Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-30-2009, 08:22 AM   #1
ABS brake light on
Hey guys,
My abs light came on the other day.............before you start nailing me, I did search and found some good information. I did find a fellow org member metioning the problem I am running to but no solution or causes. My ABS light stays on but sometimes goes off. I hear a "humming" sound when I initially insert the key and turn it to "on"; when I do, my ABS stays on. I did check my brake fluid level, even though that would not cause the light to come on. What can it be sensor, the acuator or the sensor rubbing?
The car is not lowered and replaced my pads about a yr ago.....
Thanx
Amit56 is offline   Reply With Quote
Old 06-30-2009, 10:18 PM   #2
B!tches...all of you
foodmanry's Avatar
Most likely it is an ABS sensor/line at one of the wheels. Even if you pinch or bend one of the lines it will cause the issue so check the lines first.
foodmanry is offline   Reply With Quote
Old 06-30-2009, 10:23 PM   #3
Pull the wheels off and make sure the sensors are clean. I beleive they are magnetic an can attract things you dont want. Just blow it off with compressed air if its dirty.
dustey is offline   Reply With Quote
Old 07-01-2009, 07:39 AM   #4
Thanx for the tip.....i will check it out this long weekend and let you guys know.
Thanx
Old 07-01-2009, 07:45 AM   #5
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Some code scanners will scan ABS codes too. If you have one, or have access to one ... This will tell you what sensor is at fault.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 07-01-2009, 07:53 AM   #6
Send a message via AIM to njmaxseltd
You can pull the abs codes yourself, that will tell you exactly what has failed.
Search around on here a bit more for the procedure, it involves jumping a pin in I think the OBD II connector. It was somewhere down by the fuse pannel.
njmaxseltd is offline   Reply With Quote
Old 07-02-2009, 04:43 PM   #7
same problem guys i have a little more info on mine though, i had the code pulled yesterday and he cleared everything, it came back as sensor open. that means i have a faulty sensor correct? everytime he cleared my code it came back on instantly, i just dont want to waste $160 for a new sensor and then that not be the problem.
BTW it is my front passenger side.
tac8998 is offline   Reply With Quote
Old 07-20-2009, 07:02 AM   #8
aright guys....I finally got my car scanned and it read as the left rear abs sensor......now i just need to find a place besides a dealer
thanx for your help
Old 07-25-2009, 03:45 PM   #9
How to clear the ABS light
How did you clear the code? I did the thing with Pin 9 grounded, it gave me a code 31 ( right rear). I cleaned the sensor and tried to reset the code, but I couldn't get it to clear.
The instructions I followed were to read the code then ground pin 9 three times within 12 sec. Did all that but the code never went away. Help
Sammy Z is offline   Reply With Quote
Old 07-25-2009, 04:58 PM   #10
foodmanry's Avatar
Means your sensor is still bad. You need to replace it.
Old 07-26-2009, 02:05 AM   #11
I put a volt meter on the sensor and it's reading the same as the other sensors, did the cleaning thing as well. If the car doesn't move, I would think the system would let me clear the code then maybe turn the light on when I start driving if the sensor were bad. Any ideas as to how to reset the light?
Old 07-26-2009, 09:25 AM   #12
The Dirty Pearl
pmohr's Avatar
Assuming you've got a 5th gen (since you've neglected to either tell us, or fill out your profile).
You need to ground that diagnostic pin for at least 1 second each time, 3 times within 12.5 seconds after removing the ground after checking codes.
If you're getting a code immediately, then it's likely not related to the performance of the sensor, but that the ABS control unit isn't seeing it at all.
Just testing the sensor itself is useless if you have a problem with the system. Have you not tested the harness back to the ABS control unit yet?
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 07-26-2009, 11:57 AM   #13
It's a 2001, I tested the signal where the wires come in under the rear seat to eliminate the chance of a connector being bad. I checked both right and left side and the have simialr readings. I suppose I should make the the same test at the harness at the ABS control unit.
