Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 08-11-2009, 09:23 PM   #1
Points: 8,296, Level: 61
Points: 8,296, Level: 61 Points: 8,296, Level: 61 Points: 8,296, Level: 61
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
How long should a manual transmission last?
I know this is sort of a hard question to answer, but whats the average lifetime for the 6 speed transmissions on the 02-03 Maximas?
Do they generally last the life of the car?
It obviously depends on how you drive the car and whatnot, but are syncros considered a "maintenance" item?
I've read the stories about the bad 3rd gear syncros, so I'm wondering if its only a matter of time before my transmission dies on me, because I have the 3rd gear crunch, actually more like the 4th gear crunch.
The reason I ask is that I plan on doing a clutch soon, so I'm trying to decide if I should just get a new transmission now to save money in the long run.
Unklejoe is offline   Reply With Quote
Old 08-11-2009, 09:36 PM   #2
Points: 11,854, Level: 71
Points: 11,854, Level: 71 Points: 11,854, Level: 71 Points: 11,854, Level: 71
Activity: 10.8%
Activity: 10.8% Activity: 10.8% Activity: 10.8%
02-03 Maximas' 6MTs are one of the weaker Maxima manuals.
From what I've seen/read on the .Org the syncros tend to have issues so if it's causing a problem go and buy the HLSD 6MT from an '04+ Maxima. No known reliability problems and shorter final drive should be more fun.
__________________
Mod lists are for the weak.
Maxima.org - the only place where the slowest guys keep their 'mods' top secret and require delta clearance to share.
Youtube
Administration Tuning - Builds & Executive Adventures
MoncefA33 is offline   Reply With Quote
Old 08-11-2009, 09:43 PM   #3
The opposite of bling
Derrick2k2SE's Avatar
Points: 8,638, Level: 62
Points: 8,638, Level: 62 Points: 8,638, Level: 62 Points: 8,638, Level: 62
Activity: 0%
The 02/03 are known for that. You could probably go a really long time like that if you had to.
You could look here http://car-part.com/ for a used 04/06 HLSD tranny. They have better syncros and are a direct swap. You should be able to get one with reasonable miles to your door for well under $1,000.00 and sell yours to a local rebuild shop for a few hundred. If you're going to swap the time to do it would be while you're doing the clutch.
__________________
2K2 SE 6 speed w/leather, sunroof and Bose : HLSD tranny from 2004 car, Fidanza 15lb flywheel, 350Z clutch, Hotshot headers, Warpspeed B-pipe, PR CAI, homemade VAIS blockoff plate, Apexi S-AFC2, 17 degree timing advance, HP autoworks STS, PR solid motor mounts, PR shifter bushings, control arm bushings, trailing arm bushings, FSTB, RSB. Eibach springs with Ilumina 5-way adjustable struts, 16.5 pound Enkei Wheels. Over 170,000 miles.
00 GLE Forest green (wifes car)
My other hobby http://www.thesteamworkshop.com
Derrick2k2SE is offline   Reply With Quote
Old 08-12-2009, 05:45 AM   #4
LA02MAX's Avatar
Points: 11,777, Level: 71
Points: 11,777, Level: 71 Points: 11,777, Level: 71 Points: 11,777, Level: 71
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Send a message via AIM to LA02MAX Send a message via MSN to LA02MAX
Quote:
Wrong. They're actually the strongest. The only think weak about them is their 3rd gear synchros, but the result is more of an annoyance than anything. I haven't heard of someone busting one of these 6 speeds due to worn synchros... My transmission has had a bad 3rd gear synchro for about 30k miles and all I have to do is double clutch if I downshift into third. Not a big deal.
__________________
LTB, RSB, FSTB, H-techs and Illuminas, 6.5 gen wheels, 6th gen front brakes
PB: 14.338 @ 98.27 with a 2.300 60' stock.
LA02MAX is offline   Reply With Quote
Old 08-12-2009, 09:08 AM   #5
Activity: 0%
Quote:
Interesting. Would it be possible/cheaper to have my transmission guy replace the syncros with 04-06 ones?
Old 08-12-2009, 09:55 AM   #6
Rochester's Avatar
Points: 15,264, Level: 79
Points: 15,264, Level: 79 Points: 15,264, Level: 79 Points: 15,264, Level: 79
Activity: 5.6%
Activity: 5.6% Activity: 5.6% Activity: 5.6%
Quote:
That's a good question. It seems unreasonable to replace the entire transmission for a poorly designed component... but I base that mechanical opinion on nothing what-so-ever.
I really hate my 3rd gear crunch. I get it in the winter, before the engine warms all the way up. And about 90% of the time if I wind out 2nd gear.
