Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-22-2009, 04:27 PM   #81
Quote:
Originally Posted by holymoly View Post
bushings? I just slid the rad back in.
The parts circled in red come off the radiator, exposing two pins that are molded into the radiator, and are what hold your radiator at the bottom. They keep the rad from flapping back and forward at the bottom. You were supposed to reuse those, unless your new radiator came with new ones attached already (mine didn't).
(I took the liberty to use your picture to show what I'm talking about. I hope it's not copyrighted....)
Edit: If you need to install those and already have the radiator in place, just remove the upper brackets, lift up the rad a little bit and slide those in place.
__________________
Nelsito65 is offline   Reply With Quote
Old 10-23-2009, 03:42 AM   #82
This is what the rubber looks like:
You may need two draining pans for the transmission cooling lines:
See the difference between the two rads:
And of course, use silica free OEM coolant to prevent premature waterpump failure:
LoveSick is offline   Reply With Quote
Old 10-23-2009, 06:08 AM   #83
You are right, I only had those pins. Need to put those two in place.
Thanks.
During the flush, I wasn't able to get the thermostat out.
Would the thermostat still in place restricted the flush in the engine block?
holymoly is offline   Reply With Quote
Old 10-23-2009, 08:05 AM   #84
Doubt it, as long as it functions correctly (opens when hot). I never touched my t-stat.
As far as those rubber mounts, I had to reuse them...my new Koyo radiator did not come with them.
__________________
137k miles
To-do: Belts, Fix suspension problem
Major probs fixed: L
ower oil pan | Radiator | EVAP canister/valve| VIAS Control Valve | Rear VC | MAF (2k1 w/swapped thermistor)
ridinwitha35 is offline   Reply With Quote
Old 10-23-2009, 08:18 AM   #85
yup, I had to place those in now posthumously. they're in there now.
Old 10-29-2009, 12:47 PM   #86
Donating member? what the?!
super32's Avatar
Send a message via AIM to super32 Send a message via Yahoo to super32
Quote:
http://i6.photobucket.com/albums/y25...r/23a5dbf7.jpg
wow. the new radiator looks huge! did/will it fit?
where did everyone go to get their radiator? I need to replace mine soon, but don't want to get a "cheap-o" version
i keep hearing about "Koyo", are they that much better?
thanks!
__________________
... doing it 3Gen, and no other way
get it here
super32 is offline   Reply With Quote
Old 10-29-2009, 01:19 PM   #87
Just found out some say Spectra Premium is even better and cheaper.
They say Rock Auto is one place to get one.
Old 10-29-2009, 07:16 PM   #88
The Dirty Pearl
pmohr's Avatar
Indeed, the Spectra is very nice (just installed mine yesterday). Just over $100 shipped from RockAuto.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
