no interior lights
Old 08-08-2009, 09:40 PM
mrjamaica98mx's Avatar
no interior lights
no interior lights plus no rear defrost no pwer locks
can anyone help!!!!!!
bought fuse tester all fuse light up red
2001 gle
mrjamaica98mx is offline
Old 08-08-2009, 10:43 PM
dsm=power's Avatar
have you checked your fueses in the engine bay ?
dsm=power is offline
Old 08-08-2009, 11:07 PM
yeah all work some are missing but test light lit up on the empty spots.
Old 08-09-2009, 07:41 AM
anomaly117's Avatar
check the in cabin fuse labeled "room light"?
anomaly117 is offline
Old 08-09-2009, 09:00 AM
Max_5gen's Avatar
Originally Posted by mrjamaica98mx
no interior lights
bought fuse tester no light when put on fuse for lights how do i fix this>
2001 gle
Is this the only thing not working? If there're more, like trunk room lamp not working as well read Maxim24 message in the thread:
http://forums.maxima.org/5th-generat...dont-work.html
Max_5gen is offline
Old 08-09-2009, 09:29 AM
nsnrider's Avatar
did you check the bulb? maybe its blown.
check all fuses.
nsnrider is offline
Old 08-09-2009, 10:14 AM
bulbs are ok
Old 08-09-2009, 10:16 AM
thanks found this thread and i seem to be having same problems! need a resolution ps i don't have a key fob.
wtb 2001 key fob
Old 08-13-2009, 09:00 PM
WERE IS THIS smart entrance control module LOCATED
PIC BELOW
Old 08-15-2009, 10:05 PM
is it the black or white box?
Old 08-16-2009, 10:11 PM
DennisMik's Avatar
go here and download the FSM for your car:
http://boredmder.com/FSM/Nissan/Maxima/
the smart entrance control is in the EL section, starting on page 310.
DennisMik is offline
Old 08-17-2009, 02:39 PM
thanks for the replies i'm just going to take it to a mechanic when get some money.
ps new thing ... when dome light is put to come on when door is open the light does not come on but dash lights show door is open even when close.
pic below
Old 09-11-2009, 09:46 PM
update*
The map light now works
but only if the dome light switch is off and the door open light still comes on when i turn the light on.
Old 09-11-2009, 10:34 PM
Max_5gen's Avatar
update*
Can you post if your trunk light works or not? The advantage of this test is it doesn't have any additional logic attached as it is powered directly from battery saver output.
Max_5gen is offline
Old 09-13-2009, 04:10 AM
no trunk light
Old 09-13-2009, 07:37 AM
Max_5gen's Avatar
no trunk light
If the bulb is OK check page EL-89 of your FSM. You should see that the same wire from pin 17 of the SECU powers up ignition hole light, visor mirror lights, spot lights (map lights), trunk room light and through some additional circuit - inerior light. If all of the above don't work or very dim then your SECU is fried and needs replacement. You don't have to use dealer's equipment to program your remote into replacement SECU, there's a simple procedure here on the site how to DIY. You don't even have to do it if you don't have remotes, it will be just simple replacement.
I'm afraid power locks is a separate story and most likely not working because SECU is getting 'door open' signal from one of the door switches. I wouldn't worry about that at the moment: if you're to replace SECU then power locks might start working on their own after replacement as the very same unit is involved.
Max_5gen is offline
Old 09-13-2009, 07:41 AM
Max_5gen's Avatar
PIC BELOW
Neither, I'm afraid - check page EL-342 of your FSM it shows units locations. In any case it should have 2 connectors: 18 and 24 pin (page EL 90 connectors M40 and M41).
Max_5gen is offline
Old 09-13-2009, 09:50 PM
THANK U ! will try to locate again i can't wait to fix this annoying problem.
Old 09-13-2009, 10:01 PM
is this it? and if so were on car is it?
Old 09-14-2009, 07:35 AM
Max_5gen's Avatar
Looks like it but I saw it last time few years ago. I also don't remember where exactly it is located. Looking at FSM it seems somewhere on the central console but I can't recall on which side. Find yourself and post back to enlighten future readers .
