Engine missing until totally warmed up
Help this problem happens with a cold engine.It runs like crap missing on a cylinder for about the first half hour until totally warmed up then it starts working normal.I do have a code scanner and pulled the PO320 code missfire on #4 cylinder but tested all the coils with a muti meter and they all test good.Anyone have an idea of what could cause this??
I'm assuming you mean P1320.......and you've got the P0304 by the sound of it. The fault detection on this is almost murphy proof with those two codes. I just went through this exact deal, only it was #5 cyl. Just go and buy yourself a left bank coil and change #4, and clear the codes and you're done. And as mentioned, you can test these coils with a mutimeter until the cows come home......they'll appear OK, but it means absolutely nothing.
97_GXE
09-15-2015 06:47 AM
