Can this be done?
Can this be done?
Can you make the rear windows and sunroof open when pressing and holding the unlock button on the fob instead of just opening the front windows? What would need to be rewired or modded? Would be really useful to me.
I doubt you can get the sunroof to open since it has a fixed switch (ie: it matters what happens with it even when the car is off; if you move it, it doesn't return to its original position). However, the rear windows shouldn't be terribly difficult if you can locate a wiring diagram of the alarm system.
I don't have the link any more but there was a company that made a circuit you could wire in. It would let you control other things with the factory remote. You could roll all the windows up and down and control the sunroof.
If you had the info on this, I would love to see it if you could find it. I was hoping someone had done something similar already. I didn't find anything though.
This would be good for the making the windows go up. I linked to the PDF instructions because you can't directly link to the product. I wish there was a way to integrate the rear windows into it atleast.
http://www.kptechnologies.com/docs/N...stallation.pdf
Like I said, find a wiring diagram (maybe in and FSM..can't view it right now since I'm at work) of the alarm system, and it's possible you just need to splice the wires from the rear windows into it...
I'm sure that would work, I was just hoping someone had done it already that actually knew what to do
That feature is not present with the factory remote on 5th gens. Unless you are referring to some kind of rewire.