It's that last scenario that makes me sad. Redline is where all the fun is.
__________________
FI RHFC R2C Intake Eibach sways GT-Spec FSTB Swift Springs Michelin PSS Vossen CVT
2011 Infiniti G37 Sedan 6MT
Rochester is offline   Reply With Quote
Old 08-12-2009, 02:20 PM   #7
Activity: 0%
I actually have more of a 4th gear crunch. My 3rd gear is relatively smooth.
I don't know if what I'm feeling is really a crunch, its like it clicks 2 times when I slide it into 4th.
Ill try to research some more and see if I can put syncros from an 04-06 transmission in there.
If anyone knows definitively, please let me know if this will work.
Old 08-13-2009, 06:19 PM   #8
2000 maxima 5speed here at 104k miles, no problems. but i dont drive it like a rental either.
Hind135 is offline   Reply With Quote
Old 08-13-2009, 06:21 PM   #9
Cletus
SoonerFan's Avatar
Points: 24,824, Level: 95
Points: 24,824, Level: 95 Points: 24,824, Level: 95 Points: 24,824, Level: 95
Activity: 0%
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
98K on my car...hard driving...shifts are as smooth as when i bought it with 25K...actually smoother...but thats the STS and bushings...
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
A few offroad mods
Maxima - sold (but my 5th gen knowledge wasn't in the trunk when I sold it)
O2 Sensor Locations and Corresponding Codes
SoonerFan is offline   Reply With Quote
Old 08-13-2009, 07:18 PM   #10
Rochester's Avatar
Activity: 5.6%
Quote:
That's nice for you.
SoonerFan... you've been around the Org forever. You know the 5.5 gen as well or better as anyone here. Can you weigh in on Unklejoe's question, when he asked -
"Would it be possible/cheaper to have my transmission guy replace the syncros with 04-06 ones?"
In other words, can the infamous "crunch" be repaired, or do you have to upgrade to the 6th Gen manual tranny?
__________________
Old 08-13-2009, 07:37 PM   #11
Points: 6,105, Level: 50
Points: 6,105, Level: 50 Points: 6,105, Level: 50 Points: 6,105, Level: 50
Activity: 0%
Quote:
If you drive it right it lasts forever, in other words don't drive it like a rental.
__________________
Quote:
Originally Posted by Rochester View Post
Welcome to the forum! There are some good people here, with a friendly, even-minded Moderator.
Quote:
Originally Posted by internetautomar View Post
You should be banned for saying that
2002 Max SE 6spd...died 7/13
1990 VE-5 This is not a misprint!!! died 03/03/12
2002 BMW 325XI 5spd Sport
1987 Z31 NA2T/ AT2M
1986 Z31T AT2M
1986 Z31NA
Augustus Maximus is offline   Reply With Quote
Old 08-13-2009, 09:52 PM   #12
Activity: 0%
Anything can be fixed. I do remember something about the 04/06 syncros not fitting though.
The point of swapping is that you can get one with less miles and upgrade to HLSD which most of the cars in the U.S.A. didn't come with.
Quote:
Not true at all. This is a flawed design in the 02/03 and prone to failure. Not on every car but a very high percent compared to other cars. This problem isn't because of abuse.
__________________
Old 08-13-2009, 11:37 PM   #13
Activity: 0%
My car already has the HLSD, this is why I'm interested in swapping syncros.
Thanks for all the responses guys, just trying to get a grasp on how wide-spread this problem is.
I remember seeing a thread about the 3rd gear crunch, but it seems that people only post in threads like that if they actually have the problem, so its nice to hear from some people who don't actually have the crunch.
Old 08-14-2009, 01:51 AM   #14
Toolie
knight_yyz's Avatar
Points: 13,333, Level: 75
Points: 13,333, Level: 75 Points: 13,333, Level: 75 Points: 13,333, Level: 75
Activity: 3.9%
Activity: 3.9% Activity: 3.9% Activity: 3.9%
for the record, they do fall apart with proper maintenance. My 1st tranny started to whine in all gears, it was very loud, gears 1, 2 and 3 sounded like reverse, most of the bearings were toast, the synchros were toast. I didn't drive it like a grandma, but it lasted about 180K km.
My 06 tranny that i swapped into the car last year already spun a bearing so it is being replaced in a few weeks...
__________________
6MT | 06HLSD | I/H/E & FC | Stillen FSTB & RSB | Tein SS C/O | Watkins STS | UDP | NWP Spacers | Tuned with EB | ES Bushings
253.50 fwhp
249.75 lb/ft tq
14.3 @ 101mph (street tires, bad wheel bearing and a few spun tranny bearings)
knight_yyz is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
