Starting Problem *i did a search and read up
Old 05-28-2018, 02:06 PM
FlaMark's Avatar
Hi Friends,
I used the search tool and did some research but am STUMPED???
03 Max, 3.5., 130k
Got a 6mth old battery and 3 yr old starter, and replaced cam sensor last year.
The Car is dead. Won't turn over, no click, no sound.
I do get lights, horn, and dome lights.
No dash lights and NO Radio.
ALSO WEIRD is when i turn the ignition to all the way ON, the shifter doesn't move. I push down on the release button, and can then move the shifter to neutral and back.
A friend and i tried to jump it and got nothing.
My first thought is the starter (its about 3 yrs old now), but the Radio and dash lights don't even come on???
I'VE ALSO noticed lately that the Analog clock is always running fast (like 1 hr fast every couple of days).
Wa Da???
What's the scoop...anyone have an idea?
Thanks for any constructive input you can offer...
~M
FlaMark is offline
Old 05-28-2018, 02:29 PM
Turbobink's Avatar
Neutral safety switch.
Will the car start while in neutral?
Turbobink is offline
Old 05-28-2018, 03:27 PM
FlaMark's Avatar
No
FlaMark is offline
Old 05-28-2018, 04:02 PM
Bad *** Newb
Child_uv_KoRn's Avatar
check fuses
Child_uv_KoRn is offline
Old 05-28-2018, 04:10 PM
FlaMark's Avatar
check fuses
Yes....both inside and under the hood.
FlaMark is offline
Old 05-28-2018, 05:55 PM
FlaMark's Avatar
SOLVED
I checked under the hood AGAIN, and noticed there is specifically a Ignition Fuse in the Right Panel box near the battery. I swapped it out with another, and BINGO the car starts.
That was weird. The dayum Fuse controlled even the dash lights and the stock car alarm.
Anyway,...thanks for the help!
FlaMark is offline
drstillpatient
06-20-2003 07:49 PM
phenryiv1
10-02-2002 09:23 AM
MaximaPower
06-05-2002 10:11 PM
Quick Reply: Starting Problem *i did a search and read up
