is it just me or the car?
Old 06-24-2009, 02:11 PM
maxima dude's Avatar
so i bought my maxima ...before the max i had a 03 specv with i/h/e ..it was nice and beefy and wuld spin the tires in 1st if i jus slammed on the gas and chirp and spin 2nd a bit...but now i try it with my max and it just doesnt(02 max 6spd) and it will chirp second....but i guess i was expecting so much more? i mean top end is great...i also just put in the es mmi and thought oh yea tire spin for days but it didnt...jus gave me vibrations and no wheel hop...i thought slammin on the gas and hittin second hard wuld fry the tires butt itle just still chirp...clutch is new if any1 was wondering lol....i also have a injen intake and megan racing catback with a gutted main cat...so is it me or the car? lol
maxima dude is offline
Old 06-24-2009, 02:16 PM
dot dot dot ...
NmexMAX's Avatar
It's not you nor the car ... it's your tires.
NmexMAX is offline
Old 06-24-2009, 02:18 PM
2damax's Avatar
I have had my 02 6spd for almost a year and I spin to much in 1st lol. I haven't even come close to mastering the launch. and I chirp 2nd and could spin a little if I want. You know how old/new your tires are? Idk if that makes a huge difference but mine aren't great tires so even if they are new it might just be easier for me to spin them. I got the injen too (want to get rid of it if I can sell it).
I'm suprised that you can't spin in first and you sound experienced enough to floor it lol. So i'm not sure exactly what it could be. Doesn't sound like its you though.
2damax is offline
Old 06-24-2009, 02:25 PM
PulsarGTS's Avatar
Stiffer motor mounts have always given me less wheel/spin = more traction. And as long as its not crazy hot out I can squeal to tires by stabing the gas. Im assuming you don't mean launching the car, just WOT from a rolling start. Your car is fine, if you want traction issues in 1st throw on some headers.
PulsarGTS is offline
Old 06-24-2009, 02:52 PM
yea i have perelli tires almost new ...i guess it is the tires? lol... im deff getting headers and other stuff...but i also dont have hlsd..does that make a differnce?
Old 06-24-2009, 02:59 PM
LA02MAX's Avatar
I'm on my 4th set of tires, and regardless I could never go WOT in 1st gear without spinning...I definitely got more traction when my tires were new, but never to the point where I could wring out 1st gear and not lose traction completely....HLSD won't help you in a straight, smooth road...mostly when you're turning. If the tires have equal traction they should both spin even with an open diff.
LA02MAX is offline
Old 06-24-2009, 03:06 PM
dot dot dot ...
NmexMAX's Avatar
You fellas must have never lived @ 7400' elevation.
NmexMAX is offline
Old 06-24-2009, 03:09 PM
so far 2 people say they loose traction at wot in 1st...and i never have lol...so it has to be the car then?
Old 06-24-2009, 03:19 PM
pimpin02max's Avatar
Mine doesn't lose traction completely but it does spin through the gear, it's probably just your tires...besides why are you complaining anyway, the better the traction the faster the car
pimpin02max is offline
Old 06-24-2009, 03:32 PM
dot dot dot ...
NmexMAX's Avatar
Get a dyno or a run @ the track with GOOD conditions
NmexMAX is offline
Old 06-24-2009, 04:19 PM
d-schist's Avatar
lol ya last year I drove my car to Colorado...wow absolutely no power going over mountain passes. It felt as if I was in an 18 sec car
d-schist is offline
Old 06-24-2009, 07:07 PM
i guess its the tires then...perellis are that good i guess lol
Old 06-24-2009, 09:32 PM
Derrick2k2SE's Avatar
HLSD does make a difference in a straight line. It helps tremendously. I swapped trannys to get it and did nothing else to the car at the time. I didn't even change the clutch since I had just changed it a few months before. The launch is way better and the tourque steer is a lot less. When I did the swap a few years ago I was going to the drag strip regularly so I was very in tune with how the car would launch under controlled conditions.
Driving in the rain feels a lot better now too. If I lay into it and spin the tires the car stays straight. If I did that before it would pull strongly to the right and I'd have to catch it.
I've driven several Spec Vs and several different Maximas. The Maximas always felt stronger than the Spec Vs. You might want to look at basic tune up services. Clean the MAF, new plugs (probably original) etc...
Headers will make a big difference on the 3.5.