Max_5gen is offline
Old 11-21-2009, 04:25 PM
update just found out my trunk light works but only when car is on............wierd
Old 08-05-2013, 07:22 AM
soxsrules's Avatar
Hey, i know no one has posted to this thread for a few years. I just bought a 2k Maxima with 44k miles a few months back. I just got the same exact problem, (power locks, rear defroster, interior lights don't work). I checked all my fuses (left of steering wheel and under the hood), only found 1 blown 5A fuse, which I replaced. Still had the problem. Went to a junkyard and grabbed a SECU, plugged it in and still had the problem. Did anyone ever find another solution besides the replacing the SECU? I'm a college student and really don't want to pay a Nissan dealer or an autoshop to diagnose and fix.
Thanks!
soxsrules is offline
Old 07-31-2014, 10:52 AM
SE-Rfornow's Avatar
So I had these same issues but had trouble finding a SECU at a local junkyard. I'm glad I didn't because...
THERE MIGHT BE AN EASIER WAY!!
****Try disconnecting the two plugs going into the SECU, waiting 5 seconds and then reconnecting them. After about a year of no interior lights, power door locks, and rear defrost.... they all work!! The first time I plugged them back in the horn started honking like the car alarm going off and again when I opened the trunk. So the second time I made sure the keys were in the ignition and turned to accessory, unplugged the plugs and reconnected them starting with the white plug first. After this I had no more alarms. Also, FYI I took off the kick panel under the steering wheel by removing two screws to make unplugging the unit easier.
This is the box that I assumed to be the SECU: Click the image to open in full size.
I found this thread: http://x.nissanhelp.com/forums/maxim...defroster.html and thankfully tried unplugging it before buying a brand new unit from a dealer. Finally no more using a flashlight inside my car!
SE-Rfornow is offline
Old 07-31-2014, 07:19 PM
Max_5gen's Avatar
If this was that easy you could just unplug the battery and press the brakes to get rid of residual charge without removing anything. BTW, unplugging something with power ON is not a good idea in general- you can burn it if connector's pins get disconnected/connected in wrong sequence while you're unplugging/plugging them.
Max_5gen is offline
Old 08-01-2014, 10:37 AM
DennisMik's Avatar
While you are correct that disconnecting the battery would be much easier, unplugging the connectors doesn't seem to hurt the SECU. The connectors used are capable of many times the amount of current that the SECU draws and won't be damaged.
Old 06-18-2018, 11:43 AM
SteveOKid's Avatar
Answers
Hey I figured out the solution. I may be late but hopefully it helps someone in the future. It's just a relay gone bad. While fixing my taillight relay I switched it to a headlamp relay. Twilight was fix but the same problem occurred to me. Trunk won't open nor doors will unlock unless I had the key in, and when my door is open it says trunk is open as well. I couldn't figure what happened until I realize that I switch the relays and never bought a new one for the broken one. Hopefully this helps
SteveOKid is offline
Old 11-07-2018, 08:48 PM
cdoublejj's Avatar
which relays just the tailight and headlight?
cdoublejj is offline
Old 11-07-2018, 09:13 PM
SteveOKid's Avatar
reply
yess, you can test the relay but another key thing that also is the exact cause is the fuses under the steering wheel. Driver side, idk which on the top of my head but look carefully, cause it took me awhile to realize this is one actually missing.
Old 11-16-2018, 05:54 AM
cdoublejj's Avatar
i had mine one over. DOH!
Old 10-11-2019, 09:11 AM
Msled's Avatar
Attachment 21684
Thanks worked like magic, part from Junkyard $17 Dollars. Thanks again!! could not get that bracket off though end up cutting off with small hand saw
Msled is offline
MR96GLE
07-20-2009 06:35 PM
syphic
03-24-2004 02:30 AM
phillysmoswantd
02-15-2004 05:39 PM
Dusky
07-31-2001 07:30 PM
Quick Reply: no interior lights
