Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-01-2009, 09:46 AM   #1
Necessary to replace mounts same time as struts?
I used search and couldn't find anything.. My struts have been blown for a quite a while now (clunking and now bouncy as hell) i'm just waiting for the cash to come along to get new struts.
I'm just wondering tho, is it necessary to replace the mounts at the same time? How do i know if the mounts are bad? I've never done struts before so sorry if this is a noob question.
__________________
2k3 SE 6MT Silver Mist, Exedy stage-1 clutch, Fidanza lightweight flywheel, KYB Struts, H&R Sport Springs
rosader is offline   Reply With Quote
Old 07-01-2009, 10:45 AM   #2
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Might as well change the mounts since 'you're already in there.' Bad mounts cause a strange vibrating/clunking sound when on rough / uneven pavement.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 07-01-2009, 11:30 AM   #3
There are bearings in the strut mounts, right? So... yeah, makes sense.
__________________
NWP phenolic intake spacers, Cattman y-pipe, Cattman 2.5" cat-back, Frankencar short-ram intake, Apexi pop charger, UR crank pulley, ES motor-mount and sub-mount bushings, Racingline FSTB, Progress RSB, STS mod w/ES bushings, Brembo blanks, Hawk ceramic pads, Goodyear Eagle F1's -- 54,000 original owner miles
Rochester is online now   Reply With Quote
Old 07-01-2009, 11:54 AM   #4
Quote:
If you can (as Nissan does) two greased rings of plastic "bearings".
Changing out struts is a fair amount of work, so as with anything that involved, take the opportunity to "make new" as much as you can.
__________________
LTB II, CAI, H&R, Illuminas, ES shifter, subframe, engine mounts, sway bar bushes, Megan OE-RE.
SteveB123 is offline   Reply With Quote
Old 07-01-2009, 12:00 PM   #5
Wat
E55AMG2's Avatar
Quote:
+1
they also squeak
Might as well replace them while you've got it all apart. Make sure to grease as well. Dave Burnette will get you the best price on the mounts
1888-254-6060
__________________
Quote:
Originally Posted by Mass_Media
bmw's are hand crafted by god....when you see this you will understand...
Quote:
Originally Posted by SuperChris
BMW's are crafted by the hands of Satan himself.
Before you post your dyno #'s, make sure your shop isnt doing anything on this list: http://www.turbomagazine.com/tech/04...icks_problems/
E55AMG2 is offline   Reply With Quote
Old 07-01-2009, 12:12 PM   #6
"...take the cannoli"
mannetti21's Avatar
If you're doing the work yourself, and you are strapped for cash, I'd say hold off unless you have clunking. If you are paying someone to install, you might as well replace now otherwise you may have to pay more labor charges down the road. I got my mounts from www.rockauto.com ......they actually had better prices than what I was quoted by Dave
__________________
|2001 SE|Sterling Mist|A33 tags|Magnaflow exhaust|GAB|K&N Panel|+3* ign timing|WeatherTech Deflectors|
|6000k heads & fogs|fog re-wire|AngelEyes|Clear sidemarkers|FSTB|Tein H-Tech|Tokico Illuminas 4F/4R|
|139db Stebel Dual Tone|Tint 30%side 5%rear|Sirius Satellite|
mannetti21 is offline   Reply With Quote
Old 07-01-2009, 12:58 PM   #7
Certified Hooptie
NmexMAX's Avatar
They're only like 30$ a side. So, not sure if cash would be that large of an issue.
__________________
Old 07-01-2009, 03:38 PM   #8
Do i need to buy new dust boots too? what else do i need to replace while doing struts?
__________________
Old 07-01-2009, 08:15 PM   #9
Send a message via AIM to wish2345
Quote:
which ones from rockauto did you buy ?
__________________
02 Maxima SE Sterling Mist
wish2345 is offline   Reply With Quote
Old 07-02-2009, 04:30 PM   #10
i had the same question. i can get a new set of KYB rear struts for $127, first question is that a good deal? and do i need to change bellows and mounts?
tac8998 is offline   Reply With Quote
Old 07-02-2009, 06:36 PM   #11
Go for Moog mounts. Better than OEM and who knows what you might get on EBay.
I think the Part Numbers are the same for all 5th Gens. These are the Part Numbers for a 2003.
Fronts are Part Number K90655 and includes the bearing
Rears are Part Number K90299
They also have Strut Bellows which includes the bumper
Front K90463
Rear K90467
You might want to check on the sway bar links also. While you have everything else off. That's where I was getting a lot of my noise from
The Moog's are thicker and have grease fitting compared to stock
Part Numbers are
K90432 for the left
and
K90431 for the right
After that the only other thing on the front for suspension is the balljoints
Hope this helps.
fflint_18 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
