
Old 10-06-2009, 07:57 AM
MROTH's Avatar
gr
the reason i replaced my axles was because the passenger side was bent, i thought for the life of me my wheel wasnt balanced....installed raxles and now shes smooth as silk
MROTH is offline
Old 10-06-2009, 08:29 AM
Maybe I haven't been keeping-up, but last time I checked...the Passenger Side Raxles Shaft wasn't available!?!?!
Can you clarify if this is actually avail now?!
No way I'm going back to OEM, especially for the $$$.
gr
Old 10-06-2009, 08:52 AM
MROTH's Avatar
im not sure if they have them available or not.. call them @ (800) 257-8192....
ya for the $ i would def recommend getting the raxles. every piece of the axle is brand new. no re-used parts
MROTH is offline
Old 10-06-2009, 09:20 AM
Lontar1's Avatar
gr
the vibration is only under acceleration after that the car runs ok but with a small vibration, I replaced the OEM's due to leaking out of the boots, I should have replaced only the boots....
Lontar1 is offline
Old 11-17-2009, 09:20 AM
MROTH's Avatar
did you ever get your vibration taken care of?
MROTH is offline
Old 11-17-2009, 05:11 PM
Lontar1's Avatar
The mech replaced the axles three times to shut me off.. and still have the vibration. replaced passenger side Illumina with a new one, rebalanced the rims and align the car again.. still the vibration, won't go away. At this point taking the car back one more time to replace an engine mount.. after that if it doesn't go away.. i wil be parting out the car and getting a new one... **** it am tired of this crap.....
Lontar1 is offline
Old 11-17-2009, 06:28 PM
mandyfig's Avatar
Sorry for the crap...must be terrible to be in and out of the shop!
mandyfig is offline
Old 11-17-2009, 06:37 PM
MROTH's Avatar
i just began getting minor vibration under acceleration and i think its my axle. pissin me off!
MROTH is offline
Old 11-18-2009, 05:50 AM
Lontar1's Avatar
trust me everything was fine until I replaced the axles for this GSD or something like that crap.... I hate China products, but now everything is made in China.....
Lontar1 is offline
Old 11-18-2009, 07:10 AM
Phantom-V's Avatar
i can tell mine are blow because i have resedue all in the inner part of my rims. Just black and gunky. only hear something when im turning also. really hard. mine doesn't vibrate though, atleast i don't think so. I hope you can get it fixed. with any car...there is always something wrong.
Phantom-V is offline
Old 11-18-2009, 08:43 AM
vastmax's Avatar
dont buy reman'd axles, especially from Napa or AZ. I would reccommend either Raxles or these:
http://www.carpartswarehouse.com/add.../90-01236.html
http://www.carpartswarehouse.com/add.../90-02057.html
Both Axles, brand NEW for less than $200. No core charge either... Do it right the first time.
vastmax is offline
Old 11-27-2009, 08:57 AM
Lontar1's Avatar
vibration gone after replacing the motor mounts.... my meh just replace them today
Lontar1 is offline
Old 11-28-2009, 07:19 PM
exodusx187's Avatar
did you get all the mounts replaced? if not, which ones? was your steering wheel vibrating before you replaced the mounts?
exodusx187 is offline
Old 11-28-2009, 07:24 PM
Lontar1's Avatar
my bad.. the vibration came back and the clunck came back again... so there is have to be something else. I'm done with this car... so as soon as I can and afford.. will be getting something diffeernt.. will see the part out of the car pretty soon.
Lontar1 is offline
Old 11-29-2009, 09:08 AM
exodusx187's Avatar
d@mn thats crazy. i can feel the vibration from about 1500-2500 rpm and it steadily goes away after that....mostly when i shift from 2nd to 3rd gear and above 3000rpm it feels smooth again.
Old 11-29-2009, 09:28 AM
Lontar1's Avatar
Im kinda giving up on it... it is anoying... and seems like no one can find out what it is
Lontar1 is offline
Old 12-15-2009, 10:49 AM
timmyg1's Avatar
Mine vibrates after new axles just a bit during accelleration. I guess it pays to get Nissan Parts sometimes
timmyg1 is offline
Old 12-15-2009, 11:28 AM
The Whistle go WOOOOO
Weeble1's Avatar
From what I remember, the Nissan axles have a vibration dampener and when you go with OE replacements they don't. Which is why Nissan axles are so damn expensive.
Weeble1 is offline
Old 12-15-2009, 11:50 AM
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
sparks03max's Avatar
Like others have said, sometimes buying cheap parts comes with consequences. In this case, it's vibration.
Blaming it on the car manufacturer (or the car itself) and selling it to buy a new car is ridiculous. As soon as you go replacing something on that car with cheap autozone **** and it doesn't perform as well as OEM parts, are you going to sell that car too?
I know if I replace axles, it will be Raxles or (if I really have to), OEM axles. Yes they are expensive, but considering they easily last 100+k miles... It's a worthwhile investment.
sparks03max is offline
Old 12-15-2009, 12:47 PM
jasonmax's Avatar
thats your cv joint blew, get a new one.
jasonmax is offline
Old 12-15-2009, 01:46 PM
SuperStasiu's Avatar
you guys ever think about the bearings inside the trans were the axles sit, heard it some times could be those
SuperStasiu is offline
Old 12-15-2009, 02:03 PM
Weeble1's Avatar
Couldn't have said it better myself
Weeble1 is offline
Old 11-07-2016, 07:42 PM
nicoyonkero's Avatar
Yo tambien le cambie las flechas y me dio el mismo problema pense que era las llantas pero me di cuenta que no.sucedio lo mismo con el carro de ni hermana.es un nissan roge2014 la flecha era de autozone.la regrese y nada mas le cambie la bota y asunto arreglado.
nicoyonkero is offline
Old 11-08-2016, 12:02 PM
jackman's Avatar
You just resurrected a 7-year-old thread mi amigo.
jackman is offline
Lakersallday24
06-16-2019 01:35 AM
kingw323
20
10-21-2015 08:36 AM
follyburr
08-12-2015 10:22 PM
classymax420
08-06-2015 06:35 PM
Quick Reply: After replacing axle, car vibrates