I did the ground thing to pin 9 three times (1sec ea. ) in less than 12 seconds.
The thing that gets me is that I would think the ABS would go off for a second or two before it came back on. It acts as if I'm not clearing it at all.
BTW, is it possible to swap the sensor with the rear leaf to see if the symptom changes?
THANKS IN ADVANCE FOR THE HELP !!
Old 07-27-2009, 07:09 PM   #14
Quote:
Originally Posted by Amit56 View Post
Hey guys,
Thanx
I've recently started experiencing some ABS issues as well. Based on my understanding of the ABS system, I know there is a motor/pump combo in the ABS controller, the humming I hear sounds like that motor is spinning w/o resistance, as if there was no fluid in the pump area. I can tell that once it stops testing the system (supplying power to the motor), the motor spins down slowly as I get a whirling noise. Is this basically what you have?
__________________
Auto
2002 Sterling Mist Maxima SE 6spd w/HLSD and every other option but navi
H&R Springs/Tokico HP Struts, Courtesy FSTB, 350Z dead pedal, 35% tint, Redline Oils
Moto
2003 Silver/Black Honda CBR 600 F4i
Scott's Steering Damper, Intuitive Frame Sliders
Y2K2Driver is offline   Reply With Quote
Old 07-27-2009, 09:14 PM   #15
hey guys., i also have my abs light on my 5th gen max. my pads and rotors on the front were recently replaced and my rears were shot so i did pads and rotors in the rear,..the light stayed on...i have access to a scanner, but the comp says it does not read any faults in the system, i even tried clearing it with the scanner...light stays on....any1 know my next step?
cdawg36 is offline   Reply With Quote
Old 07-27-2009, 09:15 PM   #16
The Dirty Pearl
pmohr's Avatar
Quote:
Are you checking the ABS codes with your 'scanner', or the ECU codes?
Is it a basic OBD-II code reader, or does it actually have ABS computer functionality?
__________________
Old 07-27-2009, 10:00 PM   #17
where is the sensor located in the rear of a 5th gen? i had a tire go out on the interstate and i think a simple cleaning will hopefully solve my problem, push come the shove ill check my lines
phatboislim is offline   Reply With Quote
Old 07-27-2009, 10:03 PM   #18
The Dirty Pearl
pmohr's Avatar
Quote:
Behind the wheel.
__________________
Old 07-27-2009, 10:12 PM   #19
well from the pic not on the wheel specifically, but behind it...just wanted to clarify, because i thought i messed up by swapping out for g35 wheels causing more problems just to make my 5th gen more aesthetically pleasing. thanks for the diagram. i will get to this friday hopefully.
Old 07-27-2009, 10:13 PM   #20
The Dirty Pearl
pmohr's Avatar
Well obviously it's not on the wheel itself, that's a given.
__________________
Old 07-27-2009, 10:37 PM   #21
i was thinking about teh 'TPMS' sensors on some of teh newer maximas when u said on teh wheel...not knocking you
Old 07-27-2009, 10:40 PM   #22
Bad *** Newb
Child_uv_KoRn's Avatar
Inspect the wires!
Child_uv_KoRn is offline   Reply With Quote
Old 09-19-2009, 06:32 PM   #23
OK guys............I finally got the time to fix this after couple months. Well i I got it scanned and its left rear ABS brake sensor. It did not go my way as the bolt that holds the sensor broke off (RUSTED/CORRODED). However, I managed to take out the sensor out; it was so dirty and I cleaned it off. Put it back on using some type of liquid sealer for temporarly. The light did not go out, assuming i need to get it cleared. But when i do turn it on, the humming noise still comes on when i start the vehicle. Any ideas???
Thanx for ur help
Old 09-19-2009, 08:05 PM   #24
Bad *** Newb
Thanx for ur help
The light will go out when it's fixed.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