Derrick2k2SE is offline
Old 06-24-2009, 11:07 PM
Feldman's Avatar
I almost know how you feel. i love taking my car to vegas or cali its like an instant 25hp i think the conversion is about 3% loss in hp per 1000 ft of elevation.
maybe your clutch is hating life a little and how could it not if you are constantly trying to roast your tires and slam it into second. you might want to consider checking your clutch adjustment and take into consideration the condition of your clutch. You may just be limited by the amount of friction your clutch can create to transfer the power of your engine to your tranny.
Feldman is offline
Old 06-25-2009, 06:02 AM
nissandrvr98's Avatar
yea man..why destroy tires when you dont have to. i mean if you're getting nice traction you get a better jump off the line to gobble up some Ac TL who's eyein you up at the light. Dont trash a nice set of tires-wait till they wear in and then have your fun .
My auto (w/TCS off) lays it down for a good 25 feet if I ask her to...but not so easily with new tires thats for sure.
nissandrvr98 is offline
Old 06-25-2009, 09:04 AM
anomaly117's Avatar
the car weighs a little more than a sentra, theres more weight on newer tires. and im sure if you rev the tach up enough, youll spin em, i layed a short strip and a little smoke in my 00 5 spd, and i always hop a bit in 2nd if i get on it
anomaly117 is offline
Old 06-25-2009, 06:42 PM
im not beatin oin my car or anything lik i do that everyday...im jus sayin lik when i do get on it at wot the tires wont spin in 1st...im guessin it rele is the tires now and grip is fricken amazing lol...but i hear alot of eople havin trouble wit tire spin in 1st and wen i try it just doesnt...thats wut this whole threrad is about...thinkin maybe i lost hp or sumthing....
Old 06-25-2009, 06:59 PM
dot dot dot ...
NmexMAX's Avatar
If you're really concerned, get a dyno. Attend one of those cheap dyno days for like 30$ for 3 or more runs.
NmexMAX is offline
Old 06-29-2009, 03:36 PM
Maximum-Maxima's Avatar
Idk man i have a 1997 nissan maxima GLE with cheap sams club tires and it chirps second. The way i can chirp second is i put the car into first and floor it and let up off the gas when i shift into second at around 5k and then floor it while it changes gears. I know this may not be good for my car but ive only done it about 3 times and it worked about 2/3 of those times!
Maximum-Maxima is offline
Old 06-29-2009, 04:49 PM
Rochester's Avatar
All kinds of factors... tire pressure, road debris, tread depth, temperature, humidity, weight distribution, suspension issues. Too many for a single answer.
Regardless the reason, the real trick is to learn how to keep it just south of that edge where you break loose, without actually spinning. Intentional burnouts are kind of childish off the drag strip.
But if that's your thing... consider that a FWD burnout is rather silly looking.
Rochester is offline
Old 06-29-2009, 04:58 PM
skidz88's Avatar
Judging your car's power by its ability to spin its tires is probably the silliest thing I've ever heard. There are too many factors at play.
Pay a few bucks to hop on the dyno and see where you're at, or make some passes at a drag strip. Not only will you get better results, but you'll save your clutch, tranny, and tires from the torture.
skidz88 is offline
Old 06-29-2009, 07:15 PM
Mu_036sp's Avatar
I have really good Traction in my 03 for launching, i have almost new bridgestone potenza's in my stock 17". but when i shift to 2nd. i can make it spin if i want. but i barely do that. I say its the Driving.
Mu_036sp is offline
Old 06-29-2009, 09:14 PM
PatKeo6373's Avatar
try trading front tires wit someone. i had the same prob i had a set of all season potenzas on and i could spin to third. then i got a set or G sports and third wont spin unless it wet. now that i got 19s second just does a decent cherp. if u got the tires a little wider thats deffinatly the problem. Since u have an hlsd its job is to reduce a wheel spin and cause more traction. Plus u dont got cheap tires why bother spinning them
PatKeo6373 is offline
Old 06-29-2009, 10:12 PM
tru...i guess ill jus wait till these tire wear off a lil
Old 06-30-2009, 06:11 AM
dot dot dot ...
NmexMAX's Avatar
NmexMAX is offline
Old 06-30-2009, 06:24 AM
maxboy325's Avatar
Why is wheel spin always the measure of power?
If you really want to know the power output(whp) Dynojet is your friend.
maxboy325 is offline
Old 06-30-2009, 06:26 AM
dot dot dot ...
NmexMAX's Avatar
quantitative > qualitative
NmexMAX is offline
Lakersallday24
06-16-2019 01:35 AM
MikesChevelle
09-28-2015 08:14 PM
Balkins
08-12-2015 06:39 AM
acw
08-07-2015 04:20 PM
yat70458
08-03-2015 01:16 PM
Quick Reply: is it just me or the car?
