ecu removal
Re: ecu removal
Originally posted by kevc5
Can anyone tell me how to remove the ECU?
Thanks in advance.
Thanks in advance.
You will need to remove the small panel from each side of the center console that is located in each footwell. From there the screws are along the firewall and opposite side(center console). You need to pull the main connector which is secured with a 10mm head bolt..I think. When re-installing that make sure you snug the bolt down and not to over torque it otherwise you'll crack the plastic wire housing.
Good luck because it's about 30-45 minutes of work with you on your knees.
my03maxima
04-29-2020 12:48 AM
RealityCheck
10-02-2015 06:34 PM
