Seafoam is a wonderful product!
#121
Get an 8 foot section of small diameter hose and connect it to the source for the VIAS vacuum tank. Then you can sit comfortably in the driver's seat, keeping the RPM's at 2000 while slurping up the Seafoam. This approach works very well. The little hose fits easily into the narrow neck on the Seafoam can, and you don't run the risk of gulping up too much at once.
Note the red circle below:
#122
Funny thing, I started this thread last year when I first tried it, and just recently I did it yet again and there was little to no smoke coming out of my exhaust, so I guess that solidifies my claim!
#125
Well...I did it yesterday, but I put half of the can in my fuel and half in my oil. None thru the vacuum lines. Needless to say...NOTHING happened. Today I'm going to buy another bottle and run 1/3 of it thru my vacuum line. I'll let you know what happens tomorrow.
#126
#127
Beats me. The 5.0 gen VIAS is different. Try the brake booster. Larger hose, same concept.
There was a thread/write-up a few months back from someone who used a long length of hose from the brake booster, and did this from the driver's seat. It's what gave me the idea to use the VIAS vacuum source, which I think is tons easier to do. But you're right, the 3.0 liter is different.
#129
1/3 to gas tank
1/3 to engine oil (then change oil 200-300 miles later)
1/3 to vacuum line feeding intake valves
#131
It just sold my '97 Altima last weekend, 237K+ on it. Never used any cleaners, additives, or other snake oils, not so much as using synthetic oil or blend. The car ran great, the new owner uses it as a DD, no complaints from her either. The only point I'm making here is........WHY? Why use these additives when they are NOT necessary?
im a big opponent of adding "additives" of any kind to your car (injector cleaner, oil cleaner, coolant cleaner, and seafoam) etc etc, anything that you have to add that supposedly "increases performance"
psh yeah right. i added a bottle of techron to my cobra, and the thing started pinging so bad like a mother i had to flush the entire fuel system to get rid of it.
the only problems that occur have been o2 sensors throwing a ses code for a short while due to all the crap being flushed out of your dirty engine at once... nothing to write home about imo.
#132
I'm gettin this on my way home tonite and given it a try. I have bit of stumble at warm idle, and pretty bad gas mileage, so we will see if it helps. I'm an 02 6mt, with just under 200 0000kms, for $10 it's worth a try
#133
Hi,
I just figured that I would add some fuel to the fire...
I worked at GM dealerships during the 1980 & 1990's and GM had some TSB's regarding the use of GM Top Engine Cleaner for cure some symptoms...
On 151ci Iron Duke engines to reduce ping by removing carbon from the combustion chambers and on the 350ci GM (Oldsmobile) diesel engine for sticking rings (removed pre-heaters on a hot engine and poured Top Engine Cleaner into the cylinders by way of the pre-heater hole)...
For using this product the correct usage was to pour in or suck in from a vacuum source 1/3 or the can as fast as possible and keep the engine from stalling by opening the throttle....
The faster pour, the better and then increase the pour to stall the engine, turn the key off and allow the engine to sit overnight (12 hours) with the cleaner in the combustion chambers.....Start the engine the next day and pour or suck the rest of the can into the engine.....
Allow the engine to warm and drive a short distance and than change the oil & filter because the cleaner left to sit in the cylinders will work its way down into the oil....
I had a Chevrolet Suburban that was used to tow my race car that had its life extended about 30,000 miles because using Top Engine Cleaner would free up the oil rings and cut down on oil consumption until I rebuilt the 350ci engine...
In the past the GM Top Engine Cleaner did work, but probably the EPA removed all of the ingredients that worked...
I have no information or position on the use of Seafoam or BG44, only that the use of an effective Top Engine Cleaner can be beneficial...
Bob
Bob
#136
wow after going through 4 pages of lots of trashtalk, I have a 4th gen Maxima with 180K miles.
To put some seafoam into the intake manifold, do I disconnect any vacuum hose or open the PCV value as pour some in there as per this video.
http://www.youtube.com/watch?v=sV4nRjNp0C0
#140
As mentioned you do have to draw it in slowly into the intake and then turn the car off for a few minutes and then restart. You mentioned that you put 1/3 of the can in the oil crank cases so you will need to do an oil changed as the seafoam mixture will thin down your oil it can NOT be left in there for a drive cycle.
#142
still no smoke. Maybe my max already had it's colon cleansed?
Anyone agree?
#143
#144
Yes this must be done withing 50 km of adding seafoam to the crank case, that is why most guys would perform a full seafoam treatment followed by an oil change. I am sorry you didn't know this and now have the expense of an additional oil change, but I am glad you at least posted what you had done using the seafoam and save you a major engine problem.
#145
OK just changed it. It was running a bit rough.
thanks
litch
123
01-04-2024 07:01 PM
TallTom
50
07-08-2022 09:54 AM
04-16-2020 05:15 AM
jds22
09-29-2015 02:03 PM
