Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-02-2009, 01:55 PM   #1
Remove LCR To Replace Axles/Boots
Just did a quick search, so not certain if this has been posted before, but rather than removing the Strut to Knuckle assembly, which will change alignment, or trying to remove the Ball Joint from the Knuckle, I decided to just remove the LCA. Raised the car, disconnected the stabilizer link on the LCR, then removed the 6 bolts and dropped the LCA out of the way. Pulled the left side axle, replaced the boot then went to the right side. The bearing was a bear as it was frozen in the support, but used a little heat and out it came. The boot kits were only $12.50 each from Napa, so the daughter was happy with the savings.
Only caution is that during reinstallation, the suspension should be loaded before final tightening of the LCA and stabilizer bar.
Turbonut is offline   Reply With Quote
Old 07-03-2009, 09:07 AM   #2
Guess fat fingers. LCR=LCA Lower Control Arm
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
